Korg DSS-1 self-oscillating filters
Postby PolyMTL » Thu Feb 27, 2014 5:03 pm
Hi! I've been using the Korg DW-8000 (a lot) for two years and became big fan of it. For that reason, I always kept an eye opened for a DSS-1 in the local ads knowing it was even more awesome. And I finally found one! It's as cool as I thought it would be. Best way I found so far to get PPG-esque tones and am very satisfied with it.
But I'm disappointed by only one thing: the VCFs would not go into self-oscillation the same way they do on the DW-8000 (which does it in a wondeful, progressive way). Apparently both synths use the same custom KORG chips - makes sense to my ears anyway. I've read there's a way to ajust trim pots on the board in order to make them scream but no precise info about it. So I'm just wondering if any of you have ever done that adjustment on theirs? Is it risky to give it a try? Thanks ;)
PolyMTL
Gear: AKAI AX73
ROLAND JUNO-6
YAMAHA CS-15
YAMAHA CS-50
Re: Korg DSS-1 self-oscillating filters
Postby rhino » Thu Feb 27, 2014 7:41 pm
You can try adjusting the resonance trim pots. They are on the analog board and are labled 104 thru 804. (that is: 104, 204,304 etc.)
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Postby PolyMTL » Thu Feb 27, 2014 8:38 pm
Thanks so much rhino, I'll give it a shot for sure. I see you own one too: have you made the adjustments to yours?
PolyMTL
Gear: AKAI AX73
ROLAND JUNO-6
YAMAHA CS-15
YAMAHA CS-50
Postby FreshTrooperXBL » Sun Apr 27, 2014 3:21 am
Did any of you guys try changing the resonance pots on the DSS-1? I just bought a "broken" DSS-1 from a dude in Los Angeles. Turns out just a few keys are missing, slider caps missing, screws mostly gone, and ribbon bands disconnected. Now I have two giant beasts that fully work haha. I think the floppy drive in #2 still works!
I'm going to find those pots and try different settings tonight (hopefully)!
FreshTrooperXBL
Postby Aaron2 » Sun Apr 27, 2014 4:41 am
I used to own one of these. Heaviest synth ever made!
Aaron2
Real name: Aaron
Gear: Pioneer: Toraiz SP-16
Elektron: AK, AR, MnM, MD, OT
DSI: Evolver, MEK, P08, Pro2
Korg: Arp Odyssey
Waldorf: Blofeld Keyboard
Users browsing this forum: No registered users and 23 guests
