Oberheim OB-8 pot scanning resolution?
- Gear: Bass Station 2
Juno-6
Roland TR-606, Yamaha RX11
Fender Telecaster - Location: Norway
I'm looking at the OB-8 MIDI specification (here), and in there it is a bit map of the OB-8 patch format. It seems that all parameters adjustable with pots, such as filter cutoff, envelope attack time etc. are stored using only 6 bits (that is, in 64 steps). That seems really low to me. Wouldn't stepping be audible on some parameters? I haven't seen anyone mention this anywhere, so I'm wondering if patches are really stored that way or just transferred via MIDI that way. Does anyone know anything about this?
Re: Oberheim OB-8 pot scanning resolution
I don't hear stepping other than the obvious oscillator tuning knobs.
Juno-6
Re: Oberheim OB-8 pot scanning resolution?
Yeah, I haven't seen anyone mentioning it anywhere really, so I guess it's not really noticeable. I guess if this is the case, it's only really noticeable on the filter cutoff when resonance is at a high value, and maybe pulse width and sustain levels. Do you hear any stepping on them? The rest either affect very small ranges (so stepping wouldn't be very audible) or affect things like modulation depth or envelope times, which I guess are OK at 64 steps. The reason I'm asking is that I'm thinking about getting one, and I wouldn't want this to be an issue (seeing that no one really mentions this as a weak spot I guess it isn't though).
- Real name: John
- Gear: Roland JX-10/SH-09/MT-32/D-50, Yamaha DX7-II/V50/TX7/TG33/FB-01, Korg MS-20 Mini/ARP Odyssey/DW-8000/X5DR, Ensoniq SQ-80, Oberheim SEM
I think this is probably the important point - it's too easy to get caught up in technical wankery and forget about the main point: does it sound good? Obviously, since it's still sought-after and used to this day. This issue it may or may not have might make it less suitable for live-tweaking stuff, but as an instrument you only need to listen to some demos to know that it sounds pretty damn great.polyjuno wrote:(seeing that no one really mentions this as a weak spot I guess it isn't though).
- syntheticsolutions
- Real name: Ryan
- Gear: Rhodes 78 Mk2, Jupiter 4, Juno 6, VP-330, Prophet 600, Pro-One, CS-30, CS-50, Polysix, MonoPoly, MaxiKorg, 770, Opus 3, Odyssey mk3, Machinedrum
- Band: Lunar Modular
The parameters on my OB-8 are silky smooth, they feel just like analogue pots to me.
I think you would need an oscilloscope to see the stepping, it is absolutely nothing like the parameters on the prophet 600
Juno-6
Something like the Prophet 600's stepping (which I've heard examples of) was what I was picturing when I read it was 6 bits in the MIDI specs. I'm glad to hear it's not, or at least doesn't feel, like that. I guess patches are either stored with 6 bits per parameter then, or that only the six most significant bits are taken when a patch is transferred via MIDI. Both of these cases seem a bit weird, as there would be a loss of precision when storing or transferring a patch.
Good points. It's just the engineering/programmer part of me that is/was having an issue with this really.commodorejohn wrote:I think this is probably the important point - it's too easy to get caught up in technical wankery and forget about the main point: does it sound good? Obviously, since it's still sought-after and used to this day. This issue it may or may not have might make it less suitable for live-tweaking stuff, but as an instrument you only need to listen to some demos to know that it sounds pretty damn great.polyjuno wrote:(seeing that no one really mentions this as a weak spot I guess it isn't though).
- Real name: John
Yeah, I get you there, and it does seem odd that it would cut the resolution for either storage or transfer from what it actually uses, but whaddya gonna do, I guess...
