Digitized Mess
Dr Amazing
Digitized Mess
Post by Dr Amazing » Thu Jul 14, 2011 12:27 am
How do I stop this? everything I record lately sounds like this crunchy digitized mess...both in Abelton and Garageband
I am using a Mac Book into a Lexicon Omega audio interface...
here is an example of the crunchy mess
http://www.sendspace.com/file/7pe35z
Thanks
Mark
Re: Digitized Mess
Post by Stab Frenzy » Thu Jul 14, 2011 1:04 am
There's something wrong with your interface. Look in the manual for some kind of reset option, and update it to the latest firmware if you haven't already. In fact if it's got the latest firmware you might want to reload it anyway.
Dr Amazing
Re: Digitized Mess
Post by Dr Amazing » Wed Jul 20, 2011 6:27 am
Thank you! ...just did a reset and it works like a gem!
Real name: Unpronounceable
Band: Eridani V
Re: Digitized Mess
Post by Ashe37 » Wed Jul 20, 2011 12:59 pm
Also, when you're doing music stuff, disable most power management settings because if your usb ports go into low power mode the interface may disconnect which usually requires resetting the interface and your software.
psyfi
Re: Digitized Mess
Post by psyfi » Sun Aug 07, 2011 1:54 pm
Also worth checking you projects sample rate is supported buy your interface and that the 2 can sync.
