I recently received Audio-Technica AT-2020.
I connected it to X-Station (xlr to xlr) 49 and X-S to my laptop via usb.
On Fruity Loops, I changed the audio input to X-Station.
I can get sound out of the synth, but I can't get sound of the mic.
X-Station provides phantom power, so I don't see why I can't get the sound out.
Any idea?
Can't get sound out of condenser mic
READ: Please Read the Rules of Sound Production.
- meatballfulton
- Moderator
- Gear: Logic Pro X
Re: Can't get sound out of condenser mic
You made sure to turn the phantom power ON, right?
Thank you. That was the problem.meatballfulton wrote:You made sure to turn the phantom power ON, right?
I feel so dumb now.
Now I have another question.
Is it typical for you to use a mic preamps, even though you have an audiocard (in my case, X-Station) that provides phantom power?
Without increasing gain of the mic input, the sound is very small. Am I jeopardizing the sound quality of the recording from mic by increasing the gain of the input to record vocal?
- k5k
- Gear: SH101, Pulse, Poly800, CZ5000, ESI-32, ADX1, DR110, DR5
- Band: K5K
the xstation has a mic preamp and thats what yr plugged into! if the gain is too high it will clip.
aklass.com
godrekidz.co.nz
k5k.aklass.org
breakcoreisland.com
godrekidz.co.nz
k5k.aklass.org
breakcoreisland.com
Great! Thank you k5k.
- th0mas
- Expert Member
- Gear: oakley tm3030/mopho keys/midibox sid/tr-707/tama techstars/monotron
- Band: GRAVITRONIC
It's probably not a very good mic pre however. Depending on the desired quality of your recordings you may eventually want to invest more in a dedicated mic pre.
