Ensoniq SQ-80 vs Korg DW-8000 ?
im intersted in one of these..
which one u would say is better?
- Senior Member
- Real name: David
- Gear: Oberheim: OB-8, DSX, DMX, DXa, Yamaha CS-15, Akai AX-60, S612, Moog Taurus 3, Alesis MMT-8, HR-16, Fender Bass IV, Rickenbacker 620/6, Crumar Trilogy
- Band: Season Finale
Re: Ensoniq SQ-80 vs Korg DW-8000 ?
I'm interested as well.
I keep thinking "poor mans PPG WAVE"... do either fit the bill better?
- Senior Member
- Real name: David
Also, FWIW, the Ensoniqs seems to go for cheaper.
- Senior Member
- Real name: David
no the Dw 8000 goes for cheaper here..themilford wrote:Also, FWIW, the Ensoniqs seems to go for cheaper.
usual price DW 350-400€ , SQ 600€
- Senior Member
- Real name: David
Maybe, I was basing it on completed US eBay auctions/sales.laserboy wrote:no the Dw 8000 goes for cheaper here..themilford wrote:Also, FWIW, the Ensoniqs seems to go for cheaper.
Ok, sorry... I just double checked.
DW8000 are selling for between $200 and $460 and the last eight SQ-80s went for $300-$500... most with cases.
- Walter Ego
- Senior Member
- Gear: Various noisemakers hidden around my home and classroom. And a great quantity of caffeine.
- Band: 12"VS
In the states, you can find Ensoniqs for cheaper. Use craigslist, though, they're heavy as all get-out, and they'll be much cheaper on CL. If you want to go really cheap, buy an ESQ-1, which is exactly the same as an SQ-80, but no disk drive and less patch storage. Easy find for $100-150 on CL in the states. Maybe not in other countries, though, as I think Ensoniq is a US-based company.
Walter Ego
seamonkey wrote:I nominate this for STUPIDEST THREAD ever in the history of the internez.
is craigslist trustful? and which area should i check there? im not familar with the website
and ist the ESQ -1 really the same except Disk and patch save?
in that Case i would think about to get a Esq1
- Big Gnome
- Gear: E-mu Proteus 2500
Ensoniq ESQ-1
Ensoniq VFX
SCI Prelude
Waldorf Blofeld - Band: The Nondescript
Not quite--the SQ-80 has a few more waveforms, and polyphonic aftertouch. But both 'SQs are excellent.Walter Ego wrote:If you want to go really cheap, buy an ESQ-1, which is exactly the same as an SQ-80, but no disk drive and less patch storage.
Some of my c**p
Some of my c**p
I just saw theres also a SQ-1..whats the difference to the ESQ-1 ?
- Moderator
- Real name: Unpronounceable
SQ-1 is a different beast, its more like half of a VFX. If you really want a poor man's PPG Wave, the VFX/ VFX-SD/SD-1/SQ series has scannable wavetables, the ESQ-1/SQ-80 and DW-8000 do not.
(And the Kawai K3 has SEM filters like the PPG)
- Sir Ruff
- Gear: Two persimmon modulators and a frequency adjudicator.
- Band: Ruff in the jungle
But of course the VFX (and TI?) series all lack resonant analog filters... Waldorf was the only company to really ever really combine the two, unfortunately.Ashe37 wrote:SQ-1 is a different beast, its more like half of a VFX. If you really want a poor man's PPG Wave, the VFX/ VFX-SD/SD-1/SQ series has scannable wavetables, the ESQ-1/SQ-80 and DW-8000 do not.
You can use slightly clever LFO>Amplitude tricks to create wavetable-like scanning on the earlier Ensoniqs, but it's not really the same.
Do you even post on vse bro?
- Senior Member
- Real name: David
From the demos to which I've listened:
The K3 seems smoothest, but underwhelming... certainly not a very big sound.
The DW8000 seems to sound pretty lush and "analog"... meaning it seems to approximate bigger polys pretty well... but also adds a tad of weird digital underneath. Sounds like a shrunken-down, muffled PPG... like WAY less impact or weight... but similar. The arpeggiator sounds great. I kinda wish the DW wasn't c**p plastic with a typical keybed, otherwise I'd like to snag one to have as my hybrid and arpeggiator master keyboard.
The ESQ-1/SQ-80 seems to be the most unique of the bunch. Seems like it's own thing... can do the PPG thing a little better than the DW and seems to have more unique features. Build quality of the original metal ones seem really nice. People say it makes a nice master keyboard. Too bad it doesn't have a decent arpeggiator instead of it's maligned sequencer.
- Walter Ego
- Senior Member
- Band: 12"VS
CL is just an online classified ad site. It's as trustworthy as people are. Just use common sense. There's not a ton of scamming going on in the lesser-known, lesser-sought-after synth world on craigslist--the target net isn't wide enough. Still, you should be careful.laserboy wrote:is craigslist trustful? and which area should i check there? im not familar with the website
Go to craigslist and find your locality. Search away!
Walter Ego
- Kenneth
- Real name: Kenneth
- Gear: Nothing I own will make you jealous.
- Band: KGB
I used to own a DW8000. I love that synth. Once you get past the c**p-tastic plastic chassis and junky clunky keyboard, you will begin to fall in love with the lush "analog" like sounds. The one thing that sets the DW apart from the rest, to me, is the DELAY. Holy moses. One of the coolest, easiest to use, and useful delays I have ever come across. I wish Korg would release that delay as a pedal or module, I would be the first to pre order. Anyway... Especially good for pads, strings, and brass ensemble type patches, okay for leads and basses but that's when its digital nature really starts to make itself known. Maybe you don't mind the digital sound (aliasing on lower notes and grainy wave samples on higher notes), but it bothered me a little bit. It's also great for doing weird BOC type soundscapes, thanks to the onboard delay which can also act as chorus or phaser. DW is an all around great synth for the money.
