Question about CV/Gate cables
supermel74
Post by supermel74 » Sun Jun 03, 2007 11:26 am
Are they just standard 1/4 inch cables? Any recommendations either way?
nathanscribe
Post by nathanscribe » Sun Jun 03, 2007 11:47 am
Either that, or standard 1/8" minijacks, depending on the gear. You can use any standard cables, or make your own using the regular stuff. I make mine using thinner, shielded audio, cable. The Kenton units have mini-jacks on them, but many synths have 1/4" sockets, so I have a range of lengths and a mixture of ends at hand. You can never have too many cables... :lol:
EDIT: one thing you might want to do is use twin-core, the fig. of 8 kind where each core has its own sheath/shield - and you can pulll them apart. That way, you can make one cable that does both CV & gate, and it's all a bit neater.
supermel74
Post by supermel74 » Sun Jun 03, 2007 12:15 pm
Cool thanks.
Zonkout
Gear: Salad Shooter, Flowbee, Marsona 1200, Jetta TDI, Original Jams, VCR
Band: Low Red Center
Post by Zonkout » Mon Jun 04, 2007 4:27 pm
You need to make sure to use mono plugs, too.
________________________________________
I own some key boards and rhythmic boxes.
Spaceheater184
Post by Spaceheater184 » Mon Jun 04, 2007 7:48 pm
UNLESS you have a Moog Source, which requires a stereo to mono L-R cable in order to work. The jack on the back of the Source has Gate on the ring, CV on the tip.
Gear: Korg EMX, Yamaha CS1x.
CloudOnAFly
Post by CloudOnAFly » Mon Jun 04, 2007 9:49 pm
...hosa's are great for patch cables...they're cheap, and seem to work well at what they need to do :D
...simply put..
Metasonix is the choice for all self respecting meta-humans...
(meta-humans currently known are trolls, orcs, dwarves, dragons.....)
nathanscribe
Post by nathanscribe » Mon Jun 04, 2007 9:50 pm
Spaceheater184 wrote:The jack on the back of the Source has Gate on the ring, CV on the tip.
It's not the only oddity in this respect - but I believe the original poster is using a Yamaha CS and a Bass Station, which use regular mono jacks, although it's necessary to also check the compatibility of CV and Gate voltage systems.
