Page 1 of 3
What's your favorite synthesis method--
Posted: Thu Apr 30, 2015 2:38 pm
by briandc
--and why?
(give an audio demo if possible)
brian
Re: What's your favorite synthesis method--
Posted: Thu Apr 30, 2015 3:41 pm
by Zamise
Taking the first default sound that the synth comes on with, like bank A program 1, and modifying it to sound like a distorted tb-303. Why? Because it is the first thing it comes on to, why waste more energy pushing a few more buttons or scrolling more knobs? I suppose this method would probably considered really lazy, but I like to think of it as being extremely efficient.
Posted: Thu Apr 30, 2015 3:48 pm
by briandc
Well, what I mean by "synthesis method" is FM, subtractive, additive, etc..
brian
Posted: Thu Apr 30, 2015 4:00 pm
by Zamise
Ahhh OK. I'm going to say then PCM based additive (because it usually has more polyphony than most the other methods) with a complex subtractive engine behind it and a decent control surface. Vintage rompling will be the new thing I tell you, it never went out of fashion with me.
Posted: Thu Apr 30, 2015 4:23 pm
by CS_TBL
FM
See signature
Posted: Thu Apr 30, 2015 4:41 pm
by GuyaGuy
Subtractive...although I find the term misleading. 2 sines into a ring mod is a fairly basic component of "subtractive synthesis" but it's not subtractive. Neither is analog FM. In fact, a saw into a resonant filter isn't necessarily entirely subtractive either as the resonance adds harmonics.
Why? I like those sounds the most. It's potentially less rich a palette compared to other forms of synthesis but there are so many options even with the limitations.
Posted: Thu Apr 30, 2015 5:24 pm
by vicd
Anything with dynamic filtering (well, with "dynamic" being more complex than just "LFO-to-FilterFrequency" or "keytracking"). Count in E-mu's Z-planes, Hartmann Neuron, K5000 and similar, VirSyn's engines where you literally draw your filter curves, Variphrase and similar vocoding... Kyma's morphing maybe also belongs there.
UPD: I guess all of that goes under the "spectral morphing" nickname.
Posted: Thu Apr 30, 2015 7:15 pm
by sigment
I only use subtractive and a tiny little bit of fm. Subtractive is the easiest for me to hear a sound in my head and get a pretty close patch quickly. FM not so much... I get the theory of operators / etc but the smallest change in a patch can take you from musical to demolishing very quickly, and i just dont like that.
as an aside: what type of synthesis would a device like this utilize? (where you input a formula) I love the sound of this vi in the caustic app and would like to explore the methods but don't know where to start...
Posted: Thu Apr 30, 2015 8:14 pm
by Solyaris
Zamise wrote:Taking the first default sound that the synth comes on with, like bank A program 1, and modifying it to sound like a distorted tb-303. Why? Because it is the first thing it comes on to, why waste more energy pushing a few more buttons or scrolling more knobs? I suppose this method would probably considered really lazy, but I like to think of it as being extremely efficient.
PCM based additive with a rompler? This is new to me. Could you give an example?
Posted: Thu Apr 30, 2015 11:50 pm
by Zamise
Solyaris wrote:Zamise wrote:Taking the first default sound that the synth comes on with, like bank A program 1, and modifying it to sound like a distorted tb-303. Why? Because it is the first thing it comes on to, why waste more energy pushing a few more buttons or scrolling more knobs? I suppose this method would probably considered really lazy, but I like to think of it as being extremely efficient.
PCM additive meaning the waveforms are played as sound source to a subtractive engine, usually pretty common but I suppose it is the amount of control to me that makes the difference in the subtractive part. My long time favorite is the Yamaha RS7000. It seems pretty rudimentary on the surface as far as synthesizing sounds go, but you also have immediacy of knoby control surface, plus after the subtractive part (filters, lfos, envelops etc.) you can then layer the parts with a trick or two which could be considered additive again after the additive and subtractive. So it is an additive subtractive additive, then effects can be both additive and subtractive after that so than your talking about being an additive subtractive additive additive and subtractive synthesis method. Then... oh never mind. I've also been getting in to the Yamaha CS6X/CS6R engine lately, which is kind of the same principle but sounds freaking amazing, less controls tho unless you have it hooked midied up to an RS7000 then you could say it has more controls, but anyhow check those two synths out. They ain't your mama's and dada's romplers.
Posted: Fri May 01, 2015 4:56 am
by dustinh
Subtractive for the most part, although I'm getting more and more into FM and find it far more interesting.
Posted: Fri May 01, 2015 12:34 pm
by mmp
Phy-mod for the high level of realtime control.
Analog subtractive for ease of programming.
Sample playback for emulative realism, but only when multi-dimensional with heavy scripting.
Posted: Fri May 01, 2015 3:52 pm
by ryryoftokyo
I know it's just a form of analog synthesis, but using a modular is by far my favorite. With a traditional synth, you get locked into a programming routine and the board sort of takes you where you down a set path, where as using a modular feels so free and limitless. I stare at a blank modular and see possibilities. I know what I have to do, but there are a million different ways to accomplish it, all of which can result in drastic (and often inspiring) sonic variations. When I stare at my Nord Lead 2x, Yamaha AN1x, Roland JX8P, Korg MS20, and so on, I see a routine that I get locked into. Lovely synths in their own right, but they do feel very restrictive when compared to the total freedom my modular offers me.
Posted: Fri May 01, 2015 4:11 pm
by Jabberwalky
FM, and Transwave. Make this a poll perhaps, if it lets you.
Posted: Fri May 01, 2015 7:39 pm
by briandc
Jabberwalky wrote:FM, and Transwave. Make this a poll perhaps, if it lets you.
Good idea, I'll do it!
Which ones should be included?
- Subtractive, modular, additive, FM, Phase Distortion, Wavetable, Granular, physical modeling, cellular automaton...
brian
