MY KORG POLY 61 IS BROKE AND I'M SAD.
bedroomscience
Post by bedroomscience » Thu May 15, 2014 4:14 am
When a key is pressed, it plays the tone of the patch, but highly oscillated and glitchy. Could this be the symptom of a nearly dead battery? Have not serviced this synth since buying it used nearly 8 years ago. Worked perfectly a couple weeks ago.
Here is a sample of what it sounds like:
Rezisehtnys
Real name: Casey
Gear: Ensoniq VFX
KORG Monotron
KORG Triton
Peavey Fury 1992
Peavey KB-300
Peavey Milestone 1984
Roland JX-8P
Waldorf Micro Q
Yamaha KX5
Yamaha SY77
Re: MY KORG POLY 61 IS BROKE AND I'M SAD.
Post by Rezisehtnys » Thu May 15, 2014 4:30 am
I'd open it up and make sure the battery hasn't exploded, if it still looks ok you can check out the voltage with a multi-meter to determine if it needs replaced or not.
Synthetech
Post by Synthetech » Thu May 15, 2014 4:56 am
Sounds like battery acid....
Jabberwalky
Band: Variar
Post by Jabberwalky » Thu May 15, 2014 6:30 pm
Yep. As far as I can tell. The p61 battery issue is as common as it is on the poly6.
