Keyboard Stands
schmidtc
Keyboard Stands
Post by schmidtc » Wed Nov 12, 2008 11:17 pm
Any recommendations on a two or 3 tier stand? Industrial strength is a must as it is going to support 100-150 lbs. If one tier could go flat it would be great. For whatever reason a Prophet VS requires a flat surface. The price is right on these: http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0306169707 but I suspect there is a good reason.
Box
Gear: Roland JP-8000
Roland JX-3P
Roland JX-8P
1972 Wurlitzer Console Piano
Band: Neo Decorum
Location: Land of oscillators, filters, and other really cool looking stuff.
Re: Keyboard Stands
Post by Box » Thu Nov 13, 2008 3:53 am
I personally use double braced X-stands. Very sturdy, don't rock. I can stand on in it and it won't tip. Then again I think mine is from the 80's, all metal, even the teeth locks. It alone weighs about 40-50 lbs. But some people will tell you A-frame is the best, so it depends really. A-frame is a b***h to move and set back up though. X is much easier to transport and set up. Go to a music store and see what you like most.
Help our very own Maschinengeist (Stéphane) by making your next purchase or repair with him! Click the logo for more info!
Johnny Lenin
Re: Keyboard Stands
Post by Johnny Lenin » Thu Nov 13, 2008 4:15 am
I have a 3-tier standtastic stand [see below] that is rock-steady and tough. It also breaks down easily and packs in ts own gigbag for gigging. It can bear 100 lbs per tier.
Z
Re: Keyboard Stands
Post by Z » Thu Nov 13, 2008 4:26 am
I've been considering one of the Standtastic stands. Has anyone used the 3 tier stand with and added 4th tier? If so, opinions, please. Also, how deep can the keyboard supports extend to? I've got several deep vintage synths.
Johnny Lenin
Re: Keyboard Stands
Post by Johnny Lenin » Thu Nov 13, 2008 4:11 pm
Z wrote:I've been considering one of the Standtastic stands. Has anyone used the 3 tier stand with and added 4th tier? If so, opinions, please. Also, how deep can the keyboard supports extend to? I've got several deep vintage synths.
I have four boards on three tiers -- my Fantom sits on top of my Vox on the lowest tier. And the tier arms extend to 24". They are long enough to accommodate the Vox, and I don't think even a CS-80 is as deep as that. The stand is 57" tall, and you can run tiers right to the top, so it will accommodate four tiers, easily. And you can get accessory shelves, mic booms, etc. that attach to the rails.
My set-up:
spookyman
Gear: cheezy machines and some cheap analog stuff
Re: Keyboard Stands
Post by spookyman » Thu Nov 13, 2008 5:04 pm
Looks really cool these Standtastic...the only problem, impossible to find in Europe. :|
It is much easier to be a good equipment purchaser than to be a great musician.
Z
Re: Keyboard Stands
Post by Z » Thu Nov 13, 2008 6:19 pm
Thanks for the info JL. Too bad GC doesn't stock them. Guess I'll have to order one online if I decide to purchase one.
killanator
Real name: Carl
Gear: Alesis Quadrasynth, Roland SH-201, Various MIDI things, Samson MediaONE 5a Active Studio Monitors
Band: Solo
Re: Keyboard Stands
Post by killanator » Fri Nov 14, 2008 6:57 am
i just recently got a double braced on-stage stand for 29.95 USD0 on sweetwater and it was another 29.95 for the second tier. not sure about the quality, i hope it will hold out well
pangmaster
Real name: Nathan
Gear: Voyager, PEK, A6, FIZ, Six-Trak, Juno, CZ, and other stuff
Re: Keyboard Stands
Post by pangmaster » Sat Nov 15, 2008 4:45 am
Johnny Lenin wrote:I have four boards on three tiers -- my Fantom sits on top of my Vox on the lowest tier. And the tier arms extend to 24". They are long enough to accommodate the Vox, and I don't think even a CS-80 is as deep as that. The stand is 57" tall, and you can run tiers right to the top, so it will accommodate four tiers, easily. And you can get accessory shelves, mic booms, etc. that attach to the rails.
Looks great JL... It appears that all tiers on the Standtastic stands have adjustable angles. Is that right? I've been looking for a stand that would allow me to keep the bottom tier at an angle, and with all of the double-braced X-stands the bottom tier must be flat without some sort of modification.
"To be human, to be fully human, is to need music and to derive nourishment from the music you hear." - Bob Moog
Johnny Lenin
Re: Keyboard Stands
Post by Johnny Lenin » Sat Nov 15, 2008 5:14 am
pangmaster wrote:Looks great JL... It appears that all tiers on the Standtastic stands have adjustable angles. Is that right? I've been looking for a stand that would allow me to keep the bottom tier at an angle, and with all of the double-braced X-stands the bottom tier must be flat without some sort of modification.
That is correct. You can tilt all the tiers down, in something like 10 degree increments [I don't have a protractor].
pangmaster
Real name: Nathan
Re: Keyboard Stands
Post by pangmaster » Sat Nov 15, 2008 5:31 am
Johnny Lenin wrote:That is correct. You can tilt all the tiers down, in something like 10 degree increments [I don't have a protractor].
Nice! Time to place an order 8)
braincandy
Retired Moderator
Retired Moderator
Re: Keyboard Stands
Post by braincandy » Sat Jan 17, 2009 8:53 pm
A bit of thread necromancy here...
I'm now in need of a 3-tier stand myself, as I only have a small section of wall to the corner, in terms of space. I currently have an QuikLok double-braced 2-tier X-stand. I could get a universal third tier, but the second tier isn't completely level, as the arms don't adjust inward at the same level.
The Standtastic 3-tier is very appealing, but I noticed another 3-tier model, the QuikLok QL-699 that is a little less expensive ($125 vs. $199 for the Standtastic) and wondered if anyone here has used it? Thoughts?
Fender Blacktop Jazzmaster | Squier CV Duo-Sonic | e6400 Ultra | Blofeld | a bunch of effects
killedaway
Gear: Electribes x 6
Revolution
Monomachine MKII
microKORG
CS01
& more!
Band: killedaway/allyourblood
Re: Keyboard Stands
Post by killedaway » Sun Jan 18, 2009 3:07 am
braincandy wrote: I'm now in need of a 3-tier stand myself, as I only have a small section of wall to the corner, in terms of space. I currently have an QuikLok double-braced 2-tier X-stand. I could get a universal third tier, but the second tier isn't completely level, as the arms don't adjust inward at the same level.
this drives me bonkers. it took me a few minutes to figure out that the 2nd tier was just inherently like this -- at first i thought i just wasn't setting them level. as for that stand you posted, i've never used one, but those two lower legs that come to the ground (closest to the player) don't look so hot -- i guess you'd be putting a lot of faith in the welds there.
1.5.9.13
1.5.9.13
braincandy
Retired Moderator
Retired Moderator
Re: Keyboard Stands
Post by braincandy » Sun Jan 18, 2009 10:48 pm
Yeah, those front legs look a little small on their own and unfortunately none of the music stores around me utilize these stands as displays (they don't have any keyboard specialists, either). I saw one post on KSS praising it, but that's it. There really isn't a lot of feedback regarding 3-tier keyboard stands on any of the forums (here, Gearslutz, KSS).
wojam
Gear: Roland RD-700, Hammond XK-1, Alesis Ion, Alesis Nano-Verb, Traynor K4, Motion Sound PRO-3X,
Fostex VF-08, Shure SM57 etc.
Band: Drama
Re: Keyboard Stands
Post by wojam » Mon Jan 19, 2009 5:39 am
Looks good. Can you adjust the height of the tiers, move them closer together?
I'm currently using a 2-tier Invisible stand, but may add a third 'board, so would like 3 tiers.
I'd like to be able to adjust the space between the 'boards. This is for live and home, I'd be
sitting/standing at it, 27" - 29" throne. Thx
