For those of you with more than 4 synths...Studio Setup?
For those of you who have more than 4 synths/keyboards/modules, etc - how do you have them connected, audio-wise? Do they go into a submixer? Do they all go in a regular mixer? Do you just plug them into your audio interface when you need to hear/record them? Do you use a patchbay? How do you set it up?
- michael stein
- Band: S U R V I V E
- Analog Freak
I use a Carvin C2400 mixer for everything. Every synthesizer, module or effects unit goes through it at some point. In all honesty, my rackmount gear has so many audio connections that I'm going to have to bring in a rackmount mixer and use that as a submixer before too long. I'm also thinking of getting a patchbay, although I'm not sure that it's really needed. Anyway, after the mixer, I route the main outputs to the monitors (in actuality a nice stereo system) and the other bus outputs go to my laptop for processing or recording. It might not be the ideal solution, but it has worked well for me. What exactly are you trying to do? I might be able to offer more suggestions if I knew what kind of problems you are trying to tackle.
- brian.only
- Gear: Mono/Poly, Polysix, Crumar Performer, Juno106, Ion, CS01, K Station, DX27,77' Rhodes 88 mk1
I have a 14 channel mixer I plug most into- others, The ones I tend to perform w/ live I have set up on a stand exactly like I would when I perform. Those I tend to run directly into my audio interface which has 8 ins.
The mixer is nice as I can boost and eq the signal on some of the lower output synths/instruments as well keeping the overall cord mess down by running a stereo set of xlrs to my interface for that side of the room.
I will also sometimes run the synths through an amp and record them w/ a microphone which will get sent through the mixer.
I tend to not leave things plugged in electrically( my wiring is a bit old and ya never know...), but will leave all the patch cables plugged in generally.
Every few months I'll switch gear around to liven things up and pare down what I have'nt been using-its also a good time to clean everything- dust is the end of electronics...
sell me your KS5!
- Tyler2000
- Gear: HS-60, MG-1, CS-5, ESQ-1, CZ-101, DR-110, MR-10, MDP-40, EA-1, ER-1, ES-1, Trixer, SDS-9, Califorian 365, toys, guitars, ukes, etc.
Currently I run run all my synths (HS-60, MG-1, ESQ-1, C64) through my Yamaha EM-90a 6-channel mixer and into channel 1 of Peavy KB-100 keyboard amp which has 3 channels.
Also, I run all my sequencey/drum machiney stuff (ER-1, EA-1, MDP-40, DR-202) through a 4-channel boss mixer and into input 2.
There is something plugged into input 3 on the amp but I can't figure out what it is. Not that I've tried. I just moved in and I've got myself all confused about what I'm doing.
All of that will be changing soon though. I have an 8 channel rack mixer on it's way to my door. Honestly, though, I'm probably going to turn around and sell it (unless I fall in love with it) and get a 12 channel for the same price. Damn inpulse e-buys. Anyway, it will have 2 set of aux sends for all my effects so I'm pretty pumped about that. Still, with the rack mixer I'll probably end up using the sub-mixer for drums.
Anybody got a 12 channel rack mixer for sale?
Anybody want to buy an 8 channel?
anybody want to trade?
so what do I put down here now?
- Tyler2000
I'm appear to be different to the others, I've got a 10 I/0 card in the PC and go straight into that. It used to be a pain but support for external instruments in Cubase4 is much better than it used to be. I create a track for a synth the same way as a plugin synth. It remembers all the routing and gives me 1 track to look at in the arrange page. All (!?!) I need to do now is create device panels for my outbord gear and I'll have access to my analogs with the same flexibility as VST plugs. I should point out that I only have 1 non midi analog. I also record with two bands so need to recall mixes pretty much randomly so an analog desk is out of the question for me. I used to have an 01v which was great but when you start adding analog I/0 it starts getting expensive and once you use more than the 16 front panel faders and have to start hitting shift keys, you might as well be mixing on the computer.
Q, Pulse, MW1, CS60, MEK,
- hageir
- Expert Member
- Gear: http://www.geirhelgi.com/
https://soundcloud.com/geir-helgi - Band: Geir Helgi
do any of you gus record a flat 2-track straight out of the mixer?
you can't fix anything later on, how do you work around it?
just record everything over and over again until it's perfect? -you nuts?!
- hollandturbine
Synths--->Patch bay--->Sub mixer--->Patch bay--->Sound card in 1&2
Last edited by hollandturbine on Tue Jan 08, 2008 3:52 am, edited 1 time in total.
Try and get a little sub mixer with an extra subgroup out like the Yamaha MG’s or something with a PFL (pre fader listen) as this will allow you to isolate the channels you want recorded to a separate output whilst hearing the channels you don’t.
On my old Spirit I used the monitor outputs as the recording channel so I just pressed the PFL button for any channel I wanted to record which bypassed the mixer effects, EQ and fader level so the soundcard was getting a nice clean dry signal to record whilst I heard the sound being recorded in the context of a mix with all the other sounds, a little unorthodox but a good work around if you’re recording on your own using only synths.
Getting the sounds both inside and out of your DAW to sync perfectly is another matter.
- TrondC
- Gear: Machinedrum UW & Monomachine Mk2's
Korg KP3 & Zero 4 - Band: Siesta Submarina
that's pretty much what I do.., but then again, I have no other way to record everything in proper stereo, as my recorder has 4 mono tracks only..hageir wrote:do any of you gus record a flat 2-track straight out of the mixer?
my next purchase will probably be some nice kind of software and an interface so I can start recording my gear properly, and also then I can finally start putting tracks on the internet again
- redchapterjubilee
I have 6 sound sources and they run into an Alesis 12FX mixer then stereo out into my soundcard. That's the same scenario live too.
- pangmaster
- Real name: Nathan
- Gear: Voyager, PEK, A6, FIZ, Six-Trak, Juno, CZ, and other stuff
All my synths go into a patchbay, with the first 8 outputs of the PB being normalled into the 8 inputs of my interface. I have the 4 stereo pairs of my most used synths in these first 8 outputs so I don't have to patch them in. The rest of the gear is wired up mono (6 other synths).
"To be human, to be fully human, is to need music and to derive nourishment from the music you hear." - Bob Moog
