Drums are 8-bit PCM with individual outputs. Bass, arpeggio and strings are based on M112 DCO, and the first two have SSM2044 filters. Bass has adjustable release time, and there are few presets, with different resonance and EG->filter amount. Arpeggio part has switchable waveform - square or staircase, and adjustable cutoff frequency. Strings have two parts available - cello and violin. There is also simple organ section (8' 4' 2'), that shares the chorus with strings.
Sequencer has adjustable pattern length and resolution = up to 24ppq. By default it's set to 16 steps. Can be programmed in realtime or in step mode.
Because of its sounds, it can be considered Italo-Disco-In-A-Box
Bass, PCM drums, strings and arpeggio is played by Programmer 24. Additional drum track provided by Vermona DRM - it also serves as MIDI clock master. Leads played on DX7 and Poly61, and my B5 provides brass. B5 and Poly61 are run thru Behringer CC300 chorus (dimension C clone). There is also some reverb, delay and compression. Enjoy
