TTSH: Two Thousand Six Hundred (DIY Arp 2600 Clone)
Reginator
Gear: Korg: ARP Odyssey/MS-20 Kit, TTSH: Ver.1/Ver.2, ARP 1601 Sequencer (DIY), Minimoog Voyager, Waldorf Microwave Mk1 rev B, Roland: JP-8080/MC-505
Band: Reginator
Re: TTSH: Two Thousand Six Hundred (DIY Arp 2600 Clone)
Post by Reginator » Wed Jun 17, 2015 4:15 pm
Sure thing Bitexion! I still have them all plugged in so I'll patch up some adventurous sounds and hit record!
synthroom
Real name: Kirk
Post by synthroom » Wed Jun 17, 2015 8:04 pm
Bitexion wrote:My modular system has more or less the same components as a 2600..I should try to copy some 2600 patches onto it. I just have no idea how they were supposed to sound if I copy the patch sheets over so going blind is kind of pointless.
My ARP2600 came with a factory patch book, and when patching stuff up, I always wondered if how close I was getting to the intended sound. The 2600, or at least my experience with the 2600, was that there could be a bit of slop in what was drawn on the page verses what you'd get on the knob. Or slider, I should say.
I guess what I'm trying to say is it seems like there's more variability in the slider design going from a patchbook than say on a Pro One, with rotary knobs.
The only one that I really thought I nailed was the one labeled "Frankenstein", since I've heard that song so many times in my youth on the FM radio.
Reginator
Band: Reginator
Post by Reginator » Thu Jun 18, 2015 12:54 am
Here's a very-very simple demo of the TTSH and Odyssey, Voyager and MS-20 kit. The demo is quite clinical but you can hear the difference in each synth, especially the filters. I used the Type III filter on the Odyssey...maybe I should have tried the Type II? The MS-20 has a sound of it's own. I tried to duplicate the third patch on the MS-20 and failed horribly, but it sounded cool so I kept it. ;)
Sorry about the ear piercing square wave
edit - just found out how to share each track instead of playlist:
TTSH
Odyssey
Voyager
MS-20
seamonkey
Real name: Rick
Post by seamonkey » Fri Jun 19, 2015 2:27 pm
Very cool. To my ears the Voyager has a nice rounded sound as compared to a bit rawer wave.
Reginator
Band: Reginator
Post by Reginator » Fri Jun 19, 2015 8:02 pm
I agree with you about the Voyager. Moog is Moog, there's no denying that!
shaft9000
Real name: Dave
Band: moneymoneymoney
Post by shaft9000 » Sat Jul 11, 2015 9:46 pm
aren't AS modules based on EMS and Moog circuits?
A lot of the 2600 character comes from that pumping VCA, thickly OSC, the various gain stages, and it's layout.
From what I've heard in eurorack it's oakley VCA or nothing, and even then, the 2600 is a specifically 20V modulation range. There's no way to 100% duplicate the 'stretch' that occurs on the 2600 going from none to 10V max, without re-speccing everything.
Reginator
Band: Reginator
Post by Reginator » Sat Jul 11, 2015 10:55 pm
Here's a final TTSH clip for ideas of what it sounds like. It's a test I made to check the functionality of both my second TTSH (the Blue Marvin-ish) and ARP 1601 Sequencer clone which I just completed building. Both the Ver.1 and Ver.2 TTSH's and the ARP sequencer clone are the only instruments (no effects or onboard reverb). Took around a day and a half to record due to all the patching and around 5 min to mix (which is apparent by the low frequency heaviness). It wasn't meant to showcase my keyboard chops, only the sound of the TTSH and 1601 to make sure they were working ok.
Choronzon by Tangerine Dream was the on my mind and hence the test subject... Sorry about that Mr. Froese.
ppg_wavecomputer
Band: ['ramp]
Post by ppg_wavecomputer » Sun Jul 12, 2015 10:39 am
Past March, we celebrated a shootout between a TTSH and my later black/orange 2600. First, we tried to replicate slider settings and transferred them from the 2600 to the TTSH in order to figure out how accurately they could be copied... the usual ARP problem occured: All settings were rather "off" and required a lot of readjustment.
In course of the improvised jam session it became harder and harder to distinct between the two units as to which was playing what. The TTSH is pretty close to the 2600, and if I were hard-pressed to find a 2600 but lacking the funds, I'd opt for the TTSH.
Stephen
https://ramp1.bandcamp.com/
Post by meatballfulton » Sun Jul 12, 2015 1:10 pm
Bitexion wrote:I suppose they couldn't clone the boards too much or risk copyright infringements.
Late reply to this one but as companies who have had their stuff cloned by Behringer found out, there is no such thing (in the USA anyway) as copyrights on circuit designs and board layouts. Unless the circuit is patented it can be freely cloned with no consequences.
Strangely, the appearance of a product can be trademarked. For example, Fender and Gibson have trademarks on the design of their guitar headstocks to help combat copies by other manufacturers and Roland was able to get Behringer to cease and desist with copying the Boss stompbox enclosure but not the circuits inside.
Reginator
Band: Reginator
Post by Reginator » Thu Feb 18, 2016 7:15 pm
Cool stuff, Junkie XL used a TTSH and ARP 1601 sequencer clone in the soundtrack for Deadpool. Starting at 0:36.
