Cleaning contacts on a Prophet600
phoenix224
Post by phoenix224 » Thu Jul 25, 2013 5:51 pm
Hello,
I bought a Prophet600 on eBay recently, and some of the keys don't play. If I press a non-playing key repeatedly, it eventually comes back to life.
I'm pretty sure the keyboard contacts need cleaning. I've seen two videos on youtube showing methods; one uses isopropyl only on the rubber parts, the other uses a pencil eraser on the rubber parts.
A friend recommends contact cleaner sparingly.
This is my prized synth, so I don't want to make the problem worse.
Anybody here have a proven method for doing this, or should I just take it to a technician?
Thanks.
calyx93
Gear: PPG Wave 2.2, Waldorf μWave x3, Roland JP6+V-Synth, SCI P5+600, Ensoniq SQ-80, Kawai K-3
Re: Cleaning contacts on a Prophet600
Post by calyx93 » Sun Jul 28, 2013 4:01 am
This is SO much easier than dealing with a Pratt-Read assembly - just thank your lucky stars it isn't a Prophet-5.
Just follow the instructions - it's really quite easy. Just go slow, be organized and be gentle with the rubber strips and keeping the contact board level/straight. Don't force anything too hard.
BTW - I used an eraser and swabs lightly damp with 91% isopropyl - first "erased" then cleaned with a couple swipes of the swab.
Took me about 1 hour when I did it - response was MUCH improved. Well worth the small time investment.
Casshern
Gear: Too much to list.
Ensoniq PARIS Pro V3.
Post by Casshern » Sun Jul 28, 2013 5:09 am
I used non lint leaving q-tips. Wiped twice w/ isopropyl, then dried by hand with another q-tip. I also did a wipe down of the board surfaces.
Result was like new!
I would be concerned about using erasers on the pads....
phoenix224
Post by phoenix224 » Mon Jul 29, 2013 2:38 am
Great. Thanks for the tips.
Wine Country instructed me to clean the contacts and rubber with soap and water. Helped a lot, but didn't solve the problem completely.
WC sell contact strip replacements, but it's $200 for the set. Still, good to know that option exists.
analoglsd
Real name: Lance
Gear: Buchla Music Easel, TE OP-1, Korg MS-20, Yamaha RS-7000, Effects Pedals
Post by analoglsd » Mon Jul 29, 2013 3:39 am
calyx93 wrote: BTW - I used an eraser and swabs lightly damp with 91% isopropyl - first "erased" then cleaned with a couple swipes of the swab.
+1
You don't need to be aggressive with the eraser, but from what I've been told, it's one of the least abrasive methods for cleaning contacts.(and it works like a charm)
I also use it on Pratt-Read buss bars, and have never had them come back to life so quickly.
