Arturia Beatstep - First impressions...
Broadwave
Gear: Kronos 2-88, Fantom 6, Novation Summit, Modal Argon8X, Yamaha MODX6, Behringer Odyssey, Behringer Poly D, BroadWAVE ARP 2600EX.
Post by Broadwave » Wed Apr 16, 2014 8:30 am
It arrived yesterday :)
EDITED:
As far as the sequencer part of it goes there ARE a few issues. The lowest possible CV output from the Beatstep is 2 volts (technically speaking, it really should be 0v), so I'm having to transpose everything down 2 octaves via my modulars CV mixer.
The gate output is 7.88 volts, but that has to be amplified to trigger the 2600 which needs 10 volts + (strange… they don't seem to have to do that on their demo vid!)
I noticed that the 1v/Oct CV output was also out of kilter, so I took a risk and completely voided the warrantee by taking the back off and readjusting the scale trimmer - luckily there is one, but at least it now outputs the correct 1V/Oct and I don't have to recalibrate 15 (!!!) VCOs :)
I can confirm that the Beatstep WILL act as a basic MIDI to CV converter via USB from your DAW. As I couldn't find any mention of this on Arturia's site, that's turned out to be a nice unexpected bonus.
Apart from that, it's quite good (and fun) but it would be nice if they can sort out the 2 volt offset via an update.
pflosi
Re: Arturia Beatstep - First impressions...
Post by pflosi » Wed Apr 16, 2014 9:02 am
Kronik wrote:As far as the sequencer part of it goes there ARE a few issues. The overall CV output is too high by 3V. I'm having to transpose everything down 3 octaves via my modulars CV mixer.
Noooooooooo :banghead: That might just be the deal breaker for me - I could live with no proper sync integration (unless you use a computer), but sequencers that are not at 0V for the minimum setting annoy the h**l out of me. Oh well, nice try Arturia. :roll:
Broadwave
Post by Broadwave » Wed Apr 16, 2014 9:15 am
pflosi wrote:but sequencers that are not at 0V for the minimum setting annoy the h**l out of me. Oh well, nice try Arturia. :roll:
I've been double checking everything… My mistake, it's only out by +2 volts (not 3 as in my original post :oops:) Still a bloody PITA!
I just wish manufacturers would let "real world" users try their equipment before release to clear daft things like this up first.
I've just tried it on my Minimoog (gate via an S-Trig converter), but even with the VCOs set at 32' the output from the Beatstep is too high, so you can't get "bass" from it! :roll:
pflosi
Post by pflosi » Wed Apr 16, 2014 9:43 am
Kronik wrote:Still a bloody PITA!
Exactly. :cry:
calaverasgrande
Band: N.S.V.
Post by calaverasgrande » Wed Apr 16, 2014 7:39 pm
damn, I was just about to pull the trigger on it.
The last thing I need is another piece putting out the wrong CV.
Bitexion
Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Post by Bitexion » Wed Apr 16, 2014 9:36 pm
That is VERY strange. Are you sure there isn't some switch you've tripped on yours? Or some menu that says "+2V increase" or something?
Arturia can't have messed up so badly. Like if my modular's sequencer transposed everything by two octaves. (It can, but not unless I tell it to)
Post by meatballfulton » Thu Apr 17, 2014 11:43 am
What's the maximum CV voltage?
The manual says range should be 0-7V...if it's starting at 2 V, can you get it to drive more than 7V?
Have you tried the Transpose settings to see how they affect the CV?
Took a quick look at the Arturia forums, others reporting the same pitch CV issue.
Broadwave
Post by Broadwave » Thu Apr 17, 2014 2:00 pm
I'm sat here with my trusty multimeter, y'all ready for this…
Sequence encoder at default "centre" (yeah, it's an encoder, but you get my drift) outputs +4 Volts
Sequence encoder at minimum outputs +2 Volts (down to +1 Volt with Transpose Down - Definitely not 0V!)
Sequencer encoder an maximum outputs +6 Volts (up to +7 Volts with Transpose Up)
NB. The transpose function cannot be saved as part of the template, and there's definitely no function or switch to accidentally shift the output voltage level ;)
So there you have it - Arturia sort of messed up.
Something else I noticed… When you transpose sequences live, via a MIDI keyboard, as soon as you let the key go the sequence jumps back to default (For example: If you create a sequence in "C" and transpose it down to "A", as soon as you release the key, the sequence jumps back to "C"… no latch function :cry: )
Also, you can't externally transpose lower than MIDI C2 (again +2V).
But I've just had a thought - We're dealing with digital here, powered from 0-5V via USB. Somewhere along the line Arturia must have decided on a happy medium (literally) to decide where the central voltage is to allow the sequence to be programmed up or down (in the Beatstep's case, that's +4V). Analogue sequencer pots generally have a centre position of 0V allowing for a -Ve and +Ve voltage swing... Beatstep can't do this, although it would help a little if the lowest voltage was 0 - Maybe they couldn't do that for some reason due to the design?
I think we'll just have to live with it.
But, I've still no idea why it won't directly trigger the ARP… I shoved an LFO square wave (Attenuated to 8V) into the ARPs S/H Gate socket and it fired the EGs with no problem. The Beatstep gate out is 8V but it doesn't work - Weird!!!
Ned Bouhalassa
Gear: A new German poly monster, an old BBC Brit, a vintage poly beast from NY, someone's older relative from NC, and Eurolicious patchables.
Post by Ned Bouhalassa » Thu Apr 17, 2014 3:03 pm
Thanks for sharing your tests! I think I'll wait for version 2.
My music: soundcloud
My analog synth videos nedonanalog
More about me: Mostly Human Music
calyx93
Post by calyx93 » Thu Apr 17, 2014 4:19 pm
thanks for the details - gonna have to pass on this one too.
pflosi
Post by pflosi » Thu Apr 17, 2014 4:33 pm
Strange s**t... It can't be an accident with the +2V thing, I'm sure it has a reason. But it sucks still.
About triggering the ARP, maybe the Beatstep gate is too short...?
calaverasgrande
Band: N.S.V.
Post by calaverasgrande » Thu Apr 17, 2014 5:04 pm
Kronik wrote: But, I've still no idea why it won't directly trigger the ARP… I shoved an LFO square wave (Attenuated to 8V) into the ARPs S/H Gate socket and it fired the EGs with no problem. The Beatstep gate out is 8V but it doesn't work - Weird!!!
correct me if I am wrong but isnt the CV and gate brought out on a TRS to TSx2 pigtail?
Could this not be some issue with sharing a common ground?
Does the gate work when the kb CV isn't connected to the Arp?
smcumber
Post by smcumber » Thu Apr 17, 2014 6:13 pm
This seemed cool at first, but for some reason I didn't process that the knobs are encoders and there's no visual feedback at all. Eh, that sucks.
Broadwave
Post by Broadwave » Thu Apr 17, 2014 6:31 pm
calaverasgrande wrote: correct me if I am wrong but isnt the CV and gate brought out on a TRS to TSx2 pigtail?
OK, I'll correct you ;)
The CV and Gate are on separate 3.5 jack outputs, MIDI is via a 3.5 jack to DIN converter (supplied). Gate still not triggering if the CV is removed.
@pflosi - I've tried lengthening the gate time from the default 50% up to 99% (via the supplied software) makes no difference either - I've resorted to building a small op-amp booster on a piece of stripboard to put into the ARP (just after the S/H Gate jack). It should do the trick and hopefully not interfere with the pre patched S&H clock pulse - I'd love to know how they did it in their Promo Video… Witchery, probably ;)
calaverasgrande
Band: N.S.V.
Post by calaverasgrande » Thu Apr 17, 2014 6:40 pm
Okay I must have conflated two different products. I know there was some recent new gadget that did use pigtails for the CV/Gate. Maybe it was one of the Elektrons?
I wonder if their video was done on a prototype that differed from the shipping version?
Wouldn't be the first time a company has done that.
I can't say I am super disapointed. I rank this more as a fun gadget like the Volcas than as real tool.
Still, it would have been nice to add to an order from Sweetwater. :roll:
I'm still going for the Minibrute SE.
