Oberheim OB12 vs Studiologic Sledge
corndogssg
Real name: ryan
Band: sesame street gangsters
Post by corndogssg » Fri Jun 13, 2014 2:05 pm
i had to come up with a good synth shoot out just to simply cure my bordom.
in the BLUE corner we have the OBERHEIM OB12
a very sexy synth indeed with a super interface, people cry it's not a true oberheim because it was made with another company "viscount" but who the f**k cares, so it's not a OBX,OB8! sometimes i think if this synth was called a VISCOUNT OB12 with an oberheim engine like the sledge more people would of got one.
and in the YELLOW corner we have the STUDIOLOGIC SLEDGE
also a very sexy synth with a super hands on interface, and alike the ob12 it too was "tag teamed" with waldorf who supplied the synth engine. although people say it's not as ballsy as a blofeld
so both these synths are nice looking, "tag teamed" to make, have ton's of hands on tweakability with more nobs and faders you can shake a stick at. i believe they are both have 12 polyphony now too and for both the price is around 1000-1200 bucks.
so what one would win in your opinion and why???
Broadwave
Real name: Andy
Gear: Kronos 2-88, System 8, MODX6, ARP Odyssey, BroadWAVE ARP 2600EX, BroadWAVE Modular, BroadWAVE Sparta, BroadWAVE Minimoog, oh... and some guitars.
Re: Oberheim OB12 vs Studiologic Sledge
Post by Broadwave » Sun Jun 29, 2014 1:35 pm
I've had both... Got rid of the OB12 and kept the Sledge.
I found the sound of the OB12 to be quite "static" I just didn't warm to it. No matter how much you tweaked the Osc's it just sounded flat... if you put it into Layer mode it went crazy as one voice would always lag behind the other as the CPU can't cope.
The Sledge is one of the warmest and (dare I say it???) fattest VA's (with a knobby interface) I've owned. Sure there may be better out there (Access/Nord?), but the Sledge has an immediately tweakable panel... no menu diving!
What you see is what you get, and it doesn't rely on a crazy modulation matrix to "force" it to sound great... it just does what it's supposed to do.
natrixgli
Gear: USB Hub, Pedalboard, Keyboard Stand, and many cables.
Band: Suboscillator
Post by natrixgli » Sun Jun 29, 2014 8:45 pm
I just recorded a little demo of some monophonic sledge sounds, 'case you're curious what it can do with one voice. Mostly just tweaking an arp throughout the entire thing, nothing particularly musical. No external FX used.
natrixgli
Band: Suboscillator
Post by natrixgli » Sun Jul 06, 2014 3:32 pm
Oh and I owned a OB-12 many years ago (somewhere around 2001 when they were cheap!) I paid $550 for it and later noticed it smelled like a cat peed on it. I currently own a Sledge. Had it about 2 weeks, looks a bit like pee but does not smell like it.
Everything on the OB-12 had the zipper effect. The pitch wheel, glide/portamento, sliders, etc. It had a wimpy and lifeless sound. The effects were useless. What I liked about it was the flexibility and the display. But neither of those things can compensate for weak sound and cat pee smell. So I sold it.
But to be fair I'm contemplating swapping my Sledge out for a Nord A1. The Sledge sounds outstanding, but some of the controls are unpredictable. For example the LFO depth seems to do nothing at lower levels. At high levels, if the LFO cycle exceeds the parameter's min or max value, the sound is truncated during that portion of the sweep. Which effectively narrows the range of the LFO quite a bit. You have to be kind of reserved with it. Then of course there's the fact that the LFO's can't sync between voices, which at some settings can produce very undesirable sounds. (But can also be quite cool sometimes!)
But if you can get past some of these oddities (early Nords had LFOs that behaved much the same) you are rewarded with a very instantly gratifying synth capable of some really huge and interesting sounds. You could go for the much more flexible Waldorf Blofeld but personally having owned both I think that not only does the Sledge sound have more power in my opinion, but you're also more likely to go exploring with those big ol' knobs staring you in the face.
So in conclusion between the OB-12 and Sledge:
- Sledge KILLS the OB-12 on sound. Absolutely murders it. And it's much more straight forward save for the few controls that don't exactly do what you'd expect. (LFO Depth and Osc 2>3 sync I'm looking at you!)
- OB-12 has the flexibility and tweakability, but it's let down severely by poor parameter resolution and a weak CPU.
Winner: Sledge by a country mile.
Broadwave
Real name: Andy
Post by Broadwave » Wed Jul 09, 2014 9:00 pm
natrixgli wrote:But to be fair I'm contemplating swapping my Sledge out for a Nord A1.
I've been promised by Studiologic that there is an impending update (September). Hopefully it should fix a few bugs, and add some features. It will also include Blofeld's SL License upgrade, so you can download samples into the Sledge... so, maybe hang on a while ;)
Post by Ashe37 » Thu Jul 10, 2014 10:23 am
Can you upload user wavetables to a sledge?
Broadwave
Real name: Andy
Post by Broadwave » Thu Jul 10, 2014 1:32 pm
Ashe37 wrote:Can you upload user wavetables to a sledge?
Not sure yet how compatible the update is to the Blofeld SL (which allows for user Wavetables)... Guess we'll have to wait and see.
Post by Ashe37 » Mon Jul 14, 2014 1:49 am
No, license SL is not needed on a Blofeld for user wavetables. It is needed for *samples*, but not wavetables.
SynthatticCA
Real name: Jamie
Post by SynthatticCA » Mon Sep 12, 2016 11:52 am
I presently own both as well as a number of other VAs.
Not sure why so many are digging in the OB12. Do you guys program your own sounds? I have heard them to be buggy but I feel like I might have lucked out. All the OB12s I've owned through the years have operated perfectly (fingers crossed).
When I first got the sledge, I liked it but didn't love it. Now it's grown on me. Especially since firmware 2.1 was released. While I have a whole bunch of VAs and also true analog, I'm now in the process of altering my sledge to fit into a wider, more unique role...because it can.
I'm planning on uploading raw wave data and wavetables into the sledge from the PPG wave mapper, as well as raw sample data from the Fairlight CMI. I think that will offer up a lot of new options that take the Sledge out if the VA realm and into its own.
I'm also seeking someone to help customize a new body for it. I hate that cheap plastic yellow casing! I'd like to build a new wooden casing for it, and maybe change the knobs out for something less chunky. Might also redo the silk screening to lettering that isn't so "Space Robots 2029".
As for the OB12, I always loved it. It's shortcomings are not so apparent for me because I use so many different things I do t rely heavily on a feature set. I will say I rarely write a patch that is more than a double part on the OB12. So, I haven't noticed a lag. I also don't think it's sound structure really needs more than two parts.
I do love the sound of the OB12, but I don't feel like I can really compare the two. As strictly VA instruments, I do feel the Sledge has a sonic advantage, but the OB12 has some beauty in its simplicity. Don't over-program the sounds, but under programming makes the synth sound boring. It has this subtle sweet spot where it shines. Therefore, I don't recommend the OB12 to anyone who doesn't have nearly every other option available.
Also, the sledge is very road friendly. Even if you bust it, another one is readily available on the cheap. My OB12 will never leave my studio.
vicd
Real name: Victor
Band: ROBOPOP
Post by vicd » Mon Sep 12, 2016 5:24 pm
Go with Axel Hartmann :mrgreen:.
His "20" synth looks essentially a Sledge engine inside a fancy high-tech machined metal casing.
