diy synth kits?
pich
diy synth kits?
Post by pich » Thu May 15, 2014 11:21 am
Hi I've recently got in to this and as a beginner am keen to learn more, I've just got a drum machine to go with my volca bass and wanted to get a nice little synth to add to the set up, I've seen that you can get kits to assemble and would really love this, I just wanted to know if anymore knew of any good ones the I could buy and make? I don't want to spend loads atm because I've only just started.
Also I wild love some information too... like do you have to run your own sounds through the syntjs or do they produce there own sounds?
And if there is a good starter one that I could buy I might look into that like maybe the volca keys?
I see on YouTube these cool home made boxes that people make but am unsure what they are?
Sorry if I've offended anyone with my terminology but I've only just got into this.
Cheers
Re: diy synth kits?
Post by meatballfulton » Thu May 15, 2014 11:54 am
Take a look into Paia for starters.
Jabberwalky
Band: Variar
Re: diy synth kits?
Post by Jabberwalky » Thu May 15, 2014 6:35 pm
Check out the meeblip, shruthi, and go to synthrotek.
Europanaut
Re: diy synth kits?
Post by Europanaut » Thu May 15, 2014 7:23 pm
I've had good experiences with MFOS. (Music From Outer Space.)
Percivale
Gear: Blofeld, Juno-106, AN1X, MB-6582/SEQ V4, etc
Re: diy synth kits?
Post by Percivale » Fri May 16, 2014 2:56 am
Synthesizers are typically defined as electronic instruments that create sound, so by definition yes synths will produce sound, i.e. it has a sound engine (brain). They can be "told" to play via various methods of inputs, e.g. MIDI, CV/Gate, Keyboard and Drum Pads are some I can think of. Draw the distinction between a synth and an input-only controller, where the latter does not have a sound engine. Some synths can also process external sources of audio input.
Most DIY require solder work. May I suggest Mutable Instruments Shruthi-1. It makes a good start as it:
- is available!!
- allows user customisation
- is well documented/established
- provides choice of filter/card
- is not too costly
Have fun! 8-)
DX21
Real name: Fender
Gear: Yamaha DX21
Kawai K3
Band: AHHHH!?!!?
Re: diy synth kits?
Post by DX21 » Sat May 17, 2014 11:22 am
Get this, or a Duo or a Delay model, h**l all three.
Study These:
Mono
Duo
Delay
Study these as well:
www.korg-datastorage.jp/Manual/monotron_sch.pdf
http://www.korg.com/download/global/mon ... UO_sch.pdf
http://www.korg-datastorage.jp/Manual/m ... AY_sch.pdf
wire them together, add a piano input and there you go, you have a polyphonic analog synth with delay and filters that you built yourself.
~Playin' Those Big Fluffy Pads at the Crack o' Dawn~
Yamaha DX7 > Yamaha SY77 > Kawai K3 > PC via Roland UM-ONE Rev 1.
ellaguru
Gear: juno106 korg ms20 roland vsynth yamaha an200 yamaha tx81z boss sp303 boss sp505 roland sp606 roland mc909 zoom st224
Re: diy synth kits?
Post by ellaguru » Sat May 17, 2014 12:08 pm
DX21 wrote:Get this, or a Duo or a Delay model, h**l all three.
hey that's very interesting and, on paper, seems faisable for DIY/Benders noob...thanks for sharing; have you got some links on concrete examples of those finished projects, please?
madmarkmagee
Gear: King Korg
ESQ-1
Reface DX
Microbrute
Shruthi-1
Pittsburgh System-1
Juno 106 (needs work)
Re: diy synth kits?
Post by madmarkmagee » Sat May 17, 2014 1:49 pm
Yea check out mutable instruments, but be warned,there is always an inherent risk you may stuff up the build.
http://mutable-instruments.net/
ellaguru
Re: diy synth kits?
Post by ellaguru » Sat May 17, 2014 2:22 pm
madmarkmagee wrote:Yea check out mutable instruments, but be warned,there is always an inherent risk you may stuff up the build.
thanks.
however i'm searching specifically for that monotron+monotor+monotron+synth/piano/key toy etc hybrid monster project wich DX21 suggested...
Explorer
Gear: not enough space here
Re: diy synth kits?
Post by Explorer » Sat May 17, 2014 2:29 pm
http://www.elby-designs.com/contents/en ... ASM-2.html
This one got my attention a few months ago.
Very nice and big(6U),a little "expensive".But you will have fun building it,that's for sure.
madmarkmagee
Gear: King Korg
ESQ-1
Reface DX
Microbrute
Shruthi-1
Pittsburgh System-1
Re: diy synth kits?
Post by madmarkmagee » Sat May 17, 2014 2:45 pm
thanks.
I think Dx21 may be having some fun with people...
trollololololol
DX21
Real name: Fender
Gear: Yamaha DX21
Kawai K3
Band: AHHHH!?!!?
Re: diy synth kits?
Post by DX21 » Sat May 17, 2014 10:09 pm
thanks.
trollololololol
trollololololol
Suped up:
Ghetto Upgrade
Used as Intended:
ellaguru
Re: diy synth kits?
Post by ellaguru » Sun May 18, 2014 10:04 am
hey DX21, thanks!!
i'm very impressive on how it sounds good that "ghetto upgrade". And the "megatron" too...
i have an original ms20; i know, it's a very different machine to be compared to those two, but, damn, they both sound cool to my ears...i'll check on the net if i find some specifications about them, i feel that they're not made by noob indeed, but...
sneakthief
Re: diy synth kits?
Post by sneakthief » Sun May 18, 2014 12:44 pm
Some random DIY kit info:
6-Note digital polysynth kit - http://www.audiothingies.com/
FM Synth kit - http://ixox.fr/preenfm2/
EDP Wasp clone kit - http://www.elby-designs.com/contents/en ... Clone.html
Lush One kits - http://lushprojects.com/store/
sneak-thief: raw electrofunk!
http://sneak-thief.com
sneakthief
Re: diy synth kits?
Post by sneakthief » Sun May 18, 2014 12:46 pm
Explorer wrote:http://www.elby-designs.com/contents/en ... ASM-2.html
The ASM-2 is a mother of a build. Took me 400 hours to understand what features I wanted, plan the layout then actually build it: http://sneak-thief.com/modular/
