Akai AX-60 Custom Firmware (Akai AX60)
Conjure
Re: Akai AX-60 Custom Firmware (Akai AX60)
Post by Conjure » Wed Jun 14, 2017 6:40 pm
Hey all,
Awesome thread, thanks! If it's possible, I'd like to request this feature:
-Saving MIDI Channel after the synth is shut off. I can switch my AX60 to any channel, but if I turn it off and back on, the channel is reset back to 1. Any way to make it permanent, until changed?
I've verified this with some other AX60 users as well.
Thanks!
Rasputin
Post by Rasputin » Thu Jun 15, 2017 2:56 pm
Conjure wrote:Awesome thread, thanks! If it's possible, I'd like to request this feature:
Haven't totally explored the memory map of the AX60, but that would probably be achievable. It's not the type of thing that's difficult to implement, it's just a matter of finding the space to put it, really.
I haven't worked on this firmware anymore since my last post, although I've been keeping my eyes peeled for a super cheap AX60 as getting some old beater to fiddle with is probably the only way I'm actually going to get anywhere significant with the idea, and even then I wouldn't hold my breath.
lahatte
Post by lahatte » Wed Oct 25, 2017 3:49 am
I agree with the "awesome thread" comment. I have an AX60 that I have yet to touch (remodeling the house). I look forward to what may develop on this. Would this mod also apply to the VX90?
Thanks for the smarts!
Rasputin
Post by Rasputin » Thu Oct 26, 2017 12:20 am
lahatte wrote:Would this mod also apply to the VX90?
Not directly, but it could make it easier as that whole series is related. But each firmware is unique which means (at the very least) it has to be disassembled separately.
I don't have access to the VX90 firmware so I can't say anything too specific about how feasible it is.
lahatte
Post by lahatte » Thu Oct 26, 2017 12:53 am
Thanks for the information.
wjmwpg
Real name: James
Gear: LoveRock, T40, MG500, JX10 4.0, D-50, Juno 60, VZ10M, CZ1, HT6000, K3m, SX240, Lambda, DSS1, Yamaha SY2, DX11, SQ80, MultiTrak, SammichSID
Band: Gospel Choirs
Post by wjmwpg » Sun Dec 17, 2017 7:14 am
Just another friendly voice applauding your efforts.
FYI, if you’re not already aware, Bob Grieb did a great reworking of the Akai AX80 firmware. Might be a good resource to answer questions if you get stuck. I realize it’s not the same synth, but perhaps the code will be similar as they’re both 80’s Akais.
http://tauntek.com/AX80.htm
sirdidymus
Post by sirdidymus » Fri Mar 16, 2018 2:44 pm
Just FYI, another AX-60 owner/user here, and I would be very interested in the progress of this idea. Keep us posted!
SD
wjmwpg
Real name: James
Band: Gospel Choirs
Post by wjmwpg » Mon Jun 25, 2018 11:12 pm
So I have finally found and purchased an AX60 after so many false starts. (I’ve never had so much bad luck hunting for down a synth!)
So anyhoo, just curious if there has been any progress on this firmware revisit front.
Also, for those with samplers connected to their AX60’s, would you recommend S612’s over S900’s or S950? Just curious which I should be after and I know little to nothing about samplers.
themilford
Real name: David
Gear: Oberheim: OB-8, DSX, DMX, DXa, Yamaha CS-15, Akai AX-60, S612, Moog Taurus 3, Alesis MMT-8, HR-16, Fender Bass IV, Rickenbacker 620/6, Crumar Trilogy
Band: Season Finale
Post by themilford » Wed Mar 06, 2019 7:53 pm
Bump. Just wondering if there has been any movement on this.
Rasputin
Post by Rasputin » Thu Mar 07, 2019 3:11 pm
themilford wrote:Bump. Just wondering if there has been any movement on this.
I never ended up with an AX-60, and no other good opportunities arose, so not really.
astraldeeps
Post by astraldeeps » Fri Mar 08, 2019 10:14 pm
Such a bummer. There is a lot that could be done to this synth that would take it to another level. I think a Dual mode like the AX73 is an obvious yes, because it can actually be done with some midi tricks, and sounds great. My main gripe, is that most don't know this but you can send midi out of the synth when the Arpeggiator is running if you press the Sample button (no S612 needed) but it will send the 6 notes sequentially over 6 midi channels. With unison on, I believe, it sends over one midi channel. The bummer is, that you can only play the arpeggiator, and the S612/AX60 combo, via the onboard keyboard and not with external midi. THIS, to me, would be the #1 mod. The AX60/S612 combo sounds truly incredible (try sampling some FM mod bell sounds from the 60 into the 612, then run it back into the synth and run a square wave patch, you get an extremely nice electric piano sound). If this could be sequenced, the synth would be on a WHOLE other level. Especially with the Arpeggiator...so much could be done with this. I understand people wanting CC control but to me that doesn't matter much, you actually have CC control of the filter with the Pitch Bend wheel, at least that's something. The most glaring problem with this synth is its lack of midi input/control when it comes to the Arpeggiator and S612 combo.
themilford
Real name: David
Band: Season Finale
Post by themilford » Tue Mar 12, 2019 5:27 pm
astraldeeps wrote:Such a bummer. There is a lot that could be done to this synth that would take it to another level. I think a Dual mode like the AX73 is an obvious yes, because it can actually be done with some midi tricks, and sounds great. My main gripe, is that most don't know this but you can send midi out of the synth when the Arpeggiator is running if you press the Sample button (no S612 needed) but it will send the 6 notes sequentially over 6 midi channels. With unison on, I believe, it sends over one midi channel. The bummer is, that you can only play the arpeggiator, and the S612/AX60 combo, via the onboard keyboard and not with external midi. THIS, to me, would be the #1 mod. The AX60/S612 combo sounds truly incredible (try sampling some FM mod bell sounds from the 60 into the 612, then run it back into the synth and run a square wave patch, you get an extremely nice electric piano sound). If this could be sequenced, the synth would be on a WHOLE other level. Especially with the Arpeggiator...so much could be done with this. I understand people wanting CC control but to me that doesn't matter much, you actually have CC control of the filter with the Pitch Bend wheel, at least that's something. The most glaring problem with this synth is its lack of midi input/control when it comes to the Arpeggiator and S612 combo.
Agreed. This is everything. The strength of the AX-60 is it's pairing with the S612. So streamlining that would be invaluable. Just curious, have you used the S700 with the AX60? I have both but yet to try it. Also, the VX90, wondering if it's midi implementation is improved for paring with the Samplers.
astraldeeps
Post by astraldeeps » Fri Apr 19, 2019 11:00 pm
No I have not, I've wanted a S700 since my S612 died and I assume it probably works pretty great with the AX-60. My friend has a slightly wonky S900 that I wanna try out with the 60 as well.
I'm wondering, would it be possible to add CV inputs for each voice? I know that's rare for poly synths (though obviously early ones relied on that i.e. the prophet 5). I'm just wondering why its impossible to play the arpeggiator via external midi, or the keys in general and I'm wondering if maybe it would be possible to override this by using CV if you had a modded unit. Although modifying the OS/Eprom would probably be the most sensible, I really don't know what I'm talking about with these mod ideas...but I know there is LOTS of potential.
Does anyone know just WHY you can't play the arpeggiator, or the sample combo when sampler in is engaged? It's by far the most confusing and frustrating thing. I won't stop until I figure out a solution!!!
Luckily I met someone who is very skilled at repairs and modifications of vintage analogs and he seemed interested in the task, though hes incredibly busy. :/
rlg42
Post by rlg42 » Sat Dec 21, 2019 5:05 pm
Hello,
For the past few weeks I have been studying the AX-60 V1.2 firmware and schematics to see if some sort of firmware update was possible. Unfortunately, there are only 52 bytes free in the EPROM, and the address decode for the EPROM is only 8K byte (2764). The 8K just above the EPROM is used for the 8253 timer, so there is no simple mod to allow using a larger EPROM to get more code space.
The pot code is unusual in that it has a countdown timer for each pot. When the timer is counting down, the pot only has to move 2 counts out of 256 to change the parameter. But after the timer has counted down to 0, the pot must move at least 5 counts, and it has to move that much in between two successive reads of the pots, in other words the pot has to move quickly in order to change the parameter. Once that happens, the counter starts counting down again. I am still working out how long it takes the timer to count down to 0. I think it may be a second or less. This seems an odd choice and would be easy to disable without taking any room.
Another change that would not require much space would be saving the MIDI channel when power is turned off.
It might also be possible to add MIDI ARP clocking in the space remaining, although the divide rate may be fixed at 24 PPQ or something. I would need to confirm this.
So those two or three things may be possible to address with just an EPROM swap. That would be one option.
Another option would be to design a small pcb for a larger EPROM and some logic to modify the address decoding to give another 4K of code space. This would require removing a 16-pin chip from the CPU board, installing a socket in its place, and then plugging a DIP header from the EPROM board into the socket. The EPROM board would be plugged into the existing EPROM socket. Requiring this type of mod would put the upgrade out of reach of many people, as they may not want to spend money on the AX-60 to hire someone to do it.
Having plenty of code space should make it possible to implement MIDI CC support. On the other hand, the AX-60 is hard-wired for a 4-2 split. By controlling which patch is used for each part, with that hw split, you can get 0-6,6-0,4-2, and 2-4 so it's easy to understand why they did it. Anyway, it's impossible to get a 3-3 split, or three layered voices, since the hw doesn't support it.
Other things that could be implemented with more code space would be changing the response curves for individual sliders, which some people have accomplished by adding resistors to their units. The calculations in the AX-60 to map sliders to CV's tend to be fairly simple. I don't see any lookup tables being used as in some other synths.
So why am I writing this? I am looking for opinions on which type of upgrade makes the most sense. Which type people would be willing to implement. I am also looking for good ideas for improvements that are easy to implement. There is no financial reward here, so I am looking for "low hanging fruit". This means adding features, not an entire re-write of the firmware. Something like adding layered mode, or MIDI out from the arpeggiator is probably too much work to make sense. Also, I need to be careful not to add code that weighs down the CPU. I don't want to degrade normal operation.
I will need testers to try out any new code and help me flush out any bugs. If you have an EPROM programmer, that would be a big plus, of course.
If you are interested, please contact me via Tauntek, not here, as I would like to have a record of any correspondence.
Thanks, Bob Grieb
themilford
Real name: David
Band: Season Finale
Post by themilford » Tue Apr 21, 2020 2:09 am
Hello,
This is a "feature" they explain in the manual... but it always baffled me. I like the way the dot next to the patch appears when edited in order to know for reference... but I wonder if these are connected somehow? Also, this dot feature seems to be dicey as it will sometimes just chance... I wonder why?
This would RULE... it's totally annoying. Can you do this for my OB-8 too ;)
Also awesome, I wonder if there are workaround for the PPQ... I'm used the Oberheim standard... but I think most sequencers can set this anyway, so it might be moot.
Thanks, Bob Grieb
I'll drop you a line... hoping this is still in the works. I hope to have my studio up and running again. I use both the AX-60 and the S612 pretty extensively and would love to help with testing. My business parter is an EE and has done some repair on my AX-60... So we might be able to do some work on our end as well. It might also be helpful to look at the VX-90/AX-70 firmware... as it is an updated version. of the VX-60 and might show how some other features are implemented in a different form factor (no knobs, menu etc.)
