Synth Defects - Ticking Time Bombs
Re: Synth Defects - Ticking Time Bombs
ARP Omni / Omni-2. Power supply throws voltage spikes when powered up, causing damage over time to the many tantalum (decoupling) capacitors connected across the power supply rails throughout the synth, eventually causing one or more to dead-short. Since the power supply rails are not fused, when the dead short happens it takes the power supply and other components down with it.
-- R.
Thanks for catching that. I edited the OP.fh991586 wrote:The MKS-70 is fine on this subject: you got it mixed with the MKS-7 & MKS-30, which share the save epoxy chip as the Juno 106.coastalscrub wrote:- Roland Juno 106 / MKS-70 / HS-60 - the voice chips have an epoxy coating that eventually short the chips resulting in dead voices.
What about synths that use regular removable batteries, either for main power or for memory storage? Last month, I discovered that the batteries in one of my portable turntables were leaking heavily. I caught it in time but I can imagine someone putting a SH-101 or a TB-303 in a closet and not taking the batteries out and discovering the same thing. If you're lucky, the battery acid is contained in the battery compartment and just eats away at the contacts and springs. Which of these kind of synths are most at risk of real damage from a battery leak?
- Swayze
- Gear: Mono/Poly, Pro-One, Juno-60, JX-3P, AX80, SQ80, AN1x, DX100, DX7E!, DX7IIFDE!, TG77, EX8000, Microbrute, Behringer D, Drumtraks, TR-08 and Eurorack
I hear a lot about battery leakage in the Polysix. The Mono/Poly was part of the same family from Korg, but I have never heard of any issues, batteries or otherwise. Did Korg fix this problem on the Mono/Poly, just get lucky, or should I still be concerned? I better open 'er up today and have a look.
Edit: Just remembered that batteries are needed for patch storage, which the Mono/Poly doesn't have...what a relief.
- Gear: Moog Little Phatty, Micromoog, Arp Odyssey, Roland Juno-106, Alpha Juno 1, Microbrute SE(orange), Rhodes Stage 73, Octatrack, Prophet 6
- Band: Coral Bones, Pet Library
The foam inside of the Realistic/Moog Concertmate MG-1 decays into a tar-like paste.
Earlier Wavestations and even the A/D Racks can have power supply issues - it seems that the original power supplies were somewhat under specced and can cause the rather lovely "click of death" - the WS randomly hangs and emits a repeated series of clicks to the audio output - I still have a recording of this
The solution is usually to get a replacement power supply.
Also, another common one, not just for the Wavestation but for a lot of synths of that generation is of course fading backlights in displays - both my Wavestation and my CZ-1 have backlights that are so dim they barely shine in the dark.
Moog Opus 3 does the same!super_doraemon wrote:The foam inside of the Realistic/Moog Concertmate MG-1 decays into a tar-like paste.
- meatballfulton
- Gear: Logic Pro X
The analog output stage FETs in the Alesis Ion and Micron go south regularly. Probably also true of the Akai Miniak.
The LED display of the Roland MC505 starts losing pixels over time.
The effects selector on the Korg EM-1 uses a detented pot rather than a physical switch, the part is no longer available if the original wears out.
- ppg_wavecomputer
- Expert Member
- Gear: more keys than hands (and feet)
- Band: ['ramp]
- Location: teutoburg forest, eastern westphalia, germany
Oh, right... thanks for reminding me why I sold my ARP Omni back in 1997.rschnier wrote:ARP Omni / Omni-2. Power supply throws voltage spikes when powered up, causing damage over time to the many tantalum (decoupling) capacitors connected across the power supply rails throughout the synth, eventually causing one or more to dead-short. Since the power supply rails are not fused, when the dead short happens it takes the power supply and other components down with it.
Glad you found out the answer for yourself.Swayze wrote:I hear a lot about battery leakage in the Polysix. The Mono/Poly was part of the same family from Korg, but I have never heard of any issues, batteries or otherwise. Did Korg fix this problem on the Mono/Poly, just get lucky, or should I still be concerned? I better open 'er up today and have a look.
Stephen
https://ramp1.bandcamp.com/
Some minor defects:
Roland JX-8P - the aftertouch stops working when the metal strip inside gets oxidized
Oberheim Matrix-1000 (black units only?) - humming power supply transformer
Aren't there some synths that have humming or buzzing backlit displays?
- Real name: Max
- Gear: T1, XV 5080, ES1, Zaquencer
Korg M/T seriescoastalscrub wrote:Aren't there some synths that have humming or buzzing backlit displays?
Roland D70/MV30
Kawai K5000
That's just in my arsenal.
- Percivale
- Gear: Blofeld, Juno-106, AN1X, MB-6582/SEQ V4, etc
Lots of Roland TR-626s have this "burnt" LCD.
Join - SG Synthesizers Group
- mmp
- Real name: Michael McInnis
- Gear: VS VL-1 Varios VoyagerRME MinimoogD CS60 SY-2 Kronos M3X MW1 2600 PS3100 DV-800 Z1 Chroma XT Blofeld k5K PolyMoog Avatar MS20 PE-1000 P6 OB6 m4000d
- Band: Iberquez
Rhodes Chroma: backup battery leakage & bad power supply design. Road case foam rot ruins exterior finish.
Michael McInnis Productions
www.mm-pro.com
www.mm-pro.com
Nope, white units are just as likely to be affected. They use the exact same transformer after all.coastalscrub wrote:Oberheim Matrix-1000 (black units only?) - humming power supply transformer
Fortunately the hum is actually only a physical vibration caused by the transformer, it does not propagate to the audio signal path.
And the official Arp "fix" ensures that the 18v spike stays on, so your synth fries immediately. I just had my Omni's psu upgraded. Nice and safe now. (I also had the filter mod done, and it really sounds good.)rschnier wrote:ARP Omni / Omni-2. Power supply throws voltage spikes when powered up, causing damage over time to the many tantalum (decoupling) capacitors connected across the power supply rails throughout the synth, eventually causing one or more to dead-short. Since the power supply rails are not fused, when the dead short happens it takes the power supply and other components down with it.
- ppg_wavecomputer
- Expert Member
- Band: ['ramp]
Korg Wavestation (EX) -- high-pitched whine from the display.max badwan wrote:Korg M/T seriescoastalscrub wrote:Aren't there some synths that have humming or buzzing backlit displays?
Roland D70/MV30
Kawai K5000
The WS keyboard reportedly might become sticky due to deteriorating component parts -- haven't experienced this myself but I've seen two or three examples with that issue (early DX-7 models seem to suffer from the same disease)
Stephen
