Synergy 1032 Lives Again!
Postby HideawayStudio » Sun Mar 08, 2015 6:08 pm
I seem to inadvertently be on a mission to return every remaining GDS and Synergy II+ to working order!
The last two weeks have been the resurrection of 1981 Synergy number 1032. This example (my 6th) has been particularly tough - so much wrong with this one beast - I literally have a jam jar full of nearly 100 dead/dying/tarnished/broken components that had to be replaced.
What I can say now with absolute conviction is that anyone trying their chances running one of these things without a full recap is really pushing their luck - every example I've seen to date has suffered damage due to dead short tantalum caps and in this case the transformer for the linear rails had burnt out to the point the secondary windings were open circuit.
Having finally got the entire system running again yesterday evening including the SynHCS voice editor on the Kaypro II under HxC disk emulation I celebrated by recording a test improv made using a patch programmed up on the SynHCS editor.
What transpired is actually a rather nice example of the bizarre continuously variable random vibrato feature on the Synergy which can be used to great effect from subtle complex wobbles to completely crazy FX.
I strongly feel these rather bizarre old digital synths still have a lot to be explored...
HideawayStudio
Real name: Dan Wilson
Band: Shortwave
Re: Synergy 1032 Lives Again!
Postby synthroom » Mon Mar 09, 2015 3:17 pm
That's very cool sounding! The start was like a variation on the THX sound.
synthroom
Real name: Kirk
Postby meatballfulton » Mon Mar 09, 2015 6:02 pm
Just wow. It must be so much fun playing these instruments after you have restored them.
Gear: Live 9, Logic Pro X
Postby Vxster » Mon Mar 09, 2015 9:23 pm
That is an amazing sound! As meatball said, just wow!
Vxster
Postby ppg_wavecomputer » Tue Mar 10, 2015 10:57 am
Thanks, Dan.
Now you've successfully refuelled my desire for a Synergy...
Stephen
https://ramp1.bandcamp.com/
ppg_wavecomputer
Band: ['ramp]
Postby HideawayStudio » Sat Mar 14, 2015 11:48 pm
Another evening has slipped away whilst trying my best to get my head around programming the Synergy in the SynHCS editor. I am quite determined to hold this instrument in a different light to maybe what many have heard of it and move away from the usual marimba and glockenspiels a plenty and explore something much more complex, sustained and evolving. With up to 16 loopable stages in each envelope on each oscillator it clearly is capable of doing just this!
Not only does in fact the instrument have an envelope per oscillator but all the parameters are doubled - one set for gentle key presses and one set for hard.. and they are morphed between the two...
The mind boggles!
Here is another test recording from 1982 Synergy II+ number 1032 running under the SynHCS voice editor shortly following a major overhaul and return to operation. This live improvisation is a demonstration of the potential fluidity of such evolving timbres.
This is the tip of the iceberg.. there is a h**l of a lot more to discover here.
HideawayStudio
Band: Shortwave
Postby rhino » Sun Mar 15, 2015 8:11 pm
Hat off and a cold brew to you, sir!
When I find one, I'll know who to crutch on for restoration advice!
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Postby synthroom » Mon Mar 16, 2015 2:10 pm
That sounds great!!
synthroom
Real name: Kirk
Postby Pyradox » Tue Oct 10, 2017 3:40 am
I am looking to replace my aging Synergy Host Control System software as Ive completely worn out the disks. I started w/ version 3.22 then worked with older versions (3.18, 3.15, 3.12, etc...). Please let me know if you would be willing to help get me a working copy. I also have every voice cartridge on disk that Wendy Carlos created as well as disc for VC 1-6. Let me know if you interested in that. I still have some working 5.25 discs.
Definitely still worth exploring. I have had a lot of fun creating algorithms that use all 32 oscillators, which reduces the synergy to only a few voices but then I sample that. Using synth swipe on the Emulator x3 its rather effortless to create some awesome voices that capture the velocity tinker changes.
In any case if you can point me to a software resource I'd love to get to voicing again.
Many thanks,
Pyradox
Real name: Ruston
Gear: Korg SV-1, Oberheim TVP, Arp Odyssey, Sequential Circuits Prophet T-8, Roland R8 D-50 System 8, DK Syngery II+, Crumar DS-2 Performer
Postby commodorejohn » Tue Oct 10, 2017 4:59 am
Where are you located? If someone can hook me up with disk images and/or archives for the software I've got a Kaypro I'd be happy to write disks with. And yes, definitely share them goodies.
Geez, I really do need to get off my a*s and try to get my Synergy working...
commodorejohn
Real name: John
Postby Walter Ego » Wed Oct 11, 2017 6:23 pm
Does it have the dreaded motherboard/daughterboard disconnection problem? Mine had come unseated in transit and I didn't have the patience to deal with it. So I sold it to Silikon.
I wonder what happened to Silikon... :-|
Walter Ego
Walter Ego
Band: 12"VS
Postby commodorejohn » Thu Oct 12, 2017 7:21 am
Nah, mine is actually almost working normally except for keying issues (a couple missing plastic bits I need to finish hacking up 3D-printed replacements for, and some issue in the key scanner that makes release not work.) I think I actually know a couple possible things that could be causing the problem, I just need to sit my a*s down and test my theories out...
commodorejohn
Real name: John
Postby Pyradox » Fri Oct 13, 2017 4:43 am
commodorejohn wrote:Where are you located? If someone can hook me up with disk images and/or archives for the software I've got a Kaypro I'd be happy to write disks with. And yes, definitely share them goodies.
Thanks commodorejohn, I'm in Magnolia Texas. I have several working Kaypros but appreciate the offer. Synhcs 3.22 would be the holy grail.
Pyradox
Real name: Ruston
Postby commodorejohn » Fri Oct 13, 2017 5:58 am
Cool. Point me to disk images/archives and I'll see what I can do.
commodorejohn
Real name: John
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 11 guests
