taking your moogerfoogers out...
smallsynth
Gear: jp03, dx21, bass station, k-station, gnat, buzz, cs01-mkii, eml-101, eh-401
Band: resterisk
Post by smallsynth » Tue Nov 25, 2008 6:19 pm
want to take care of my moogerfoogers because
they look and sound so nice. they are also
cumbersome and the power source is
annoying (no battery, reverse plug).
so instead of
taking my moogerfoogers out to shows, i'm thinking of
taking my moogerfoogers out of my live setup.
does anyone have cheap alternatives they recommend?
analog delay?
phaser?
there are quite a few cheap ones out there,
so a few suggests would be nice.
i would like them to be simple, and small.
analog for the delay. and for the
phaser, i use it mainly for very fast and
exaggerated sounds -- experimental land.
thanks,
geoffrey smallsynth
Bitexion
Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Re: taking your moogerfoogers out...
Post by Bitexion » Tue Nov 25, 2008 6:44 pm
Get some "guitar" pedals. They're easy to carry around, runs on batteries, and sound great. Like the Electro-Harmonix stuff. They have many phasers and delays and whatnot. Their Smallstone phaser is probably the most well-known among synth heads since it makes the trademark swirl sound of Jean-Michel Jarre's early albums.
All analog electronics, no fake digital stuff.
aXL
Gear: Moog LP Stage II, Ensoniq ESQ-1, Nord Electro 3, Roland JP-8080, Akai SynthStation 49, numerous softies...
Band: Nemesis Kane
Post by aXL » Tue Nov 25, 2008 6:58 pm
The Boss RE-20, like most Boss pedals, is built like a steel brick. If you're looking to replace an analogue delay unit, it's probably one of the better options if durability is the main concern. The reverb, though a bit limited, isn't that bad either.
And yes, I know it's digital, but it's modelled after the original RE-201 tape echo. And IMO, Roland's COSM modelling isn't that bad.
Sir Nose wrote:It's like sex with or without a condom. You know which choice is gonna feel better, but it's not always a wise choice.
Disciples of the new wave, portaits in the sand...
synth3tik
Gear: Pro One/Prophet 2002+/Prophet 08SE/Cat/M1/Poly6/Jupiter6/JD-990/SidStation/SE-1X/Microwave II/Matrix 6R/S3000/S612/Source
Band: Batteries Aren't Food/J.a.F.a
Post by synth3tik » Tue Nov 25, 2008 9:16 pm
When I was originally looking for an analog delay I wanted the Moogerfooger, but it was just way too much money. I ended up grabbing a Memory Lane pedal by the company Diamond for like $250-275ish. Great delay and modulation.
smallsynth
Band: resterisk
Post by smallsynth » Tue Nov 25, 2008 10:53 pm
thanks for the suggestions so far...
i used to have a small stone (i sold it to some one here...), but it couldn't get crazy enough for me. i use the mooger on the more experimental parts, so i need to have a little more from the pedal. i need rate, depth, and what i refer to as the crazy, though this is often labeled as something else on the pedal.
as for delay, i guess you get what you pay for, huh? nothing between 50 and 100 that works and sounds good? am i better with digital at that price point? maybe i have something around i can use.
-geoffrey smallsynth
nathanscribe
Post by nathanscribe » Wed Nov 26, 2008 12:55 am
MXR Carbon Copy (not used one but the demos look good)? The new Boss DD-7 has analogue emulation mode. Also consider PT2399-based pseudo-analogue delays like the Biyang AD-7. They sound good.
As for phasers, I hear good things about the EHX polyphase. If you can find an old Boss RPH-10 it has plenty of control and switchable stages (6,10 or 12), is analogue, and is cheap. But you'd have to find one. and it's not a pedal, it's a microrack.
pricklyrobot
Post by pricklyrobot » Wed Nov 26, 2008 1:16 am
nathanscribe wrote:Also consider PT2399-based pseudo-analogue delays like the Biyang AD-7. They sound good.
Here's another PT2399-based delay, if you're into DIY at all: http://www.buildyourownclone.com/pingpong.html, they also have an analog delay coming out shortly: http://www.buildyourownclone.com/analogdelay.html
I don't have any of their delays yet, but I've built other BYOC kits—including the phaser which sounds quite nice (although it's a Phase 90 clone, so probably better for classic sound than for crazy)—and found them to be very well put together, and easy for beginners.
If you decide you just want a cheap, digital delay, the Digitech Digidelay sounds decent enough to my ears, has several fun options (mod, reverse, etc.), and can easily be found used around $50.
Post by Stab Frenzy » Wed Nov 26, 2008 1:22 am
I'm gonna move this to Sound Production, where all the interesting threads live. :thumbright:
I've found that a lot of guitar pedals either can't handle a synth's line level signal, can't get a wet enough effect or don't have enough range for tweaking to get the sounds I like. When we gig we use a Russian Small Stone for phasing duties, but that's what we use in the studio anyway so it's not a compromise for gigging.
For delay we use a Behringer digital delay pedal for one synth and an Eventide Timefactor (formerly an RE-20) for the other. The Behringer sounds great for a straight digital delay, although if you tweak the delay time it cracks up rather than pitch-shifts, which could be a dealbreaker for some. The Timefactor is mindblowing but it's pretty expensive too, although still about half the price of the Moog (over here at least). It doesn't do a BBD delay though, but the tape is fantastic. It also has a Mod delay which is like a delay with phasing/chorus on the feedback loop, which could give you your delay and phaser in one. The sound quality is a step above the RE-20 which sounds muddy in comparison, although the RE-20 delay algorithm does sound good. The Eventide won't run off batteries but most good delays will either chew through batteries at a rate of knots or not even give you the option.
I'd be keen to hear what people who've used the Maxon 999 delay have to say about it, also the Ibanez AD-9 is one I've wanted to try out for a while. The Diamond Memory Lane looks great but the v.2 is more expensive and has apparently had the feedback tamed a bit for less spaceship noises, which is a negative in my book. I've played with a Deluxe Memory Man a few times and it seems like a decent analogue delay, I could get quite a few good sounds out of it but it's never blown my mind to the point where I just had to buy one. It's got the same thing with the no batteries and it's $300, but I reckon it could be the closest to the MF-104 for gigging purposes.
edit: Is this for your Yamaha organ? Ours outputs at guitar level so works great with guitar pedals and opens up a lot more options. I'd check out the Ibanez AD-9 if it's for that.
I've got a Biyang AD-7 and it's kind of cool, but the feedback path seems to be bandpass filtered so it doesn't sound much like an analogue delay. Also it doesn't freak out in a way I like when you crank up the feedback. It has its uses, but not as a direct replacement of a BBD delay IMO.
stikygum
Post by stikygum » Wed Nov 26, 2008 5:50 am
I don't know, I just saw the band ohGr the other night and they had a LP and a Moogerfooger - sounded like it was the Ring mod one. And live, it sounded grrrrreat! The LP sounded pretty dang good. But it looked even sweeter. Man is that a gorgeous design.
clusterchord
Real name: Tomislav
Band: Nimbus Dei
Post by clusterchord » Wed Nov 26, 2008 6:41 am
get EHX Small Stone for phasing duties, and a small echo pedal like Ibanez or Maxon AD9/MXR CarbonCopy/EHX Echo etc..
of course, Polyphase and Memoryman are real nice, but it kinda defeats your original idea to scale down - as these are also valuable/expensive, need power socket, and are barely smaller than mooferfoogers themselves.
mind u , 4-stage small stone is not the same sound as 6/12-stage MF-103. i got both, and btwn the two, i think you are covered for almost any classic phasing sound you can think of.
code green
Gear: prophet 600/evolver/juno 6/alpha juno 2/bassst'n/crumar performer/jv1010/suitcase rhodes 73/ '78 gibson l6-s/'73 guild mahogany/'69 fender princeton
Band: thermite zapruder
Post by code green » Wed Nov 26, 2008 9:10 am
the dd-3 is under $100 and gives forth liquid, gorgeous delays...and plays well with synths. i have the mf analog delay in my studio but gig with the boss. love it.
Carey M
Gear: Akai Miniak, Fender Chroma Polaris, Moog Sub Phatty, Roland SH-101, Roland Jupiter-4, Sequential Circuits Prophet-600, Komplete 8, Reaper, iPad, beer
Band: Nightsatan
Post by Carey M » Wed Nov 26, 2008 10:13 am
Maxon AD-999 and Maxon PH-350. Super simple, yet versatile (especially the Phasor), sound great.
- CM
redchapterjubilee
Post by redchapterjubilee » Wed Nov 26, 2008 2:01 pm
I'm gonna go to h**l for saying this...
Line 6 Echo Park. Built like a tank, has tons of options (analog & tape emulation, modulation, reverse, stereo, tap tempo, etc.) Pretty much everything the big green pedal has except for looping. and you can get these used for under $100 no problem. Eats batteries but I daisy chain it so no worries.
As for the phaser. I'd look at Boss's green phaser. If I recall right it shifts between 4 and 6 pole phasing. I always liked the Small Stone or Phase 90 but both of those are smooooove. If you aren't stomping on it maybe try an Alesis Faze? It can get crazy and does stereo asynchronous phasing.
tallowwaters
Gear: LC-MS/MS
Post by tallowwaters » Wed Nov 26, 2008 6:49 pm
redchapterjubilee wrote:I'm gonna go to h**l for saying this...
Behringer actually cloned the echo park in a 30 dollar pedal. Cant remember the name...
novielo
Gear: in order of appearence:
sh2000 s612 nord modular mpc1000 kp3 ms-something cp-251 gameboy s6000 and other crappy stuff
Band: one-man band
Location: by the river, st-jerome, quebec, canada, north america
Post by novielo » Wed Nov 26, 2008 7:11 pm
i think you're talking about the ECHO MACHINE EM600
