Ensoniq: ESQ-1 or SD-1?
Postby Tiger Jackson » Thu Apr 04, 2013 4:37 am
Ive been thinking that i might replace my esq-1 with an sd-1 if i ever came across a great deal. From what i know
-Sd-1 has a great piano, even great up to date, while the esq's is seen as aged, thin and cheesey (?)
-sd-1 has no resonant filter, while the esq does
-sd-1 has no analog filter while the esq-1 does
Does the sd-1 support esq-1 patches? I have a cart with my esq-1 patches.
Do you guys think it's worth it?
Tiger Jackson
Gear: Ensoniq ESQ-1, Microkorg, Yamaha DX100, Fizmo
Re: Ensoniq: ESQ-1 or SD-1?
Postby Silverfish » Thu Apr 04, 2013 8:24 am
I think they are different enough to warrant having one of each.
The ESQ-1 is one h**l of an analog/digital hybrid, and maybe the closest synth relative to a SID synth (without actually being a SID synth). Three oscillators. Analog filters. Three very flexible LFOs (if I'm not mistaken). 80s digital synth sounds with a warm curtis filter. Yummy.
I've never used an SD-1, but on paper, it looks to do a different type of digital sound. To my ear, the SD-1 sounds like a very 90s rompler. Nothing wrong with that sound, but not my flavor. If you want to dig into synth-programming territory, I imagine you'd find some very grainy, cold, glassy sounds, which would also be awesome.
So there you have it. My somewhat biased opinion towards the ESQ-1 and the SD-1. Happy synthing.
Silverfish
Real name: Tyler
Band: Silverfish
Postby meatballfulton » Thu Apr 04, 2013 11:59 am
Tiger Jackson wrote:Does the sd-1 support esq-1 patches? I have a cart with my esq-1 patches.
No
No, keep the ESQ-1.
SD-1 does have better samples for things like pianos, but if you just want a better piano you can get that in a lot of ways.
Gear: Live 9, Logic Pro X
Postby rhino » Thu Apr 04, 2013 4:28 pm
SD-1: Full-featured sequencer, nice effects.
ESQ-1: That vintage 8-bit sound.
You need both.
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Postby Sir Ruff » Thu Apr 04, 2013 4:40 pm
The best feature of the SD-1 is its "transwave" ability (Ensoniq speak for Waldorf-like wavetable modulation), and ability to modulate effects. But I wouldn't give up the ESQ-1 for it. You can sort of emulate those sounds using clever VCA modulation on the ESQ, and it's just SO much easier to use.
Do you even post on vse bro?
Sir Ruff
Band: Ruff in the jungle
Postby Walter Ego » Thu Apr 04, 2013 6:01 pm
Tiger Jackson wrote:-sd-1 has no resonant filter, while the esq does
I'm being stupidly nit-picky, but the ESQ doesn't technically have a resonant filter. But it does still have a VCF and VCA with very flexible routing and FOUR envelopes that can be routed anywhere. Pretty cool.
Walter Ego
Walter Ego
Band: 12"VS
Postby rhino » Thu Apr 04, 2013 7:21 pm
The ESQ-1's filters are analog and DO have resonance - just (as set at the factory) can't quite be pushed into self-oscillation.
Also - although the SD's piano waves can be useful, they are blown out of the water by even a cheap piano module (Kurzweil MicroPiano for one)
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Postby Tiger Jackson » Thu Apr 04, 2013 7:59 pm
Ok i will keep the esq-1. i already have 2 full sized boards and just didn't really want to have another (space issue), the second board is a fizmo i recently got, so i don't really need the sd-1 for its transwaves.
Tiger Jackson
Return to Synth Shootouts
Users browsing this forum: No registered users and 10 guests
