Jx10 v's Jx8p
Jx10 v's Jx8p
Postby Scottf » Fri Jan 14, 2011 4:19 pm
I don't really understand the differences?
I like the Jx8p... dosen't that have way better midi than the JX10.
With the Jx10 polyphony is doubled, ya? but like I ain't really even able to play anything for the moment, I don't think I'll ever need extra polyphony
Could someone give me the advantages of the JX10 please?
Scottf
Re: Jx10 v's Jx8p
Postby rhino » Fri Jan 14, 2011 4:30 pm
The ability to split/layer two seperate patches.
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: Jx10 v's Jx8p
Postby CfNorENa » Fri Jan 14, 2011 7:12 pm
rhino wrote:The ability to split/layer two seperate patches.
This. Esp. the layering part. When you combine two separate "tones," you can get some really nice, slow, evolving, deeply textured pads that JX8P just can't do.
CfNorENa
Re: Jx10 v's Jx8p
Postby iphoenix » Sat Jan 15, 2011 1:50 am
A really nice semi-weighted 76 key keyboard. The JX10 is essentially 2 JX8P sound boards inside, though apparently the chorus sounds slightly different .
iphoenix
Real name: Paul
Re: Jx10 v's Jx8p
Postby space6oy » Sat Jan 15, 2011 1:57 am
this obviously belongs in the synth shootout section...
space6oy
Re: Jx10 v's Jx8p
Postby Scottf » Sat Jan 15, 2011 6:41 am
Your'e right, though it's because I want to purchase either...
Scottf
Re: Jx10 v's Jx8p
Postby max badwan » Wed Feb 19, 2014 2:57 am
Dual mode is static, V-mix and V-switch are dynamic, the ability to mix/switch the two engines via velocity is my favourite thing about the 10P.
max badwan
Real name: Max
Gear: T1, XV 5080, Fantom XR, Varios, Cubase 4
Re: Jx10 v's Jx8p
Postby Quavermass » Sun Apr 20, 2014 10:26 pm
New Firmware under Beta testing for the JX10 Improves the sysex control to full tone A and B editing, use of the front panel sliders to edit tones/adjust tone parameters while playing a patch,replaces the useless sequencer with a Midi clockable Arpeggiator and generally speeds the operation of the machine up....all on a drop in ROM replacement.
Old vid of one of the other Beta testers
Watch on youtube.com
Currently testing v3893 which fixes any of the problems in his other vids
Quavermass
Re: Jx10 v's Jx8p
Postby madtheory » Mon Apr 21, 2014 8:11 am
Alternatively, the MKS70 is a JX10 in a rack with proper MIDI.
Band: madtheory
Re: Jx10 v's Jx8p
Postby corndogssg » Thu Apr 24, 2014 9:31 am
so is the jx8p= to a dx7
and the jx10= to a dx7ii
does that make sense? the dx7ii can make 2 diff dx7 sounds layered (although people would argue the dx7 sounds better than the dx7ii in single layer sound)
basically is the jx10 able to do pretty much 99 percent the jx8p can do, as well as double layer and splits?
corndogssg
Real name: ryan
Gear: v synth,little phatty2,jx10,kiwi106 jx305, jv2080x's8,k2600,ion,microQ,blofeld,evolver,tetra,x station,ultra nova,bass station2, jd990,minibrute
Band: sesame street gangsters
Re: Jx10 v's Jx8p
Postby commodorejohn » Thu Apr 24, 2014 1:00 pm
That's a pretty good comparison, yeah.
commodorejohn
Real name: John
Gear: Roland JX-10/SH-09/HS-80D-50, Yamaha DX7-II/V50/TG33, Korg MS-20 Mini/Odyssey/DW-8000/M1, Ensoniq SQ-80, E-mu Emax, Casio CZ-5000, SCI Prophet-600
Return to Synth Shootouts
