is it normal for a power supply to buzz? (not through audio)
vuuv
Post by vuuv » Sat Mar 01, 2014 5:56 am
I have a jx3p and an alpha juno 2 that have landed in my lap recetly, and both of them make an electrical buzz/hum when turned on -- not thru the audio outs, but from the power supply, inside the synth. is that normal for gear of this age? or should i be worried about a small explosion?
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: is it normal for a power supply to buzz? (not through au
Post by rhino » Sat Mar 01, 2014 7:00 am
Welcome to the board!
SOME small hum is generaly ok, but check:
1) synths are set for the correct voltage
2) rectifier diodes
3) filter caps - look for leakage
4) on the JX3p, check that the transformer has not pulled loose fron the wooden base plate of the synth.
- Confucius
vuuv
Post by vuuv » Sat Mar 01, 2014 9:35 am
i'll definitely look at the tranformers -- the jx3p is far less noisy and is otherwise in excellent shape, but the noisy juno 2 is being loaned to me (indefinitely i guess) and has seen better days... broken keys i can fix no problem, but diodes and the rest might be a bit beyond my skills right now :) anything beyond unscrewing things is beyond me!
Post by Stab Frenzy » Mon Mar 03, 2014 1:26 am
It's the AC in the transformer creating a magnetic field that vibrates the steel in the chassis at your AC frequency. It's not a problem.
Psy_Free
Gear: Synths 'n' stuff.
Band: Klangzeit
Post by Psy_Free » Mon Mar 03, 2014 10:28 am
My JX-8P has buzzed like a nest of furious hornets since I got it years ago & hasn't blown up yet, so I wouldn't worry too much.
Bandcamp 1
Bandcamp 2
Soundcloud
vin14
Band: oddball
Post by vin14 » Mon Mar 03, 2014 11:41 pm
My juno 106 has done that since i got it in the 90s, though my alpha juno 1 hasn't.
pmh
Real name: Phil
Post by pmh » Mon Mar 03, 2014 11:55 pm
As already mentioned, some transformers are prone to buzzing, which will be at the frequency of the mains.
If this doesn't appear in the audio output then there is nothing to worry about.
You can get rubber mounts for transformers, which can/help to reduce the hum, but it's extra effort for nothing really.
I have had to strip our house alarm down, in the past, as the hum from this used to annoy me at night.
That said, I doubt you sleep with the Juno ........ or do you :mrgreen:
Kind regards,
Phil
gmeredith
Band: Warning Will Robinson
Post by gmeredith » Tue Mar 04, 2014 12:56 am
The Yamaha TX81z are renowned for their acoustic transformer buzz. It's not a fault issue - just poor shielding and mounting design. Yanaha actually issued a service bulletin for factory recalls for it. The notes told the service technician to do the following modification:
Altitude from this forum also mentioned it:
http://www.vintagesynth.com/forum/viewt ... 35#p564254
So you could probably apply the similar mod to your transformer.
Cheers, Graham
vuuv
Post by vuuv » Tue Mar 04, 2014 2:33 am
thanks everyone! i'll just deal with it :)
and pmh, i mean, technically what i have now is the bedroom studio thing happening, so it's all within reach from my bed.....
Post by Stab Frenzy » Tue Mar 04, 2014 3:57 am
vin14 wrote:My juno 106 has done that since i got it in the 90s, though my alpha juno 1 hasn't.
That's cause the Alpha Juno is made from plastic not steel.
