BCRM50 (Behringer BCR2000-Based Editor for Yamaha RM50)
Postby evanlong » Sun Jan 26, 2014 5:43 am
I've completed the first round of work on a set of SysEx files designed to make a BCR2000 and a Yamaha RM50 drum synth compatible for editing purposes. What you get with this system is an RM50 which is customized to have 8 drum kits of 16 notes each and a BCR2000 which can edit two of these kits at a time down to pretty fine details. (Unfortunately not all of the RM50's parameters can fit on the BCR's 50-some knob array, but I've included those which I feel to be the most important.) There are more details in the release notes in the ZIP file, but basically you get 8 GM-compatible percussion kits using all eight of the RM50's audio outputs and including kick, snare, side stick, clap, three toms, hi-hat (open, closed, and pedal), ride and ride bell, cowbell, and two crash cymbals.
In this release, although the RM50 will be set up for all 8 kits/128 user voices (I-MX bank), I have only included a SysEx file for the first editor for the BCR (presets 1-16 -- one for each note in the kit). Eventually I will get around to setting up and sharing the BCR editors for kits 2-8, but it's a very tedious and time-consuming process to program them, and I figured that having at least one kit editor fully up and running would be worth an early release.
I have quadruple-checked the RM50's settings, and I think everything is in order per the specifications I laid out for it. I used RM50 Manager as well as the front panel of the box to set up the kits and voices, and it worked pretty well, but I did notice a few bugs even after I thought I'd finished, so if anyone uses this system and notices any bad settings, please let me know. Likewise with the BCR2000, if anyone notices a knob that doesn't do what it's supposed to, please let me know, and I'll publish a fix when I get a chance.
Hopefully others will find this useful! Again there are more details in the release notes, but the RM50 is a powerful ROMpler that can do some pretty interesting sounds. With the BCR's knobs so set to control it and dig into its brain, I think it will be that much easier to explore its full potential.
Link: http://evanlong.net/wp-content/uploads/2014/01/BCRM50.zip
evanlong
Re: BCRM50 (Behringer BCR2000-Based Editor for Yamaha RM50)
Postby evanlong » Fri Jan 31, 2014 5:14 am
Here's a photo of the BCR2000 labeled with the RM50 tags. You can't see it in this picture, but when you turn a knob to alter a value, the LCD ring around it lights up to show what value you've entered relative to the min and max values.
evanlong
Postby evanlong » Wed Apr 09, 2014 4:03 am
v1.1 is now available:
get the current version of BCRM50 here
Version 1.1 corrects some minor errors that were present in version 1.0 and makes a few other changes:
1) Wave Number now stops at 132
2) Balance now stops at 128
3) Pitch EG Level now stops at 144
4) LFO Speed now goes all the way to 99
5) The enclosed RM50 device definition files for BC Manager have been updated to reflect the above
6) Documentation has been collapsed into one text file
v2.0 will have the editors for kits 1 and 2 as well as a few other improvements. ETA is... a month? We'll see.
evanlong
Postby evanlong » Thu Apr 24, 2014 5:23 am
Here's v2.0 of the BCRM50 project (same link as before, updated file package):
As promised, this version fills the entire memory of the BCR2000 by including voice editors for all of I-MX voices 1-32. It also upgrades the RM50's configuration by adding 24 new "double kits" to user kit slots 9-36.
Therefore, the BCR2000 can now be used either to edit kits 1 ("BCRM50 1," comprised of I-MX voices 1-16) and 2 ("BCRM50 2," comprised of I-MX voices 17-32) separately or, by using the double-kit (two voices per note instead of one) in user kit 9 ("BCRM50 1+2," comprised of I-MX voices 1/17, 2/18, 3/19, etc.), simultaneously. Users wishing to save their results can copy them to the higher-numbered voice slots (33-128) using the front panel, then resume editing the lower-numbered voices.
We'll see how this one works in terms of its workflow. If it works well, I may not bother making live editors for the voices of kits 3-8, relying instead on the voice-copying method. Let's hope it does work well because the tedious process of creating these kit editors is definitely not my favorite activity.
evanlong
Postby evanlong » Tue May 20, 2014 10:31 pm
Here are some examples of sounds I've made on the RM50 using this editor.
http://evanlong.net/sound-examples-of-yamaha-rm50-using-bcrm50-editor/
evanlong
Postby Anarkand » Wed Feb 21, 2018 1:57 am
amazing stuff - will def. look into this
Anarkand
Users browsing this forum: Bing [Bot] and 19 guests
