Speaker setup
Blackie1
Re: Speaker setup
Post by Blackie1 » Sun Sep 21, 2008 7:32 pm
Hey, I just picked up a pair of PA speakers at a yard sale for $20 for both. The brand is Toa. Unfortunately, they aren't powered, just an in and out jack. I connected one up to a stereo receiver, and it played the radio, but the other one has a messed up contact, the thin metal piece where the 1/4 jack goes is disconnected, (actually both the in and out socket are like that) and I need to fix them. I know the speaker works though.
Any suggestions? And all I'll need is an amp, correct?
waveterm
Gear: A lot more than you
Re: Speaker setup
Post by waveterm » Sun Sep 21, 2008 7:41 pm
Yep !
You´ll need an amp.
Check what impedance the and power rating the speakers have and buy an amp that is capable to drive them.
One thing to remember is that it is better to have an amp that is a bit more powerful than the speakers.
You could also look for a powered mixer.
WT
Just a guy with a bunch of blue things.......now, move on !
Blackie1
Re: Speaker setup
Post by Blackie1 » Sun Sep 21, 2008 7:48 pm
I do have a mixer, it's a small Behringer unit. Probably not powered though, right?
Thanks
waveterm
Re: Speaker setup
Post by waveterm » Sun Sep 21, 2008 8:10 pm
Nope, not likely.
What are the specs of the speakers ?
WT
Blackie1
Re: Speaker setup
Post by Blackie1 » Sun Sep 21, 2008 8:39 pm
They say:
Cont. PGM. Input: 240 Watts
Impedance: 8(then an omega sign)
waveterm
Re: Speaker setup
Post by waveterm » Sun Sep 21, 2008 8:49 pm
Ok,
ideally you would have an amp that outputs 300 W / 8 ohm ( omega sign ).
If you use an amp that is smaller/weaker you run the risk of damaging the speakers.
If you use an amp that is a lot more powerful than the speakers can handle you also run the risk of damaging the speakers.
WT
Blackie1
Re: Speaker setup
Post by Blackie1 » Sun Sep 21, 2008 8:51 pm
Alright, thank you for the help!
waveterm
Re: Speaker setup
Post by waveterm » Sun Sep 21, 2008 8:59 pm
Cool !
Let us know what you end up with.
WT
Blackie1
Re: Speaker setup
Post by Blackie1 » Sun Sep 21, 2008 9:44 pm
Will do. I just wish I would have asked the guy if he had the amp that went with them.
sonny1
Gear: Lots of Gear. I don't know. Gear is only about 1/4 of the equasion anyway. 1/4 is who you play with and 1/2 is what you dowith the gear you have.
Band: Press Two for Panic!!!
Re: Speaker setup
Post by sonny1 » Thu Sep 25, 2008 7:50 pm
Blackie1 wrote:Hey, I just picked up a pair of PA speakers at a yard sale for $20 for both. The brand is Toa. Unfortunately, they aren't powered, just an in and out jack. I connected one up to a stereo receiver, and it played the radio, but the other one has a messed up contact, the thin metal piece where the 1/4 jack goes is disconnected, (actually both the in and out socket are like that) and I need to fix them. I know the speaker works though.
Hey, If you go to a pawn shop I'm sure they will have a Amplifier for 100, or less. Look at peavy They are cheap, and durable I think they used 8 ohm speakers. I'm pretty sure, but check.
Korg Triton (2001), Ensoniq esq-1, Casiotone 401, Suzuki Omnichord version 200 (electric autoharp). E-MU Ultra Proteus, Ensoniq QS-R. Yamaha RX-8. Yamaha QX-21,Yamaha AN1x
