Arturia Minibrute and ARP CV/Gate
Postby Cotillion » Tue Mar 12, 2013 11:55 pm
Hey!
I'm new to both this synths and this forum - another reformed guitar player with too many pedals.
Anyways, I've got an ARP Solus and just bought an Arturia Minibrute to, hopefully, connect together in glorious harmony. Unfortunately, when I connect the pitch and gate outs from the Minibrute to the ARP, the ARP's octaves are way too high and out of tune. I did a little research and saw that voltages need to be changed in some way, but I can't find concrete info on what exactly needs to happen. Does anybody have any clue?
Cotillion
Re: Arturia Minibrute and ARP CV/Gate
Postby Kenneth » Wed Mar 13, 2013 12:02 am
Hey, welcome! You need an attenuator, that's really all the help I can offer. I unfortunately don't know a lot about control voltages, so I don't want to steer you the wrong way. Good luck.
Kenneth
Real name: Kenneth
Gear: Nothing I own will make you jealous.
Band: KGB
Postby Z » Wed Mar 13, 2013 12:39 am
You might also check to make sure the ARP's tuning is properly calibrated.
Z
Postby Steve Jones » Wed Mar 13, 2013 1:38 am
If you are going to run the ARP from the MB the ARP must be properly calibrated, because even if the ARP's VCO's are scaled correctly with the ARP's keyboard if the ARP keyboard CV is not also exactly calibrated to 1V/octave the synth won't play in tune with the Arturia.
Have you tried simply pulling the ARP's master tune slider right down to see if you can get it close to the correct range when played with the MB?
Steve Jones
Real name: Steve
Postby Cotillion » Wed Mar 13, 2013 1:54 am
Yeah, I've messed with the master tune. It still plays 3 or 4 octaves higher and not at the same pitch
Cotillion
Postby Steve Jones » Wed Mar 13, 2013 2:27 am
Cotillion wrote:Yeah, I've messed with the master tune. It still plays 3 or 4 octaves higher and not at the same pitch
Is it possible to switch the MB octave down? If you have a multimeter put it across the tip and sleeve of the lead that you have coming out of the MB's CV out jack and measure the voltage while you play the bottom key on the MB and see what voltage is produced. Sounds like it must be set fairly high, I wouldn't have thought that it should be more than about 3V to put the MB's little keyboard in a reasonable octave range...
Steve Jones
Real name: Steve
Postby Cotillion » Wed Mar 13, 2013 4:27 am
I'm getting a reading of 1.5V at the lowest note and octave on the MB
Cotillion
Postby Steve Jones » Wed Mar 13, 2013 5:05 am
Cotillion wrote:I'm getting a reading of 1.5V at the lowest note and octave on the MB
Sounds like the issue is with the ARP. What does your meter say when you read the CV out of the ARP bottom note?
Steve Jones
Real name: Steve
Postby micahjonhughes » Wed Mar 13, 2013 5:34 pm
When playing the ARP from the Minibrute's keyboard, does the note that sounds on the ARP depend on the last key pressed on the ARP's keyboard?
The ARP may be summing the voltage from its keyboard with that it is receiving from the Minibrute.
micahjonhughes
Postby calyx93 » Thu Mar 14, 2013 3:06 am
I had a similar problem when using the Moog FreqBox as a second oscillator expander. It wouldn't play in tune when cv-ed to the Minibrute and it was pitched higher by an octave even at the lowest frequency setting on the FB vco. Luckily I also have a Moog CP-251 which features a cv mixer with offset and two attenuators. The offset is the most important and I can now tune the MB keyboard cv pitch output over several octaves now. It's also proving useful when interfacing with my Lil Phatty - it too is pitched an octave off.
I know they're pricey - but it would be a definite solution and it's very useful tool too. Apart from the four way mixer (with + and - outputs. hello reverse keyboard scaling!) and attenuators, there's a cv controllable LFO, extra noise source, lag generator, four way multiple and sample & hold.
calyx93
Gear: PPG Wave 2.2, Waldorf μWave x3, Roland JP6+V-Synth, SCI P5+600, Ensoniq SQ-80, Kawai K-3
Postby Bitexion » Thu Mar 14, 2013 3:28 am
I use my Minibrute to play my modular synth with the CV/Gate outputs (using the 1v/oct input on each modular VCO), so it's sending out usual 1V/Octave voltages at least. Might be that your ARP has a different scaling though.
1V per octave means that there is 12 specific voltages(corresponding to notes, 12 notes in an octave) between 1-2 volts. It became the standard after a while, but early synths had different ranges, probably just to be uncompatible with their competitors.
Bitexion
Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Postby Blue Monster 65 » Wed Dec 11, 2013 1:33 pm
Ummm ... I do NOT want a video from AG, demonstrating that! ^ :shock:
Muhahahahahahahahaha!
Blue Monster 65
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 1 guest
