Page 1 of 2
Yamaha dx7 iifd Grey E!! card??? arpegattor help
Posted: Mon Mar 02, 2015 7:11 pm
by bassplayer1980
I bought an yamaha dx7 iifd with an grey e! card. I want to know how can I use the arpegiattor and which keys do i need to press to activate it. I saw the manual but I didn't find anything related to the arpegiattor. most people said it has an arpegiattor. I really need that help.. U.U
thanks for your help.
att: Paul
Re: Yamaha dx7 iifd Grey E!! card??? arpegattor help
Posted: Mon Mar 02, 2015 7:37 pm
by calyx93
Posted: Tue Mar 03, 2015 2:16 am
by bassplayer1980
I already see the document before, but I'm still confused how to turn the arpeggiattor. anyways, thanks
Posted: Tue Mar 03, 2015 1:59 pm
by pflosi
It would be news to me that there's an arpeggiator in the E! board...? But then again I only have experience with a MK1 DX7 equipped with the E! board...
Posted: Tue Mar 03, 2015 5:48 pm
by bassplayer1980
So, what you guys recommend me?? I also don't know what is the use of the floppy disk on the yamaha dx7 iifd. I really need the arpeggiator for my yamaha dx7. :cry: :cry: :cry:
Posted: Tue Mar 03, 2015 6:52 pm
by pflosi
Where did you read about that arpeggiator? Must be somewhere. I scanned my Grey Matter E! manual before, but there's nothing in it. But I'm also not sure whether that's just the DX7 MK1 manual for it or a generic one...
Otherwise, how about a MidiPal or something like that?
Posted: Tue Mar 03, 2015 7:20 pm
by adamstan
There is no "classic" arpeggiator in E! for DX7II. It has "Player" mode, which is crude form of auto-accompaniment/arranger. It plays back pre-programmed sequences (up to 8 tracks), which you can transpose (and sometimes switch between different patterns) using lowest octave on the keyboard. I haven't figured out how to program your own sequences yet, but it probably is covered somewhere in the manual ;-) My main use for E! is memory expansion, so I can have 4 standard DX banks at once :-)
Posted: Tue Mar 03, 2015 7:27 pm
by philip
Is it possible to install E! on DX5?
Posted: Wed Mar 04, 2015 11:06 am
by bassplayer1980
Thanks!!! I already solder the battery and I didn't lost any patch. yeah, I have my 4 banks to store sounds. I turn the synth and I hear the volume low, then I wait and it started to raise. It is normal??? well, If E! don't have arpegiattor, what could I do?? Is there any midi arpegiattor for Dx7??? I really want to try it if it exist.
thanks!!!! :? :? :? :? :?
Posted: Thu Mar 05, 2015 4:48 pm
by fh991586
No, there is no arpegiator on any version of the DX7. You must use an external module that can send the arp through midi. The easiest way would be a software, or even a MicroKorg...
Posted: Thu Mar 05, 2015 5:12 pm
by bassplayer1980
Ohh, I understand. Should I try the mutable instruments shruti 01 or midpal??? maybe an ARPIE???
Posted: Thu Mar 05, 2015 5:30 pm
by pflosi
MidiPal
Then: "Local Midi off" on the DX7, put a cable from the DX midi out to the MidiPal, and back into the midi in of the DX :thumbright:
If you still want to use the DX keyboard that is.
Otherwise, yes of course software can do it even cheaper if you have the respective software already :D
Posted: Thu Mar 05, 2015 6:06 pm
by Infinity Curve
Why not use the arp from your Command Station?
Posted: Thu Mar 05, 2015 7:21 pm
by Peopleunderthesun
I've got the Supermax mod on mine and it does have an arpeggiator
Posted: Fri Mar 06, 2015 2:34 am
by bassplayer1980
Can I get the SUPERMAX for my dx7 iifd??? I hace a moog little phatty, can I use it for bass lines??? If I local midi off??
thanks!!! :? :? :? :?
