KORG MS10 with stereo headphones
arminp
Post by arminp » Tue Jul 03, 2012 6:11 pm
Hey guys,
I recently bought a KORG MS10, which I was looking for for a really long time! I can really recommend it to anyone looking for an analog synth..
However, I encountered a small problem.. Since the synth is monophonic, I only hear the left channel when I plug my normal headphones into the "signal out" jack.. It obviously works normally when I plug it into an amp or a mixer..
Is there a way to "double" the signal in order to be able to listen to what I play with normal stereo headphones? I'd love to take the synth to some places where there is no mixer around just to jam a bit..
Thanks a lot in advance,
Armin
V301H
Band: The Characters
Re: KORG MS10 with stereo headphones
Post by V301H » Tue Jul 03, 2012 6:54 pm
You might see if a local music or electronics store has a Stereo-to-Mono adapter plug something like this:
http://www.showmecables.com/product/1-4 ... 4AodTwq3Cw
pflosi
Post by pflosi » Tue Jul 03, 2012 8:16 pm
arminp wrote:Since the synth is monophonic, I only hear the left channel when I plug my normal headphones into the "signal out" jack...
No, since the synth is monophonic, you only can play one note at once. Since the synth has no headphone output, you only hear the left channel when you plug your normal headphones into the "signal out" jack... ;)
arminp
Post by arminp » Tue Jul 03, 2012 9:23 pm
Thanks for rectifying :)
I went to a shop today to ask for that kind of cable or adapter, but they said it wouldn't be such a good idea as there is some problem with the headphones impedance.. They said it might destroy the synth from the inside or something, I didn't quite get what they meant..
I guess I'll have to stick to my mixer then..
Post by madtheory » Tue Jul 03, 2012 9:39 pm
You won't destroy anything. But the "signal out" socket is not for headphones, it's for the line input of a mixer or similar. If it was for headphones it would say "headphones". :P But you've discovered that by trial and error now, so it's all good.
Nice synth!!
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Tue Jul 03, 2012 11:07 pm
One possible solution might be one of those tiny headphone amps made for electric guitar practice. I'll edit this post when I find a link.
Here is one version:
http://www.sweetwater.com/store/detail/amPlugAC30
- Confucius
fh991586
Real name: Francis
Korg Kaossilator, MicroKorg,
Yamaha Motif Rack.
Midines
Post by fh991586 » Wed Jul 04, 2012 4:15 am
But still, what's the real problem with using an signal output if there is not headphone output?
Available for sale:
Post by Stab Frenzy » Wed Jul 04, 2012 6:13 am
fh991586 wrote:But still, what's the real problem with using an signal output if there is not headphone output?
For a start, you only get signal to the left side of the headphones...
Don T
Real name: Don
Post by Don T » Wed Jul 04, 2012 6:19 am
Usually there is not enough power to drive the headphones, at least not at a useable level. By looking at the MS-10 service manual, if you are able to hear anything through your headphones, it's probably weak, or the headphones are amazingly sensitive.
Don Taylor
fh991586
Real name: Francis
Yamaha Motif Rack.
Midines
Post by fh991586 » Wed Jul 04, 2012 11:44 pm
When I test a synth before buying it, and there is no amp available, I check the signal output(s) with my cheap walkman headphones, and I can pick up the sound. It's not enough nor fun to play long like this, but it's still a possibility...
Just tell me there is no possible damage to the synth itself (why could there be anyway?), and the rest is irrelevant to me.
Available for sale:
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Thu Jul 05, 2012 12:42 am
Looking at the MS-10 schematic, the output is single ended, capacitor coupled. There is no logical way you could hurt the synth by using a mono to stereo adaptor on your headphones. You will have a rather low level signal, and loose much of the bass response due to the mismatch, but no damage.
Most synths in the past 20 years have a stereo headphone jack (with built-in amps to boost the level)
- Confucius
Sexor
Gear: Prophet6, Jupiter-7, MS25, Juno-50, TR-303, Rhodes 63
Post by Sexor » Thu Jul 05, 2012 4:17 am
Maybe you should try this then:
Same link
Monkey business since 2007!
Projectile
Post by Projectile » Sat Jul 07, 2012 5:54 am
The guys at the shop are idiots. You won't hurt the synth by using a mono to stereo adapter and plugging headphones into the line out. Though, it will sound pretty crappy without a headphone amp. I would recommend getting one of those cheap little battery powered headphone amps to boost the signal and give you the right output impedance. That should do the trick.
fh991586
Real name: Francis
Yamaha Motif Rack.
Midines
Post by fh991586 » Sun Jul 08, 2012 5:18 pm
That's what I thought. Thanks for the precision.
Available for sale:
