Is this acoustic panel going to do anything?
Postby Jay200MPH » Fri Jan 10, 2014 6:36 am
My new monitors will be facing a flat, hollow, wall which is about 3m away. There is a faux-suede couch against the wall. I had some pieces of foam lying around; I thought I could glue these down to some MDF/plywood/whatever's cheap and make an acoustic panel for above the couch.
It ended up being a bit small - about 117x63 cm (46x24 inches.) I could place it either horizontally or vertically at that size. Should I build the panel or am I just wasting my foam?
I'll get a pic of the wall space & the couch when I get home. I'm open to alternate configurations for the foam pieces too.
Jay200MPH
Gear: Currently active:
x0xb0x, MC-202, Microkorg, PSR-36, mini-KP, SA-5, JV-1010, S-760, CMU-800.
Sequenced in Impulse Tracker on a P233 w/AWE64+GUS.
Re: Is this acoustic panel going to do anything?
Postby Stab Frenzy » Sat Jan 11, 2014 6:29 am
That's packing material not acoustic foam. It'll absorb top end but won't do much below 1-2kHz, I wouldn't waste my time if I were you.
If you want to do it properly you need proper acoustic material, I find insulation designed for HVAC is the best/cheapest source for making panels. If possible get batts made from polyester rather than fibreglass, it's nicer to have in the studio.
Postby Jay200MPH » Mon Jan 13, 2014 3:49 am
Thanks, yeah, kind of figured as much. I'll try to source the proper stuff and keep my packing foam for its intended purpose (building a carry case for my x0x+MC202) then.
Jay200MPH
Return to Sound Production
