If you could design the perfect synth
xanadu97
Gear: DIY Modular
Monotron
Post by xanadu97 » Mon Apr 08, 2013 3:11 am
What would it be? How many oscillators? What kind of filter(s)? Polyphony? Modular, semi-modular, not modular (is there a name for that?), etc.
Z
Re: If you could design the perfect synth
Post by Z » Mon Apr 08, 2013 4:05 am
There never will be a perfect synth. I rather like have a few synths that excel in different areas.
xanadu97 wrote:not modular (is there a name for that?),
Hardwired
Hybrid88
Post by Hybrid88 » Mon Apr 08, 2013 5:53 am
For me the original V-Synth comes as close as one can to a perfect synth, although there's still things I'd change about it.
ravenmek
Post by ravenmek » Mon Apr 08, 2013 6:55 am
a 4 digital OSC (wavetables, samples, FM, even with a joystick for vector synthesis) with analog SVF filters (8 for polyphony), distortion, 4 ADSR envelopes, 3 LFOs (including S&H). At the end, an analog chorus and spring reverb for the solos. A big ribbon controller, CS80 style, a XY pad for parameter controlling, and a trigger button for one of the envelopes). Poly AT is a must!!! and instead of a pitch wheel, a pitch stick like the Nord keyboards.
Dr. Phibes
Post by Dr. Phibes » Mon Apr 08, 2013 7:11 am
Something that unfailingly makes my balls almost vibrate out my scrotum.
ppg_wavecomputer
Band: ['ramp]
Post by ppg_wavecomputer » Mon Apr 08, 2013 1:06 pm
Monophonic or polyphonic, wouldn´t matter as they would use the same architecture anyway:
- three LFOs, one for global modulation (vibrato etc.), two more elaborate (sync, reset, variable frequency ranges, voltage-controllable)
- three VCOs with two linear and two exponential FM inputs, PWM/phase modulation by various sources, hard sync, output of each VCO routable to various VCFs/resonators via potentiometers
- Noise, sample & hold (with various inputs and clocks, think ARP Odyssey)
- Ringmodulator (various input sources, level controllable using LFOs and/or envelopes), output routable to various VCFs/resonators
- Multimode VCF: switchable 12/18/24 dB response, high/band/lowpass, four individual FM control inputs, output switchable between VCF to Resonator or vice versa, direct output to VCA
- Resonator: think Synton Syrinx, output routable directly to output VCA, input either from VCF or output to VCF
- three DADSR envelopes, various triggering options, invertable, two with selectable loop modes and wide range (think Prophet VS)
- Stereo Output Stage with mixer section for VCF/Resonator output, VCO 1-3 sinewave straight to VCA (think Yamaha CS80), Amplitude modulation by various sources (envelopes and LFOs, VCO for overdrive), stereo panning modulation
- Five-octave keyboard with aftertouch and velocity (think Yamaha CS80), controlling various parameters.
Oh, and a sound to die for.
Stephen
https://ramp1.bandcamp.com/
Z
Post by Z » Mon Apr 08, 2013 2:09 pm
ravenmek wrote:a 4 digital OSC (wavetables, samples, FM, even with a joystick for vector synthesis) with analog SVF filters (8 for polyphony), distortion, 4 ADSR envelopes, 3 LFOs (including S&H). At the end, an analog chorus and spring reverb for the solos. A big ribbon controller, CS80 style, a XY pad for parameter controlling, and a trigger button for one of the envelopes). Poly AT is a must!!! and instead of a pitch wheel, a pitch stick like the Nord keyboards.
You have almost described the John Bowen Solaris. In my original post, I was going to state that the Solaris could be as close to a perfect synth as any. But as I stated before, I like having several synths with their own strengths.
Walter Ego
Band: 12"VS
Post by Walter Ego » Mon Apr 08, 2013 2:17 pm
Dr. Phibes wrote:Something that unfailingly makes my balls almost vibrate out my scrotum.
Yeah, I'm on board with that one. Screw the specs--on with the vibrating testes! :mrgreen:
Walter Ego
Bitexion
Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Post by Bitexion » Mon Apr 08, 2013 2:43 pm
ppg_wavecomputer wrote:Monophonic or polyphonic, wouldn´t matter as they would use the same architecture anyway:
Stephen
90% of that is in the Alesis Ion already.
ColorForm2113
Gear: tin cans and rubber bands
Band: Me twiddling in the corner...
Post by ColorForm2113 » Mon Apr 08, 2013 3:14 pm
If Hans Zimmers studio can be considered one synth, then it would be that lol.
I don't think I could design a reasonable "perfect synth" because I would just keep adding more and more to it. But I think it be something like the Schmidt
Kenneth
Real name: Kenneth
Gear: Nothing I own will make you jealous.
Band: KGB
Post by Kenneth » Mon Apr 08, 2013 4:38 pm
Stephen
The Ion doesn't have VCOs or VCFs or VCAs or VC ANYTHING. I think you missed that bit.
ravenmek
Post by ravenmek » Mon Apr 08, 2013 7:45 pm
I know! I would love to try one, but buying a 4000 dollars synth in my country is like saving 2 years of my salary :D
griffin avid
Post by griffin avid » Mon Apr 08, 2013 8:00 pm
My ultimate synth would be a single main body with interchangeable parts.
NOT a Modular, but have a modular design. Sort of like the Elektron drum machine with the keyboard you could slap on the side. Some synths have upgrade paths where you can add extra chips in for more voices....
Old drum machines used to have expandable memory and Roland (SRX) and some Studio Electronics pieces take cards. I would love to be into something that can be expanded over time.
It would then be customized by you and fit your system.
Live player? Probably gets the largest keyboard version and tons of polyphony.
Studio guy might want the drum pad section and NOT the step-sequencer option.
Someone else goes for the expanded RAM chips and Internal Hard Drive for sampling/storage.
So the basic body is a wide rectangle, 2 modules wide.
Sampler slaps on top.
Drum pads slap on left, step sequencer connects on the right...
If you go with 37 keys, there's room for another module on right or left.
But like a modular, you'd pick the internals when you order the main housing.
CS_TBL
Gear: All "In-The-Box"
Mainly FM8
Post by CS_TBL » Mon Apr 08, 2013 8:17 pm
I wouldn't design a synth, there's more than plenty of 'm.
I'd rather try to design a composing tool, some kind of advanced polyphonic arpeggiator, something like a desktop model you could integrate into a rack o' synths, something multi-timbral etc.
FM8 vids
bochelli
Gear: minimoog polymoog memorymoog multimoog micromoog minitmoog and tons more.
Post by bochelli » Mon Apr 08, 2013 8:30 pm
On style it has already been done , at least to me the 203a synthesizer from long ago Moog, something like that but modern and please please please no lit lit menu screen however small.
yamoto773
