EQ with spectral analyzer?
Posted: Tue Apr 22, 2008 4:05 am
by pricklyrobot
I'm pretty new to recording and such, so I'm thinking it might be good to have an EQ that gives me some visual, as well as audio, feedback. Specifically something that gives me a visual representation of what frequencies are in a track, so I can see, as well as hear, the changes that are happening as I change EQ settings.
I did a Google search for 'EQ with spectral analyzer' (not sure this is the the most accurate terminology, but it was the best I could come up with). I found some references to Presonus EyeQ, but couldn't actually find it for sale anywhere (maybe it's not actually released yet?) Then there's Izotope Ozone, which looks like it does what I'm after, plus a bunch of other stuff, but costs $250 (not sure I'd get enough use out of it to justify that price).
So does anyone know of a more bargain-priced application that does this? Preferably something that would work as a plug-in in ProTools M-Powered.
Re: EQ with spectral analyzer?
Posted: Thu May 01, 2008 2:11 pm
by derma_tek
pricklyrobot wrote:I'm pretty new to recording and such, so I'm thinking it might be good to have an EQ that gives me some visual, as well as audio, feedback. Specifically something that gives me a visual representation of what frequencies are in a track, so I can see, as well as hear, the changes that are happening as I change EQ settings.
i highly recommend roger nichols INSPECTOR, it's only a spectral analyzer but at least then you are free to use whatever eq you like in combination with it. plus IT'S FREE.
http://www.rndigital.org/inspector.html
as far as eq's go, even though they aren't exactly budget eq's, i'm a big fan of the URS eq's. they have some really great plugins.
http://www.ursplugins.com/
Posted: Thu May 01, 2008 2:45 pm
by pricklyrobot
Inspector looks cool (I suppose it wouldn't be too hard to have an EQ and the analyzer open at once and just jump back and forth between the windows, to get an idea of how one is effecting the other), and you can't beat free.
Posted: Thu May 01, 2008 6:32 pm
by derma_tek
pricklyrobot wrote:Inspector looks cool (I suppose it wouldn't be too hard to have an EQ and the analyzer open at once and just jump back and forth between the windows, to get an idea of how one is effecting the other), and you can't beat free.
the sonalksis eq's are pretty awesome as well, and cheaper than the urs stuff.
http://www.sonalksis.com/
Posted: Fri Jun 27, 2008 9:41 pm
by TheBeezus
http://www.apulsoft.ch/apeq/
I use this religiously.
Posted: Fri Jun 27, 2008 10:08 pm
by GeneralBigbag
Voxengo's SCAPE is free, as is ElectriQ.
Posted: Sat Jun 28, 2008 12:36 am
by MitchK1989
I'd put a spectrograph type plugin both before and after the EQ. Then you can put one above and one below the EQ GUI.
Posted: Mon Jun 30, 2008 12:25 pm
by krushing
BF wrote:Just my humble opinion, but skip the visuals and learn to trust mixing with your ears rather than second guessing with your eyes.
Ditto. Spectrographs can be comforting to look at but are 1) rarely accurate 2) usually lagging behind and 3) mostly useless in the low end (the size of the FFT window used to calculate the values has to be reasonably small for these to be any use and in the lower frequencies the waves are quite simply too long to fit in this window, simply put) - which is quite often the most problematic area when mixing.
Use your ears.
