MFB Tanzbar vs. Roland TR-8
Zmeinogorsk
Post by Zmeinogorsk » Sat Feb 28, 2015 9:14 pm
I bought a Tanzbar about a year ago, while I really love its lo-fi grit, the build quality is iffy and figuring out some of the functions can be a chore.
The consensus on the TR-8 is that is sounds pretty good, and honestly it's a lot cheaper, so if I sold the Tanzbar I could free up some much needed cash.
Can any Tanzbar/TR-8 owners chime in on this issue? If I were to sell the Tanzbar would I seriously miss its analog grit and vibe (which it has tons of) in favour of a digital replacement?
ppg_wavecomputer
Band: ['ramp]
Re: MFB Tanzbar vs. Roland TR-8
Post by ppg_wavecomputer » Sun Mar 01, 2015 11:53 am
I think it's easy to add grit and imperfection. Run the TR through some external devices and I am sure it will come to life.
Stephen
https://ramp1.bandcamp.com/
Sir Ruff
Band: Ruff in the jungle
Post by Sir Ruff » Wed Mar 11, 2015 11:47 pm
It's pretty easy to answer that question yourself: Do you want barely editable 808/909 clone sounds and a simple interface, or a more complex and editable analog drum machine? Unless you are determined to have the 808/909 sounds, I would stick with the Tanzbar. Much more interesting machine.
Do you even post on vse bro?
