ninninon
Post by ninninon » Sat Nov 21, 2015 6:42 pm
phesago
Real name: Douglas
Gear: tech nine, bag of coke, an erection and a hostage
Re: I'm a totally new to synthesizers, and have a question t
Post by phesago » Sat Nov 21, 2015 6:56 pm
Well its up to you. You can goolge "midi controller", there a tons of them that do what you need. You'll obvious need a midi cable. The idea is pretty simple, but you'll need to learn how to set midi channels in the devices, so that they actually "talk to" each other.
ninninon
Post by ninninon » Sat Nov 21, 2015 6:59 pm
Online
Post by meatballfulton » Sat Nov 21, 2015 7:09 pm
No, the LPK25 is not sufficient. You need a keyboard that has real MIDI jacks, not just USB. For example:
The MIDI jacks are the two large round connectors in the middle of the jack panel. The keyboard shown is a Korg Taktile 25 which sells in the US for $100.
The Roland SH-32 is a digital synth, not analog. It was marketed as virtual analog meaning it's intended to sound like an analog synth.
ninninon
Post by ninninon » Sat Nov 21, 2015 7:12 pm
phesago
Real name: Douglas
Post by phesago » Sat Nov 21, 2015 8:26 pm
Most midi controllers can be programmed. Most likely the buttons/knobs/sliders are customizable in the OS.
ninninon
Post by ninninon » Sat Nov 21, 2015 8:40 pm
phesago
Real name: Douglas
Post by phesago » Sat Nov 21, 2015 8:47 pm
No. Most can be done from the controller itself.
ninninon
Post by ninninon » Sat Nov 21, 2015 8:53 pm
Online
Post by meatballfulton » Sun Nov 22, 2015 2:28 pm
The controls are there for when you are using the Taktile with software. They can also be used with hardware, but you must connect the unit to a computer to set up the controls as you want. Once programmed, it need not be connected to the computer again.
With a synth like the SH-32 which has plenty of sliders, knobs and buttons already, there's little need to use what's on the Taktile.
JeEA
Post by JeEA » Sun Nov 22, 2015 3:04 pm
Yes modelling synthesizer means digital doing an emulation of analog synthesizer.
I have an Access Virus B which is also a modelling synth.
If You Want analog filter You Can look for casio HT Series keyboard.
They have digital oscillator and AMP but analog filter. Sell for 60-100£
You Can buy an old midi control kbd with midi and use that probably cost 30-60£
If You have an IPad You Can find lots of synths with great sound
Korg iM1, arturia prophet VS and mini moog and many more.
Cheers
