Chorus (guitarpedals) for pads etc
Synthprophet
Post by Synthprophet » Fri Dec 04, 2015 11:30 am
Hello there
I have always been a fan of that vibe of the Juno (6, 60 and 106) chorus polysounds.
Several times I have thought about getting a Juno just for that reason. But then Again I have a couple of synths that should make a fine base for pads. Then I just need the Chorus.
I have read about chorusunits that comes close to the one found in the Junos. Those can be quite expensive, and then Again I don't necessarily need a Juno emulation.
All I need is a great chorusunit, that might make my feet rise from the ground and perhaps put me on a light soft cloud.
I normally use guitarpedals, as they are easy to put on top of a synth.
Perhaps Boss can offer something good?
Clavia: /Nord Lead 2x/
Roland: /AX-Synth/D-50/SH-201/
Korg: /EMX-1/Microkorg/Monotron/MS-20 Mini
monolith
Re: Chorus (guitarpedals) for pads etc
Post by monolith » Fri Dec 04, 2015 1:24 pm
Get a behringer cc-300, it will probably be all you need, and likely for less than $50
Weirdofromouterspace
Real name: Bodo
Post by Weirdofromouterspace » Fri Dec 04, 2015 3:18 pm
Synthprophet wrote:All I need is a great chorusunit, that might make my feet rise from the ground and perhaps put me on a light soft cloud.
Vintage and very affordable (I paid about 30 Euros for mine - German Ebay):
Ibanez CCL Dual Chorus. A wonderful and versatile stompbox (I use mine for the synths, not in my guitar setup).
thermite zapruder
Gear: ARP 2600
EMU SSM Card Kit
Prophet 600
Evolver
ESQ-1
Juno 6
Alpha Juno 2
JV-1010
Crumar Performer
EMU e6400 ultra
MPC2000xl
SK-1
SK-5
Band: Thermite Zapruder
Post by thermite zapruder » Fri Dec 04, 2015 6:32 pm
I have the Boss CE-2--very nice pedal but did not play well, impedance-wise, with my Prophet 600. Can't remember how it fared (or if I tried it) with my other synths. With a ReAmp, however, it's very nice (but something to bear in mind if this is for live use and you don't want to have to bother with impedance matching devices in such a scenario).
The E-H Small Stone (and its offspring) has a proud pedigree for such uses and is much beloved.
Calgonstudio
Real name: Ric
Band: Client No7
Post by Calgonstudio » Sat Dec 05, 2015 7:59 pm
I use a boss CEB2 Bass Chorus with a K2000r,as an Insert with Mix d, Used it a few times with a DX7 seemed to work good.
My Key board player has the same Impedance issue with his Prophet 600, we actually ran his Prophet 600. thru a Peavey Mega Bass amp I had , the mega had a built in chorus that was fairly nice sound had cutoff feq at 200k , If I remember correctly.
