Sequencer for Korg MS-20
Hey guys,
I just bought an original Korg MS-20. It's amazing. I know people say just get the MS-20 mini, but I found something really special about the original. Who knows.
ANYWAYS, I'm looking at sequencers for it. What are my options? Googling anything just brings up info for the MS-20mini, which leads to discussions about USB MIDI, and that obviously won't work for me.
Looking for something affordable, but I'll take any suggestions!!!
- Moderator
- Gear: Hard and Soft Synths
Re: Original Korg MS-20 Sequencer
If your looking for a step sequencer then check out the Doepfer Dark Time, just make sure you get the trigger mod done so it'll work with the MS.
There are lots of options depending on budget however.
You always want just one more Synth!
- Bitexion
- Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Waldorf Blofeld - Location: Drammen, Norway
You can't use just any CV sequencer, since Korg's MS range uses a different scaling than 1V/Octave.
You can, but you'll lose the pitch modulation CV input. Wrong trigger type is a bigger problem, but can be fixed with a specific cable.Bitexion wrote:You can't use just any CV sequencer, since Korg's MS range uses a different scaling than 1V/Octave.
- Psy_Free
- Gear: Synths 'n' stuff.
- Band: Klangzeit
Buy yourself a Korg EA-1 & a Kenton Pro Solo MK 2.
Here's a link to the Kenton : http://www.kentonuk.com/products/items/ ... solo.shtml
- Psy_Free
- Band: Klangzeit
Er, OK. (I'm sure the OP could probably work out how to search the web for them, but I'll oblige).
Kenton Pro Solo :
Korg EA-1 :
Kenton Pro Solo :
Korg EA-1 :
- ninja6485
- Gear: Virus Ti, Jx-8p, Juno 60, Radias, Maschine, 101,303,606,707,727,808,909, odyssey, mirage, akai s5K/s2K/s1k, drumtraks, E6400ult, M1R, rx5, fizmo,d50
- Band: Subliminal Sea
- Psy_Free
- Band: Klangzeit
- meatballfulton
- Moderator
- Gear: Logic Pro X
Re: Sequencer for Korg MS-20
You guys are cracking me up...
- pflosi
The Dark Time can send out unquantized CV so you can also use the Hz/V input and scale by ear (or tuner), step by step... That's how I use my MS20 + Dark Time combination mostly.Low Life wrote:You can, but you'll lose the pitch modulation CV input. Wrong trigger type is a bigger problem, but can be fixed with a specific cable.Bitexion wrote:You can't use just any CV sequencer, since Korg's MS range uses a different scaling than 1V/Octave.
The range you can get out of the supplied 5V is smaller though than with the V/Oct input, obviously...
- pflosi
Psy_Free wrote:Unless he thinks there is an MS-20 sequencer (as opposed to an MS-20 synth)
Also unquantized CV only as far as I know...
- Bitexion
Roland D-50
Creamware Minimax
Yamaha DX7s
Nothing lol there, there is, and it's called SQ-10. But it's probably even rarer than an MS-20.Psy_Free wrote:Unless he thinks there is an MS-20 sequencer (as opposed to an MS-20 synth)
- Psy_Free
- Band: Klangzeit
Bitexion wrote:Nothing lol there, there is, and it's called SQ-10. But it's probably even rarer than an MS-20.Psy_Free wrote:Unless he thinks there is an MS-20 sequencer (as opposed to an MS-20 synth)
- stevee0303
- Gear: Roland x0x machines
The MFB Urzwerg or urzwerg pro is capable and I prefer it over the darktime, it doesn't require any mod done if I recall correctly.
