Fatso demo (I'm renting one)
Ok - this thing works.
I have yet to track, but I used it as a buss compressor on the final mix of THJ.
Technical details:
Both tracks are processed with a Kjaerhus Classic Master Limiter for about 1-2 dB of gain reduction, and they have a tiny bit of stereo widening. This processing is on the final mix, so post-fatso on the After file.
The Fatso track uses the Buss compressor mode, taking off about 1-2 dB, and the high saturation is taking about 3-4 dB off of the high transients. The transformer is on, and the input is high enough to cause about 1% THD on transients.
http://ookpikk.googlepages.com/Before.mp3
http://ookpikk.googlepages.com/After.mp3
Technical details:
virb.com/ookpikk
Re: Fatso demo (I'm renting one)
It does work...I hear it in the BD and bassline... but, man, the average person isn't going to be able to tell any difference. I guess I'm a little above the average person these days when listening...so I notice. However, I really wonder if it is worth it for those of us not putting out records or with a few handful of listeners. I'd love to hear more demos.GeneralBigbag wrote:Ok - this thing works.
Technical details:
- supercluster
yeah definitely noticed immediately in the bassline, however i expected something a little bit more for some reason. A nice change, but I do question how much the average joe would notice.
Doepfer A-100, MPC1000, Alesis Ion
Roland Re-20, Moog MF-105, Moog MF-102, boss me50-b
For sale: Yamaha RS7000, Korg Kontrol49
- Architecture
- Gear: TR909, TR808 Dot Com, Moog LP. x0xb0x, Andromeda A6, AX60, SQ80, EPS, DSI PEK Pot Edition, ASR10, Juno 60.
- Band: Architecture!
Yep, I'm a below average listener here... but in the regular world...I can tell things my friends cannot.Architecture wrote:the average listener on VSE is far more discerning than the average listener.
For goodness sakes, a good majority can tell the difference between analog and digital here, the average joe would be like whatever give me my 128kbps mp3 please.
- Stab Frenzy
Just because you don't think that the 'average listener' (whoever that is) will notice the difference it doesn't mean you shouldn't strive to get that extra 1% better on all your tracks.
I always try and make everything as good as I can, maybe most people won't hear the difference but I'm gonna do stuff cause I can hear the difference, which makes it worth doing.
Whether or not I'd spend a certain amount on a device that just gave me that 1% or not would really depend, and I guess it's up to the individual.
True, I try to make each batch of songs sound better than the last. but the average or below average VSE-er needs to factor price vs. reality no? The reality is that you can spend an awful lot of money on things to make your recordings slightly better... and the same few dozen people will listen and give you the same feedback. Once you become better than average, and alot more people start listening to your stuff...then you can go for the expensive stuff that does the little things. I can still make my stuff sound so much better with the tools I already have... so for me, I don't want to rely on expensive boxes unless I truly know what I'm doing. Just a thought. That said, if you have the money to spend, then do it. I have no issue with that. The flip side is that you need to know what to do with the tools. easier said than done.Stab Frenzy wrote:Just because you don't think that the 'average listener' (whoever that is) will notice the difference it doesn't mean you shouldn't strive to get that extra 1% better on all your tracks.
I believe the general is doing this because he is releasing his music officially in hope of reaching more than forum dwellers and friends. To me, that is worth it then.
- shaft9000
- Real name: Dave
- Band: moneymoneymoney
idea:
take the processed mix and the unprocessed mix and splice them together every 4-8 bars, alternating between the two. this should make the differences very obvious.
then play it in a car stereo w/ good bass power.
Play it in a car stereo - if it's the type of music you expect people to typically listen to in a car. Of course it's good if your mix sounds good on a car stereo, but there's tons of really well-mixed music out there which is the fail in a car.
And, FWIW, this box may cost $2800 in Canada, but you can rent it for a whole week for $80 inc tax. A week is a lot of time if you have all of the raw audio already down.
virb.com/ookpikk
