booming bass help
muhammed
booming bass help
Post by muhammed » Mon Nov 30, 2009 1:37 pm
I recorded bass from my ms 20 but ı couldt mix it. ı dont know how to deal with booming bass sound.
I have big issue with software equlaziers. What am ı suppose to do . should ı buy hardware eq ?
here is my awful record http://rapidshare.com/files/314257861/U ... 0.wav.html
tallowwaters
Gear: LC-MS/MS
Re: booming bass help
Post by tallowwaters » Mon Nov 30, 2009 2:44 pm
Couldn't get the D/l to work, but I am going to guess that you should pull your 20-50 Hz down a few.
muhammed
Post by muhammed » Mon Nov 30, 2009 3:49 pm
Post by madtheory » Mon Nov 30, 2009 4:04 pm
muhammed wrote: I have big issue with software equlaziers.
What's the issue?
muhammed
Post by muhammed » Mon Nov 30, 2009 5:11 pm
What's the issue?
I pulled 20-50 Hz down then my analog bass loosed its warm'ness and originality. İt is the issue
tallowwaters
Gear: LC-MS/MS
Post by tallowwaters » Mon Nov 30, 2009 6:05 pm
Well, what software are you using?
EQ isn't a simple and magical thing, it's a subtle art.
Post by madtheory » Mon Nov 30, 2009 6:29 pm
Yes, there's an art to it.
muhammed wrote:
What's the issue?
Did you use a shelf or a notch? How many dB? What Q did you use?
muhammed
Post by muhammed » Mon Nov 30, 2009 6:55 pm
tallowwaters wrote: EQ isn't a simple and magical thing, it's a subtle art.
definitely.
I am using cubase.
muhammed
Post by muhammed » Mon Nov 30, 2009 7:21 pm
[/quote]
Did you use a shelf or a notch? How many dB? What Q did you use?[/quote]
yes.
ı am using cubase and its eq
Lo =-6db - 44.0Hz--6
lo mid=-9.6db-60hz-8
hi mid=-24db-20hz-6
hi=-7.7db-54hz-7.3
Post by madtheory » Mon Nov 30, 2009 11:21 pm
muhammed wrote: Lo =-6db - 44.0Hz--6
hi mid=-24db-20hz-6
hi=-7.7db-54hz-7.3
That's a completely bizarre eq. There must be something seriously wrong with your room/ speaker interaction. Do you have any acoustic treatment? Maybe post a pic of your setup, with the MS20 in there for a sense of scale.
Furthermore, I listened to your recording. The amount of bass is not excessive. Here it is spectrum analyzed- as you can see the biggest peak is in the "mud" area, 300Hz:
space6oy
Post by space6oy » Tue Dec 01, 2009 12:13 am
what'd you use for that spectrum analysis?
muhammed
Post by muhammed » Tue Dec 01, 2009 9:19 am
This is Roger Nichols Digital Inspector. I use Sennheiser earphone so ı dont need acoustic treatment. I am thinking buying hardware eq.
muhammed
Post by muhammed » Tue Dec 01, 2009 10:21 am
here is another record.http://hotfile.com/dl/19158786/2a6c44f/ ... 3.wav.html ı recorded my roland sh 101 everything seems fine. ı guess ı have trouble mixing aggressive korg ms 20 basses
Post by madtheory » Tue Dec 01, 2009 1:07 pm
muhammed wrote:This is Roger Nichols Digital Inspector. I use Sennheiser earphone so ı dont need acoustic treatment. I am thinking buying hardware eq.
If you don't already have an acoustically treated room and good speakers, then a hardware eq is a waste of money (and that's not an opinion, it's a fact). Get the room and speakers right first. Headphones, while good, are a compromise, and are more difficult to mix with than a well treated room with good speakers.
That said, the Roger Nichols Digital Unequalizer is probably the best eq under $500, hardware or software. That is an opinion. :)
k5k
Gear: SH101, Pulse, Poly800, CZ5000, ESI-32, ADX1, DR110, DR5
Band: K5K
Post by k5k » Thu Dec 03, 2009 1:29 pm
muhammed wrote:I use Sennheiser earphone
bass boost?
aklass.com
godrekidz.co.nz
k5k.aklass.org
breakcoreisland.com
