Korg to release ARP Odyssey
- micahjonhughes
Re: Korg to release ARP Odyssey
Korg is a Japanese company with US division. You would not have any problem contacting Korg. Also, it looks like the Odyssey comes with a one year warranty. I see some online retailers are offering a 2-year warranty.
Just curious, does the Odyssey have surface mount components or through hole?
- adamstan
- Real name: Adam
- Gear: Yamaha 2xDX7II|QY-70|PSR-S750|PSR-2000|TYROS|Electone D85|Electone E50
B5 DIY polysynth
KORG Poly61
Vermona DRM
Solton Programmer 24
LEMA EDD-5 - Location: Poland
Surface mount, as can be seen here:
Man with a tape recorder | Living in the '80s
Re: Korg Arp Odyssey
A guitar stand. Okay.Platner wrote:It matters because I recently bought a guitar stand that was made in China and I had some concerns about build quality and I wasn't able to get in touch with the company in the US selling it. Before I purchase something in this kind of price range I like to determine how easy it is to get it fixed if it should break.monolith wrote:China. Why does it matter?
Does Korg stand behind this product?
Does Korg stand behind this product? The box mine came in has a big korg sticker with an Aussie flag on it that says '3 year warranty', so I'd say they do. Also, having previously worked for the Australian distributor of Korg products I've found no problems with the addressing warranty issues - which weren't all that common anyway.
- Automatic Gainsay
- Real name: Marc Doty
- Gear: Minimoog, 2600, CS-15, CS-50, MiniBrute, MicroBrute, S2, Korg MS-20 Mini, 3 Volcas, Pro 2, Leipzig, Pianet T, Wurli 7300, Wurli 145-A, ASR-10, e6400.
- Band: Godfrey's Cordial
At Gearfest, I saw Dave Smith mock everyone who is concerned about surface-mount technology, and watched Tom Oberheim and Roger Linn laugh along.
After that, I kind of want to never hear about it again.
- Stab Frenzy
Whenever this topic comes up I try to find the photo someone took of cutting open a through hole ceramic cap to reveal that it's just an SMT cap with leads attached and dipped in epoxy, but it's a hard photo to find.Automatic Gainsay wrote:At Gearfest, I saw Dave Smith mock everyone who is concerned about surface-mount technology, and watched Tom Oberheim and Roger Linn laugh along.
I own a lot of modules, both SMT and through hole, and there is no correlation between sound quality and construction methods used.
- No Longer Registered
I thought the only difference would be that if you knocked a pot hard that was surface mounted then it's got something solid to hold it. If it's through hole then it's got a little give and if the knock was hard enough it could be enough to break, rip the board/trace etc etc
I dunno though, and I don't really care
- Bitexion
- Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
People seem to think they have to be flimsy because they're so small, but really it's the same circuitry and it's mounted closer to the PCB so it's even more secure.
- Hybrid88
- Gear: V-Synth, and other stuff...
Ok, it's probably pretty pointless trying to argue about it, you guys all seem to know everything already. But the fact is if you take something in to be repaired that is SMD construction the tech will most likely not be able to do a component level fix. Let along a diagnosis. I don't know about you but I'd rather replace one component than a whole PCB.Automatic Gainsay wrote:At Gearfest, I saw Dave Smith mock everyone who is concerned about surface-mount technology, and watched Tom Oberheim and Roger Linn laugh along.
Sure there's a warranty on most stuff now...
SMD is pretty reliable, but when it does fail it will brick a synth.
- pflosi
You can bolt pots to the panels with SMT too you know... And you can have them PCB-mounted only with thru hole if you want. Doesn't have anything to do with SMT vs thru hole.zoomtheline wrote:I thought the only difference would be that if you knocked a pot hard that was surface mounted then it's got something solid to hold it. If it's through hole then it's got a little give and if the knock was hard enough it could be enough to break, rip the board/trace etc etc
- micahjonhughes
My question regarding SMT or through hole was directed at ease of future in home repairs after the warranty is long expired. I get most of my gear used, slightly abused and needing some mending.
Clearly SMT is the way synth manufacturers are going. I'll just need to get some new soldering skills to keep up. I can't think of any reason SMT would sound different.
- Hybrid88
Yeah but who does? Seriously. I guess it's a separate issue but I can't think of any manufacturers that bolt SMD pots to the front panel. Plastic cased/shafted pots don't make the problem any better either.pflosi wrote:You can bolt pots to the panels with SMT too you know...zoomtheline wrote:I thought the only difference would be that if you knocked a pot hard that was surface mounted then it's got something solid to hold it. If it's through hole then it's got a little give and if the knock was hard enough it could be enough to break, rip the board/trace etc etc
ah, I see, guess i'm out of my tech depth ha
- pflosi
Cwejman, Synthesis Technology, just to name two off the top of my head.Hybrid88 wrote:Yeah but who does? Seriously. I guess it's a separate issue but I can't think of any manufacturers that bolt SMD pots to the front panel. Plastic cased/shafted pots don't make the problem any better either.pflosi wrote:You can bolt pots to the panels with SMT too you know...zoomtheline wrote:I thought the only difference would be that if you knocked a pot hard that was surface mounted then it's got something solid to hold it. If it's through hole then it's got a little give and if the knock was hard enough it could be enough to break, rip the board/trace etc etc
- Hybrid88
mm a couple of low volume modular manufacturers. I'm more thinking of more mass-produced gear, I suppose it saves the big producers time and money not to screw them on.pflosi wrote:Cwejman, Synthesis Technology, just to name two off the top of my head.Hybrid88 wrote:Yeah but who does? Seriously. I guess it's a separate issue but I can't think of any manufacturers that bolt SMD pots to the front panel. Plastic cased/shafted pots don't make the problem any better either.pflosi wrote:You can bolt pots to the panels with SMT too you know...
- pflosi
Well that's where the quality is atHybrid88 wrote:low volume modular manufacturers
