What I wanted to say, is that it seems neither more strong nor more fragile than its concurrents.
And therefore, it should change the filter's character. Finally, I'm starting to think that those angry monosynths with control over the ocsillator's output levels are slightly more flexible.Black Tomorrow wrote:This is probably the case. For instance, the mixer on the Moog Rogue is specifically labelled with overdrive if you bring the sliders above a certain point.Scories wrote:Very interesting. Seems like some basic knowledge the vast majority of us just missed. By rising the osc volume slider looking for hot outputs and high signal-to-noise ratio, maybe we overdrive filters quite often.
+1! I was also thinking they could come out with a "Microbrute" expander w/o keyboard with additional interfacing, and they could also expand this additional modules - similar to the Moog CP251. That would be very cool I think!jcn7 wrote:If I remember correctly, it was mentioned that the MB will also have a "polychain" ability...if this is indeed true, then I can see Arturia selling a ton of expansion modules to polychain together for an ever increasing polyphony. Heck, even just 2 in a unison mode would be killer...2 MB filters running in parallel, say one HP into the 2nd in a LP mode...could reach MS20 territory quite nicely, and do a lot more...
I would love to see more inputs/outputs in an expansion module, but even if it was a total duplicate, it would still be a killer combo, for a lot less $ than many 2 osc synths.
Well done Yusynth and Arturia!
Sorry. didn’t know more analog poly and oscs on panel needs independent filters, envs, etc, and the $49 monotron duo had me thinking analog could be so cheap.Push-Pull wrote:Because for polyphony you need one VCO per voice.vox345 wrote:$699 instead of $499 for more keys, poly, and VCOs, and asked why they don't offer that
If you suggest a second VCO on the panel, it makes two VCOs per voice.
So, for a "little" polyphony of four voices, you need eight VCOs (!) four filters, eight enveloppes and so on.
I got an email 10 days ago saying that the eta for (UK) delivery was this Saturday, after it got pushed back from today.James Mandible wrote:They were pushed back at Sweetwater until late May so the wait may be a while.
