corndogssg wrote:I have a cs6x with a plg 150 an board in it. I read that it is basically half of an anx1 board so I am wondering if adding a 2nd an expansion board will give you a full fledged anx1 keyboard inside your cs6x or will it simply be a waste of the 2nd expansion slot???
PLG150-AN – Analog Physical Modeling Plug-in Board
Reproduce the fat and resonant sounds of vintage analog synthesizers. This board gives you a synth engine similar to the one featured in Yamaha's amazing AN1x analog physical modeling synthesizer. It provides a full array of classic synthesizer components, including fat resonant filters, LFOs, oscillator sync and FM, as well as distortion, 3-band EQ, arpeggiator and step sequencer. For even more expressive synthesis control, it features a powerful "morphing" function and programmable envelope generator with which you can freely draw your own custom envelopes for various parameters. With the PLG150-AN, creating the classic analog strings, brass and bass sounds of the '70s and '80s is incredibly easy, making it the ideal plug-in board for producers of contemporary pop/rock music or modern electronic dance music.
What is the Modular Synthesis Plug-in System?
Powerful Expansion Boards That:
Expand your sound generation capabilities
Increase your available polyphony
Give you more multitimbral parts and effects
Can be controlled from the host keyboard
Come bundled with PC software for detailed voice editing
Once a plug-in board is installed, you can directly access any of its voices and edit them from the front panel of the host synthesizer. You can also use a PC-based software editor (bundled with each plug-in board) to edit any of the voices in detail. Many voice parameters can be controlled by a MIDI sequencer, which enables you to record realtime edits, such as filter cutoff frequency and effect levels, for automated voice transformation during playback.
With the Modular Synthesis Plug-in System, you can customize your Yamaha synthesizer with the exact synthesis or processing power you need whenever you need it.
Note: Bundled editors are software plug-ins developed for XGworks sequencing software (Windows 95/98.
Offering new synthesis possibilities ranging from physical modeling to FM synthesis, these high-quality plug-in boards cater to specific synthesizer needs of professional users. Each plug-in board within the PLG150 Series comes bundled with special "Plug-in Voice" data that makes full use of the exclusive features found on the S80, S30, CS6x and CS6R synthesizers.
PLG150-AN– Analog Physical Modeling Plug-in Board
PLG150-PF– Piano Plug-in Board
PLG150-DX– Advanced DX/TX Plug-in Board
PLG150-VL– Virtual Acoustic VL Plug-in Board
Note: PLG150 Series plug-in boards and the PLG100-VH and PLG100-XG plug-in boards can be installed together in any combination in the S80 or CS6x/6R. Using previously released plug-in boards (PLG100-VL and PLG-DX), however, may result in 1) loss of edited voice data when the power is off, or 2) no sound output; therefore it is recommended to install the tuned-up versions (PLG150-VL and PLG150-DX) in these synthesizers.
Specs
Voices
Tone Generation Tone Generating Technology AN (Analog Physical Modeling Synthesis)
Multi Timbral Capacity 1
Polyphony Number of Polyphony (Max.) 5
Preset Number of Voices 256 Preset 128 User
