Moog model D reissue
commodorejohn
Real name: John
Re: Mood model D reissue
Post by commodorejohn » Thu May 19, 2016 3:04 pm
Okay, somebody get me a release date for this. I have to know how long before I can own one.
And this had better not be a boutique limited-edition thing.
Post by pflosi » Thu May 19, 2016 3:08 pm
Yummie
desmond
Post by desmond » Thu May 19, 2016 4:29 pm
commodorejohn wrote:And this had better not be a boutique limited-edition thing.
Half-a-note polyphony.. ;)
adamstan
Real name: Adam
B5 DIY polysynth
KORG Poly61
Vermona DRM
Solton Programmer 24
LEMA EDD-5
Post by adamstan » Thu May 19, 2016 4:35 pm
You mean it responds to every second key you press? ;-)
garranimal
Post by garranimal » Thu May 19, 2016 5:02 pm
commodorejohn wrote:Okay, somebody get me a release date for this. I have to know how long before I can own one.
This is a limited run during Moogfest. An email from Moog said "the pilot-production units built during the festival will only be available for purchase on-site in the Moog Store by Guitar Center. " After Moogfest is over, your best guess on availability.
Jabberwalky
Band: Variar
Post by Jabberwalky » Thu May 19, 2016 5:35 pm
I can't imagine them holding out on a limited run. The demand for this will be astronomical...assuming it doesn't cost as much as a car.
alfadawg01
Gear: Ensoniq SD1, Alesis Ion, iPad2 (running Animoog, Galileo Organ, iM1, iWavestation, Mellotronics M3000HD, & ThumbJam), Roland VR-09b.
Band: The Journey Worship Band
Post by alfadawg01 » Thu May 19, 2016 6:37 pm
The term "pilot-production" implies that there could be "regular production" at some point.
wiss
Post by wiss » Thu May 19, 2016 6:51 pm
You can pre-order now (which I have), very limited run, then it won't be until November when they will be available again. Mine is scheduled for delivery around June 15th.
wiss
Post by wiss » Thu May 19, 2016 10:01 pm
Swayze
Gear: Mono/Poly, Pro-One, Juno-60, JX-3P, AX80, SQ80, AN1x, DX100, DX7E!, DX7IIFDE!, TG77, EX8000, Microbrute, Behringer D, Drumtraks, TR-08 and Eurorack
Post by Swayze » Fri May 20, 2016 12:16 am
Wow, dreams really do come true. Bob would be proud. With all the improvements they made, this will be even better than the original! It's high time I sell everything and finally start saving up for a model d.
Kenneth
Real name: Kenneth
Band: KGB
Post by Kenneth » Fri May 20, 2016 12:23 am
In the hands-on demo I watched on synthtopia, the Moog employee was saying it has CV-patchable aftertouch routing. That, friends, is badass!
AnalogKid
Post by AnalogKid » Fri May 20, 2016 12:38 am
How does this Model D re-issue differ in sound/features from the Moog Voyager Old School?
wiss
Post by wiss » Fri May 20, 2016 12:49 am
AnalogKid wrote:How does this Model D re-issue differ in sound/features from the Moog Voyager Old School?
1. This was built on the Voyager design, not the Model D's design
2. I would assume the Old School circuit board were pre-preprinted
chipaudette
Post by chipaudette » Fri May 20, 2016 3:14 am
Kenneth wrote:In the hands-on demo I watched on synthtopia, the Moog employee was saying it has CV-patchable aftertouch routing. That, friends, is badass!
Yes, but based on the video, there's no place to patch "Aftertouch" to "Modulation Amount". So, if true, you cannot do the most common aftertouch effect...you cannot do pitch vibrato. :(
Chip
adamstan
Real name: Adam
B5 DIY polysynth
KORG Poly61
Vermona DRM
LEMA EDD-5
Post by adamstan » Fri May 20, 2016 7:16 am
Chip
Probably there is no VCA on modulation bus, and instead it is routed directly through mod wheel. (which is obvious way to do things if you don't build a poly or a patch memory).
You can do manual "touch-vibrato", GX-1 style, by routing AT to pitch and wiggling your finger.
