Prophet 08 vs Prophet 12
chiro973
Post by chiro973 » Tue Oct 22, 2013 4:07 am
Different creatures in many respects, I understand. I am in a band that essentially covers classic rock and some newer stuff 70s to present. Night Ranger, Styx, Journey, Loverboy, Faith no More, Robert Palmer, Bon Jovi (you get the idea). So...I understand some of the differences between these two boards, but my needs are live cover stuff, intuitive programming/tweaking and great sounds for the genres I am involved with. Understand either would do, but...probably one is better than the other for what I need. Currently using a Yamaha MOX-6, Access Virus TI2 and a Korg Kaosillator Pro. The VIrus is pretty cool, well-built but seems its default sounds are in the NIN, Industrial, Techno, Trance, Hip Hop. et al and that you can get classic VA stuff but it takes a lot of work and is not its strength.
SO...what say you all?
Re: Prophet 08 vs Prophet 12
Post by Ashe37 » Wed Oct 23, 2013 9:52 am
Prophet 08...
Or an Alesis Ion.
Gear: Live 9, Logic Pro X
Post by meatballfulton » Wed Oct 23, 2013 1:15 pm
The MOX is more than capable of "classic rock" synth sounds. There are a number of third party voice libraries in addition to what's in the factory sounds.
Some links
Vintage Keys
Phat Analog
Phat Analog II
Stage and Studio
Bitexion
Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Post by Bitexion » Thu Oct 24, 2013 11:33 am
The MOX should cover your bases pretty well. Some of the third party libraries don't even use new samples, they just created sounds from the onboard samples in really creative ways.
I don't see my Motif XF as a "rompler", but as a subtractive synth with thousands of oscillator waveforms instead of just 3-4. It's voice structure is very similar to any subtractive synth. Can combine up to 8 elements (voices), each with its own waveform, filters and envelopes or a global filter and envelopes. And add in LFO modulations and effects and whatnot.
Just saying maybe you don't need to splurge $2000 on a new synth if you can use your existing equipment better :)
cornutt
Gear: 6th
Post by cornutt » Thu Oct 24, 2013 6:57 pm
It's my understanding that the P12 incorporates at least some of the Evolver functionality, but I haven't dug into it yet to figure out how much. Since all versions of the Poly Evolver are now discontinued, it would be nice if the P12 covered that territory.
Bitexion
Roland D-50
Creamware Minimax
Yamaha DX7s
Post by Bitexion » Fri Oct 25, 2013 12:51 am
Well, I'm sure Dave could have just remade the P5 with more voices and it'd still sell like warm cookies. But he didn't.
philip
Real name: Philip
Post by philip » Fri Oct 25, 2013 3:36 am
NONE!!!
Prophet 5!!!
shaft9000
Real name: Dave
Band: moneymoneymoney
Post by shaft9000 » Fri Oct 25, 2013 3:53 am
just brush up on your synth patch know-how.
going analog like the P08 will necessitate adding FX and such. it also doesn't sound very big except in unison mode. i have a ton of analogs, and frankly, the alesis Ion will serve you better for this task. Your MOX and Virus are plenty capable you just need to iron out their idiosyncrasies.
Presets are convenient - when you 'luck out' or narrow your requirements - but there's truly no substitute for the benefit gained from spending hours programming. Sound-On-Sound has a great series for novice-intermediates called Synth Secrets i think. Good luck!
chiro973
Post by chiro973 » Fri Oct 25, 2013 4:39 am
I appreciate all the responses so far, thanks. As to why I don't use the MOX 6 "better", etc is that it is my main axe and I use it even multi timbral fashion for piano, organ, guitar, so when I need the classic synth stuff I need another keyboard, but not to crazy about the Virus.
As to programming I started out in 1976 with a Mini Moog Model D which I still have, had an Oberheim FVS-4 voice that I sold a couple of years ago, so I do understand the analog side pretty well, had a bunch of keys since then - Roland JV8P, Fantom-S and G, Studiologic Sledge, still have a Yamaha AN1X, had a Nord, and I still have a Novation Supernova 2 48 voice.
But from intuitive programming most of these suck (except the Sledge which is like a mini moog panel) and sound wise they were either okay or so-so to my ears. I love the MOX-6, I guess I could buy a second one, but that seems a bit odd and a different brand gives you more sonic possibilities.
Pro5
Post by Pro5 » Thu Jun 04, 2015 1:15 am
Bitexion wrote:Well, I'm sure Dave could have just remade the P5 with more voices and it'd still sell like warm cookies. But he didn't.
:mrgreen:
