Yamaha dx7 iifd Grey E!! card??? arpegattor help
bassplayer1980
Real name: Paul
Gear: Moog lp, Ensoniq ESQ-1, E-mu command station, Mackie mixer 402 vlz3.
Post by bassplayer1980 » Mon Mar 02, 2015 7:11 pm
I bought an yamaha dx7 iifd with an grey e! card. I want to know how can I use the arpegiattor and which keys do i need to press to activate it. I saw the manual but I didn't find anything related to the arpegiattor. most people said it has an arpegiattor. I really need that help.. U.U
thanks for your help.
att: Paul
calyx93
Gear: PPG Wave 2.2, Waldorf μWave x3, Roland JP6+V-Synth, SCI P5+600, Ensoniq SQ-80, Kawai K-3
Re: Yamaha dx7 iifd Grey E!! card??? arpegattor help
Post by calyx93 » Mon Mar 02, 2015 7:37 pm
bassplayer1980
Real name: Paul
Post by bassplayer1980 » Tue Mar 03, 2015 2:16 am
I already see the document before, but I'm still confused how to turn the arpeggiattor. anyways, thanks
pflosi
Post by pflosi » Tue Mar 03, 2015 1:59 pm
It would be news to me that there's an arpeggiator in the E! board...? But then again I only have experience with a MK1 DX7 equipped with the E! board...
bassplayer1980
Real name: Paul
Post by bassplayer1980 » Tue Mar 03, 2015 5:48 pm
So, what you guys recommend me?? I also don't know what is the use of the floppy disk on the yamaha dx7 iifd. I really need the arpeggiator for my yamaha dx7. :cry: :cry: :cry:
pflosi
Post by pflosi » Tue Mar 03, 2015 6:52 pm
Where did you read about that arpeggiator? Must be somewhere. I scanned my Grey Matter E! manual before, but there's nothing in it. But I'm also not sure whether that's just the DX7 MK1 manual for it or a generic one...
Otherwise, how about a MidiPal or something like that?
adamstan
Real name: Adam
B5 DIY polysynth
KORG Poly61
Vermona DRM
Solton Programmer 24
LEMA EDD-5
Post by adamstan » Tue Mar 03, 2015 7:20 pm
There is no "classic" arpeggiator in E! for DX7II. It has "Player" mode, which is crude form of auto-accompaniment/arranger. It plays back pre-programmed sequences (up to 8 tracks), which you can transpose (and sometimes switch between different patterns) using lowest octave on the keyboard. I haven't figured out how to program your own sequences yet, but it probably is covered somewhere in the manual ;-) My main use for E! is memory expansion, so I can have 4 standard DX banks at once :-)
philip
Real name: Philip
Post by philip » Tue Mar 03, 2015 7:27 pm
Is it possible to install E! on DX5?
bassplayer1980
Real name: Paul
Post by bassplayer1980 » Wed Mar 04, 2015 11:06 am
Thanks!!! I already solder the battery and I didn't lost any patch. yeah, I have my 4 banks to store sounds. I turn the synth and I hear the volume low, then I wait and it started to raise. It is normal??? well, If E! don't have arpegiattor, what could I do?? Is there any midi arpegiattor for Dx7??? I really want to try it if it exist.
thanks!!!! :? :? :? :? :?
fh991586
Real name: Francis
Yamaha Motif Rack.
Midines
Post by fh991586 » Thu Mar 05, 2015 4:48 pm
No, there is no arpegiator on any version of the DX7. You must use an external module that can send the arp through midi. The easiest way would be a software, or even a MicroKorg...
-Roland TR707
-DSI Mopho
bassplayer1980
Real name: Paul
Post by bassplayer1980 » Thu Mar 05, 2015 5:12 pm
Ohh, I understand. Should I try the mutable instruments shruti 01 or midpal??? maybe an ARPIE???
pflosi
Post by pflosi » Thu Mar 05, 2015 5:30 pm
MidiPal
Then: "Local Midi off" on the DX7, put a cable from the DX midi out to the MidiPal, and back into the midi in of the DX :thumbright:
If you still want to use the DX keyboard that is.
Otherwise, yes of course software can do it even cheaper if you have the respective software already :D
Infinity Curve
Real name: Cody
Gear: SH101, Monomachine, Machinedrum, Analog Four, lots of eurorack
Band: Infinity Curve
Post by Infinity Curve » Thu Mar 05, 2015 6:06 pm
Why not use the arp from your Command Station?
Peopleunderthesun
Gear: Minimoog, Polymoog, Prophet 5, Composer, Multiman, Jx10 with Vecoven modifications, D50, Emax II HD, Dx7 MkI Supermax, MPC 5000
Band: People Under The Sun
Post by Peopleunderthesun » Thu Mar 05, 2015 7:21 pm
I've got the Supermax mod on mine and it does have an arpeggiator
bassplayer1980
Real name: Paul
Post by bassplayer1980 » Fri Mar 06, 2015 2:34 am
Can I get the SUPERMAX for my dx7 iifd??? I hace a moog little phatty, can I use it for bass lines??? If I local midi off??
thanks!!! :? :? :? :?
