Minimal wave tips??? Ensoniq, Moog, E-mu
bassplayer1980
Real name: Paul
Gear: Moog lp, Ensoniq ESQ-1, E-mu command station, Mackie mixer 402 vlz3.
Post by bassplayer1980 » Fri Jul 25, 2014 2:05 am
Hi, I'm new atthis synth forum. My name is Paul. I have 3 synths, Ensoniq ESQ-1 , Moog little phatty, E-mu Command station. and I plan to play minimal wave synth and I want some tips from the forum. the esq and the e-mu can make sequences and the moog little phatty has a good monophonic arpegiattor for bass. Any help is gladly appreciated.
Rick N Boogie
Real name: Alan
Basses/synth fx galore
Band: no.one.won
Re: Minimal wave tips??? Ensoniq, Moog, E-mu
Post by Rick N Boogie » Fri Jul 25, 2014 2:32 am
Maybe I'm just unaware, but what is "minimal wave synth"?
Bassist, synth junkie
bassplayer1980
Real name: Paul
Post by bassplayer1980 » Fri Jul 25, 2014 4:15 am
this is an exampleof whatI'm looking for:
bassplayer1980
Real name: Paul
Rick N Boogie wrote:Maybe I'm just unaware, but what is "minimal wave synth"?
Aaron2
Real name: Aaron
Gear: Pioneer: Toraiz SP-16
Elektron: AK, AR, MnM, MD, OT
DSI: Evolver, MEK, P08, Pro2
Korg: Arp Odyssey
Waldorf: Blofeld Keyboard
Post by Aaron2 » Fri Jul 25, 2014 7:47 am
bassplayer1980 wrote:Hi, I'm new atthis synth forum. My name is Paul. I have 3 synths, Ensoniq ESQ-1 , Moog little phatty, E-mu Command station. and I plan to play minimal wave synth and I want some tips from the forum. the esq and the e-mu can make sequences and the moog little phatty has a good monophonic arpegiattor for bass. Any help is gladly appreciated.
First off, welcome to the forum.
You probably have all the gear you need right now to play anything you want. Just start making the sounds you want to make. I don't think there's a ready-made, minimal-wave-in-a-box synth that will fulfill your every wish.
To me, a synth is like a hammer. It's just a tool. With a hammer, you can build a house with it, or a fence, or a dining-room table. Or you can squash a bug with it. It has many uses. It's up to you to decide what you want to make it do.
bassplayer1980
Real name: Paul
Post by bassplayer1980 » Fri Jul 25, 2014 11:16 am
thanks, :) but i was searching for some tips, like how to use all these synths at the same time. I was thinkin on use the e-mu to make drum patters in 1/4 and then play the moog for basslines because itscool arpeggiator and use the ensoniq to make synth sequences to cover the songs. i wish to hearmore for you. :) thanks
balma
Real name: Mauricio
Post by balma » Fri Jul 25, 2014 12:23 pm
https://soundcloud.com/balma
alfadawg01
Gear: Ensoniq SD1, Alesis Ion, iPad2 (running Animoog, Galileo Organ, iM1, iWavestation, Mellotronics M3000HD, & ThumbJam), Roland VR-09b.
Band: The Journey Worship Band
Post by alfadawg01 » Fri Jul 25, 2014 2:20 pm
This isn't meant to sound arrogant, but you should read each instrument's manual to learn how they do what they do. If you don't have them, search on line. Then, you might try to recreate a song you like so you can figure out how it was done. Beyond that, just sit down and play!
micahjonhughes
Post by micahjonhughes » Fri Jul 25, 2014 3:20 pm
I know nothing about the genre, except what I learned by clicking on the link, but is seems that a general setup will work for minimal wave. The gear that you have should be more than adequate to write some songs if you combine it with a mixer, monitors and appropriate cables.
I'm unsure whether you are asking how to connect up the gear you have into a midi synth studio or if you are asking for some tips on composing. If you can clarify, I'll try and be more helpful.
Very generally, you could probably get by with the Command Station alone. It is a drum machine, sequencer and rompler. As it is likely to be the backbone of your rig, you should read the link provided and get to know what you can do with it. The Moog will provide good basses as well as leads and synth effects. The ESQ is fairly flexible, but my guess is that you will find yourself mostly using it for pads and then leads and basses.
As mentioned above, you will need a mixer, monitors (speakers) and lots of 1/4 inch and midi cables.
If you narrow your question down, I'll try to be more helpful.
Bitexion
Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Post by Bitexion » Fri Jul 25, 2014 3:44 pm
What you are asking is like buying a bunch of guitars and a drumset and ask how to make heavy metal music with this gear..
calyx93
Gear: PPG Wave 2.2, μWave (x2), Roland JP6+V-Synth+S-220, SCI P5+600, Ensoniq SQ-80, Kawai K-3+K-3m, ARP Odyssey+Omni2, Emulator II+HD, Ensoniq Mirage.
Post by calyx93 » Fri Jul 25, 2014 5:00 pm
Honestly, just start off with the mastering the ESQ-1 - it's very easy to understand, the sequencer is easy to use and will give you the basic knowledge behind sequencing, the synthesis is straightforward too and will give you a solid knowledge of subtractive synthesis - plus it has drum sounds, so you can make complete 8 track songs with it. Check out the manual, and learn that synth inside and out FIRST.
Then you should move onto the Phatty - if you've got the skills down on the ESQ, then creating sounds on the Moog will be a cinch and you then understand the difference between what a digital/analog hybrid and a pure analog sounds like. Then try maybe using it for a bass track via MIDI in an ESQ sequence.
Now that you've got that down, the most complex item is the E-mu, but by this point, you should feel comfortable enough to delve into that. If you've not been "bitten by the bug" at this point, you'll know it and will either dive head-first with exuberance or drop the stuff altogether.
As for HOW to compose or write minimal wave, I've no idea. Just try copying some songs or riffs you've heard - just synthesize and sequence them yourself as best you can and try improving them. There are no classes on this sort of thing - everyone learns by doing and mimicking their favorite artists.
Good luck and hope you catch on quick - have fun too.
JayEm
Real name: Jonathan
Post by JayEm » Fri Jul 25, 2014 6:23 pm
according to wikipedia, your gear is wrong for minimal wave because they include midi.
best just to give up entirely.
w00t
matia
Real name: matia
Gear: Forum said that I exceeded 150 characters. Here's a partial:
Serge Modular 9 pannels SMS Modular almost all modules
ARP 2600
Roland Tr 808 ....
Post by matia » Sat Jul 26, 2014 4:33 am
i would say the ESQ 1 is cool for more mid to late 80's kinds of sounds ... think Martin Dupont circa He Saw the Light ...
Out of the modern stuff I would say the MS20 mini is your ticket and the Bass Station 2. Drum machine wise ... I mean the obvious is to bag a Boss DR55 like everyone else ;-) There's the TR 8 as well. It does a fairly convincing 808. The kick and the hats on the Volca Beats are also fantastic.
joeboy
Gear: ax-80, jx-8p, v-synth, monotribe, ПИФ, tx81z, sy35, tg77
Post by joeboy » Sat Jul 26, 2014 10:38 am
I'll second the DR55. And a Casio VL-Tone VL-1 too!
But idunno. Just use the gear you have first.
alfadawg01
Post by alfadawg01 » Sat Jul 26, 2014 10:27 pm
Hmmm....the OP vanished on us. That's what happens when someone comes expecting us to do his homework for him.
