Motavis wrote:i_watch_stars wrote:LOL...who cares? I just get cheap HOSA cables. It really only matters if you have long cable runs, or stuff that is going to cause heavy interference, right?
As I mentioned I am getting a hisssssssssssssssing. So I am looking perhaps
from what you said something to keep the interferences down or the hisssing.
Oh ok...well how long are your cable runs? All my cables are six feet or less, usually 3 feet. Keep in mind that balanced cables only work with balanced gear and a completely balanced signal path. Also, the balance/unbalance of your cables should be irrelevant if you don't have long cable runs.
Other than that, keeping cables away from powercords, or at least not parralell, helps.
If all else fails, and its still there, its probably gear related in which case, well, that sucks right?
