SureRob @ Rosen Inc wrote: I'd be happy to answer anything else you'd like to know.
Y'all hiring?
What is the poblem with sockets ?Rob @ Rosen Inc wrote:Sockets for the chips are another controversy
I don't think there's a problem with sockets if you use the right ones....Push-Pull wrote:What is the poblem with sockets ?Rob @ Rosen Inc wrote:Sockets for the chips are another controversy
I often repair 106s, so mine has voice #1 on socket just to check the 80017A of the 106s of my customers. No problem until today...
That's what it comes down to.... If you can't solder, more so de-solder, don't try it. You will burn the board. You will lift traces. You will cause more problems.sam wrote:I think the sockets are a very nessersary, I have removed countless Juno at chips and the tracking is very fragile.
I see many sad cases from botched attempts on those boards...if you can't solder don't try it.
Got 3 in this week for new chips.
Top tip.....always remove the deadly foam from the pot board...and clean out the sliders.
Yes I agree, for a 106 on the road, it is preferable to solder.Rob @ Rosen Inc wrote:Some techs (respectable ones at that) say sockets cause more headache and increase the chances of dropped voices. I assume this means that there's a chance that the sockets won't hold the chip tight enough, and a bumpy car ride can unseat a chip.
I find this plausible.
True. Hot glue does the trick though. Sent one on tour with some silicone for extra protection. Not one problem on the road. I've shipped them around the world with a small dab of silicone. No problem.Push-Pull wrote:Yes I agree, for a 106 on the road, it is preferable to solder.Rob @ Rosen Inc wrote:Some techs (respectable ones at that) say sockets cause more headache and increase the chances of dropped voices. I assume this means that there's a chance that the sockets won't hold the chip tight enough, and a bumpy car ride can unseat a chip.
I find this plausible.Mine is in "studio use" only.
