Studiologic Sledge - Hidden Parameters
Broadwave
Gear: Kronos 2-88, Fantom 6, System 8, MODX6, Behringer Odyssey, BroadWAVE ARP 2600EX, BroadWAVE Modular, BroadWAVE Sparta, BroadWAVE Minimoog.
Post by Broadwave » Tue Dec 10, 2013 1:02 pm
So many people keep comparing the Blofeld to the Sledge that, out of curiosity, I loaded up a Blofeld CC editor using Reaktor to see if anything would happen on the Sledge…
So far, I've found a couple of things of interest :)
You can access the extra filter modes:
CC No. 68
Notch 24dB (Data 7)
Notch 12dB (Data 8)
Comb+ (Data 9)
Comb- (Data 10)
PPG VCF (Data 11)
You can also put the Sledge into Unison Mode:
CC No. 99
Poly Mode - No Unison - as on front panel (Data 0)
Mono Mode - No Unison - as on front panel (Data 2)
Poly Unison - Uses 2 Voices (Data 16)
Poly Unison - Uses 3 Voices (Data 32)
Poly Unison - Uses 4 Voices (Data 48)
Poly Unison - Uses 5 Voices (Data 60)
Mono Full Unison (Data 127)
Unfortunately there is no Unison Detune… But you can set LFO 1, 2 or the Mod Wheel to a slow Sine or Triangle and add a touch of depth to detune.
That's all I've come across at the moment, but I'm looking into the SYSEX side of things…
Sir Ruff
Band: Ruff in the jungle
Re: Studiologic Sledge - Hidden Parameters
Post by Sir Ruff » Tue Dec 10, 2013 7:44 pm
Very cool you discovered that! :ugeek:
Do you even post on vse bro?
natrixgli
Gear: USB Hub, Pedalboard, Keyboard Stand, and many cables.
Band: Suboscillator
Post by natrixgli » Wed Jun 25, 2014 3:02 am
Hi -
I know this is an old post, but I was testing out parameters from the Blofeld manual, and found another one:
CC# 62
Noise Colour (0-127)
I was hoping to access LFO sync on #17 / #21 but they didn't work. (It did something, but nothing desirable...)
calaverasgrande
Band: N.S.V.
Post by calaverasgrande » Wed Jun 25, 2014 5:54 pm
natrixgli wrote:Hi -
CC# 62
well if it doesn't sync to midi than it IS a genuine Blofeld!
Infinity Curve
Real name: Cody
Gear: SH101, Monomachine, Machinedrum, Analog Four, lots of eurorack
Band: Infinity Curve
Post by Infinity Curve » Wed Jun 25, 2014 5:59 pm
CC# 62
:lol:
natrixgli
Band: Suboscillator
Post by natrixgli » Fri Jun 27, 2014 10:12 pm
calaverasgrande wrote:well if it doesn't sync to midi than it IS a genuine Blofeld!
Germans & Italians come together to build a synth; what could possibly go wrong? :lol:
No, the more I play the Sledge the more I realize how brilliant and underappreciated it is. Sure it's not as flexible and fully featured as a blofeld, but having all of it's controls exposed right on the front panel makes me far more likely to come up with interesting sounds.
Anyway I was hoping to sync the LFOs to each other, not MIDI. It sounds odd when the LFOs are all out of phase at low speeds.
Broadwave
Post by Broadwave » Sat Jun 28, 2014 10:10 am
A quick update... Studiologic are releasing V.2 firmware "Sometime soon".
Hopefully it will sort out some of the bugs, but... Studiologic are adding the Blofeld's SL License, and as far as I'm aware, It's a free update! ;)
Vid here, but in Italian only, I'm afraid.
natrixgli
Band: Suboscillator
Post by natrixgli » Sat Jun 28, 2014 4:42 pm
Kronik wrote:A quick update... Studiologic are releasing V.2 firmware "Sometime soon".
I got a response from them via email stating that it should be out sometime in September.
Broadwave
Post by Broadwave » Sun Jun 29, 2014 1:25 pm
natrixgli wrote: I got a response from them via email stating that it should be out sometime in September.
That's good to know... Thanks.
calaverasgrande
Band: N.S.V.
Post by calaverasgrande » Sun Jun 29, 2014 4:39 pm
will they ever come out with a honeydew or watermelon version? Not a fan of the cantaloupe.
zaphod betamax
Post by zaphod betamax » Wed Jan 13, 2016 3:23 am
You don't need the cc out of midox either. The Blofeld will send these out (keyboard version only)
So, when you select the comb filter for example, it will select it on the Sledge, or if you select the PPG filter
on the Blokeys, so goes the Sledge.
YMMV.
Mark Pigott
zaphod betamax
Post by zaphod betamax » Wed Jan 10, 2018 3:19 pm
If you cross reference the cc99 on a Blofeld you see it is FilterEnvSustain2.
As this is a =127 data entry with the encoder, you can enter in the above number
with your Waldorf Blofeld keyboard via MIDI OUT to MIDI IN on the Sledge.
I find Data@16 (unison2) to yield some interesting phasing when a slow LFO is
applied to pitch with a slow speed and a+3 amount.
