oberheim matrix 6r vs 1000
corndogssg
Real name: ryan
Gear: v synth,little phatty2,jx10,kiwi106 jx305, jv2080x's8,k2600,ion,microQ,blofeld,evolver,tetra,x station,ultra nova,bass station2, jd990,minibrute
Band: sesame street gangsters
Post by corndogssg » Wed Aug 27, 2014 11:27 am
I would like to get on of these two for use with my kiwi patch editor. any suggestions. is the 1000 just a "best of" of the 6? just wondering why it only got 3 stars? they both got a lot of praise from people though. might it just be that they are a b***h to edit. hence why kiwi technics made it compatible to use with these 2 synths??
max badwan
Real name: Max
Re: oberheim matrix 6r vs 1000
Post by max badwan » Fri Aug 29, 2014 11:34 pm
as you've got the Kiwi editor, I'd lean toward the 1000: 1U vs 2U for starters, same programmable patch memory (IIRC), but the 1000 has more presets = more jumping off points for tweaking.
Z
Post by Z » Fri Aug 29, 2014 11:54 pm
M6R - 3U rack with 100 patch memories - all of which are user editable and savable from front panel. Bi-timbral / split keyboard ability.
M1000 - 1U rack with 1000 patch memory: 800 ROM only and 200 user via SysEx.
The M6R was my first rack mount synth. The parameter legend is printed on the top of the unit and you cannot see the list when it is installed in a rack. You will need to have a parameter chart handy when you're first starting out. After you've spent some time with it, you'll get a feel for where all the parameter are. There's no data slider, but +1/+10/-10/-1 buttons for fine and course editing. But if you're going to use the Kiwi editor, that shouldn't be a major concern.
max badwan
Real name: Max
Post by max badwan » Sun Aug 31, 2014 6:45 am
my bad, thanks for the correct, Z.
