Good to hear you're able to see the photos now.
I checked the image links in my postings, and they're all direct links so you should be able to see all my images in this thread.
Yes, I still have the old display, but with the cable removed (soldered to the new display).
I've ordered some new cables/connectors from eBay, so in a few weeks time I will be able to try out and compare both displays. In the meantime I hope to clear up all the confusion with the connection pinouts.
On that note I came across something interested when I searched for "Roland D-110 LCD" on Youtube. Check out the comments to
this and
this video! They both confirm my findings that each row of pins on the LCD are swapped (i.e. 1 and 2, 3 and 4 etc). I assume they mean in comparison to the pinout numbering on the LCD displays (both my old and new one has the same placement/numbering of the connection pins on the PCB).
This means that I've probably fried the new LCD, because I checked CN1 (LCD connector on the D-110 circuit board) and the voltage polarity is correct according to the schematic (pin 1 marking on the PCB is +5V and pin 2 is GND). I'm not sure how to check the rest of the signals, but at least this confirms that I've applied the reverse polarity. This is assuming that the pinout in the new LCD documentation is correct.
About the backlight: given the IMHO confusing instructions in the new LCD documentation I haven't yet dared to apply power to it, but I think they might mean that there are connection pair options: one for attaching +5V (meaning there's a resistor to pass through on the LCD circuit board), and another connection which goes directly to the LED backlight with the correct power (in the old days this was something like 2V or so IIRC). I'm going to take a closer look at the circuit traces and I think it might be quite harmless to test it with say a 1.5V battery just to see if it glows.
To conclude all my talk
..... I really would like to hear from someone who has successfully replaced their D-110 LCD in regards to the connection pinout.
Also, if my new LCD turns out to be fried, are there compatible LCDs with a pure green LED backlight (like the original LCD)? The one I ordered is yellow/green and I couldn't find any green version at that site with the same specs.
UPDATE: Robber1956, I see you posted the pinouts earlier for a different display. Is that pin swapping in relation to the pinouts of the original display (in the D-110 service manual), meaning that the pin numbering/signal description of the CN1 connector (see below) is correct?
