That's what sucked about the Juno-106 unison mode. Just made the sound alot louder, not fatter since they were all perfectly in tune. A tiny bit of drift would have changed it into something awesome.Automatic Gainsay wrote:What good are free-running DCOs if they're all perfectly in tune? Being digitally out of phase isn't as good as being slightly out of tune!
3-Oscillator Per Voice Polysynths??
- Bitexion
- Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Re: 3-Oscillator Per Voice Polysynths??
- HideawayStudio
- Real name: Dani Wilson
- Band: Shortwave
Don't forget that the high frequency (typ. 500KHz,1MHz or 2MHz) master oscillators in most DCO synths are analog at the end of the day which means they free run and are slightly unstable. The reason for this is that in most cases any frequency modulation effects such as vibrato or even FM or cross modulation can be relatively easily implemented with a high degree of fluidity by using a VCO based HF master oscillator with its own modulation source mixer taking CV channels from analog pitch bend, LFO as well as the outputs of other oscillators for cross modulation.Automatic Gainsay wrote:What good are free-running DCOs if they're all perfectly in tune? Being digitally out of phase isn't as good as being slightly out of tune!
If you have multiple HF master oscillators then even when the digital counters are set to the same period there will still be a natural beating effect because its impossible to set the HF oscillators to precisely the same frequency unless there is a mode to deliberately lock to one master oscillator (which is implemented in the better DCO designs in patches were phase accuracy is important) - however- sadly so many cut corners by sharing the same master oscillator for every counter-timer. Thankfully some didn't go this far and implemented multiple HF oscillators knowing that the result would be more musical.
For example - Mario Maggi used four independent VCO based HF oscillators each with their own analog modulation CV sources in the Synthex and the early Oberheim DCOs had multiple master oscillators too.
Sadly, many didn't go this extra step and the Juno-106 is such an example where all the counter-timer channels were phase locked to the same master oscillator.
H.I.D.E.A.W.A.Y S.T.U.D.I.O
http://www.hideawaystudio.net
The Home of Novachord #346
http://www.novachord.co.uk
- nathanscribe
- VSE Review Contributor
A side-note about the Lambda's implementation: not only does it have three independent oscillators providing clocks for its three separate divide-down circuits, each oscillator receives differently-phased modulation from a multiple-output LFO. The vibrato on this thing is thick.
- HideawayStudio
- Band: Shortwave
The PE-2000 and PS-3300 did something similar and even the PE-1000 with its crazy oscillator per key architecture has a very clever trick up its sleeve which I've never seen before whereby the keyboard is split into three and not only variably detuned across the three splits but three separate free-running vibrato channels drive them to create an ensemble effect which is particularly effective with the variable octave layering control. Its quite simply the most bizarre and wonderfully unique polysynth Korg ever made in my opinion.nathanscribe wrote:A side-note about the Lambda's implementation: not only does it have three independent oscillators providing clocks for its three separate divide-down circuits, each oscillator receives differently-phased modulation from a multiple-output LFO. The vibrato on this thing is thick.
So it seems Korg took ideas from both the PS and PE series when they came up with the Lambda.
Out all the big name synth manufacturers I think Korg was the one making by far the most quirky and characterful instruments during that era.
- nathanscribe
Compromised as it is in some ways, the Lambda uses some clever design. I particularly like how the 3 oscillators are assigned depending on which sounds are selected. Nicely thought out stuff.
I've not really looked into the PE models, but that sounds intriguing...
- Automatic Gainsay
- Real name: Marc Doty
- Gear: Minimoog, 2600, CS-15, CS-50, MiniBrute, MicroBrute, S2, Korg MS-20 Mini, 3 Volcas, Pro 2, Leipzig, Pianet T, Wurli 7300, Wurli 145-A, ASR-10, e6400.
- Band: Godfrey's Cordial
"Compromised?"
How? How is this a "compromised" string synth?
Come on, Nathanscribe.
- Walter Ego
- Gear: Various noisemakers hidden around my home and classroom. And a great quantity of caffeine.
- Band: 12"VS
I think that goes for Korg in general during that era!HideawayStudio wrote:Out all the big name synth manufacturers I think Korg was the one making by far the most quirky and characterful instruments during that era.
Walter Ego
seamonkey wrote:I nominate this for STUPIDEST THREAD ever in the history of the internez.
- nathanscribe
Automatic Gainsay wrote:"Compromised?"
Only in ways you'd ecxpect a stringer to be compromised. Single 'paraphonic' (dare I even say that word? :p) retriggering Brass filter envelope, awkward panning of chorussed/non-chorussed audio outputs, presets per side on/off only with no individual mix controls... overall the Lambda is pretty damn great, and I don't consider it 'compromised' as a whole, but being a stringer there are a couple of the usual workarounds, that's all I meant.
